03-14-2008, 09:18 PM | #2 |
that looks like the hose that connects from the intake manifold to the brake booster. 1 of 2 hoses. if its cracked it can cause idle problems and afr problems.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
03-14-2008, 09:33 PM | #4 |
i retract my statement, i believe you're correct with it being the heater hose. It carries coolant through the heater core on the other side of the firewall. shouldn't be tough to resplace. good luck
03-14-2008, 11:16 PM | #6 |
i suppose you could just go to your local kragen/ krack zone and get a similar looking hose and bend it to suit your situation.
