09-10-2013, 09:22 AM | #61 |
Ahhhh ... now that your talking about that ! i remember reading about that bleed line not needed!
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
09-10-2013, 11:49 PM | #62 |
Exhaust also doesn't have the VVL lobes either. I still don't fully understand why, but yeah it was brought that way and I haven't been told it's a bad thing
09-11-2013, 04:42 AM | #63 |
Now its starting to make sence .... you have a vet head and not a ve
The vet comes without the exhaust vvl . If you wana convert your exhaust side you need to buy : P11 Primera exhaust rocker arms and a set of cams of your choice !
09-11-2013, 04:43 AM | #64 |
Kemp (SRT8E180) did the same on is 180sx !
Vet head , p12 cams , P11 Primera exhaust rocker arms , and the list goea on !!!!
09-11-2013, 11:47 PM | #65 |
It's a P11 VE head with custom camshafts with VVL delete on the exhaust camshaft. That's according to both Shred Motorsport [who are building the motor] and E&H Motorsport [where I purchased the head from]
09-25-2013, 02:48 AM | #66 |
Front strut brace
Front sway bar- 27mm (solid) 3 point adjustable Rear sway bar- 24mm (solid) adjustable Surge tank set up Radiator- Koyo s15 ‘N-flow’ double pass radiator ATI damper Genuine Tomei sump Front caster arms Rear camber arms Rear toe arms Subframe lock collars These are are on their way, but there's a six week wait for the sump. Hopefully if the rest of the gear shows up quite quickly they can continue the work on the car with what they have. |
11-21-2013, 07:34 AM | #75 |
Just a heads up Locki, if those lines in your trunk aren't PTFE(Teflon) lined, they are going to permeate fuel smell throughout the car. I found that out with my blue fuel hose and have bought everything needed to convert mine over to PTFE lines. It's a PITA but I don't want to smell fuel the entire time driving.
11-21-2013, 09:08 PM | #77 |
I'm well aware that you may get fuel fumes from the boot or let alone a loud fuel pump noise, cheers though for the heads up
I'm hoping wiring is done by next week. Really wanting this back before end of the year! |
11-26-2013, 11:02 PM | #80 |
The filter relocation kit came with the car when I brought it, so wouldn't know sorry. And cheers . I'm hoping to have it back home before Christmas but I don't think it'll happen.
12-23-2013, 09:45 PM | #88 |
Good god, this is basically the exact build I want to do.
Texas drifting -> http://www.youtube.com/watch?v=yAVPdnMnlag |
