Old 06-03-2012, 07:40 AM   #151
CaBS
CaBS's Avatar
CaBS is an unknown quantity at this point
Heres the part that came from Japan I was harping on about. Had just been working on finishing up spot welds with the linager. Also removed the spot welds on the rail cap where the new section will be going in. Also used some extra hands to do a rough fit of the dash and get ideas on how I'll trim it accurately to fit the cage. I think I've come up with a solid idea to cut it in the correct places before it goes in.
I found this youtube vid which should help abit the gaps on his are where my front cage legs will go so it should turn out well and look pretty neat.
[media]http://youtu.be/1yrOJu62FMk[/media]
Anyways, some pics!
Rail, we ordered the same section for the other side. The floor profile is the same so will fit perfectly. It is going to be slightly tricky though as its inside the other rails at both ends.
The stock rail cap removed so we can go about fitting the new section.
MMMMmm spots =)
Test fit, looks good the plan is to use this dash until I have time to attepmt a carbon layup of the S13 dash which is the end goal.
More soon!
SXDevelopments on Facebook
CaBS is offline   Reply With Quote
Old 06-03-2012, 09:44 PM   #152
Beejis60
Beejis60 is an unknown quantity at this point
Been meaning to read through all of this for quite some time now. Finally accomplished that tonight.
I gotta laugh at the assbag who has literally nothing else to bitch about other than how the welds look... Good.
Hate on hater.
Beejis60 is offline   Reply With Quote
Old 06-04-2012, 08:18 AM   #153
CaBS
CaBS's Avatar
The new chassis rail was now in place ready to be welded in I was super happy with how it has turned out. I managed to rust convert most of the drivers and passengers door sills I just need to do the tops of them now which may prove difficult as gravity is against me!
Some pics
Trim trim
trim
draw
test
trim
draw
clean
clean
Clean
Clean
Fits perfectly still needs to be welded in but looks so factory its not funny. The contour matches the floor perfectly!
Down, down down down down. Mild sign modification :P
The plasma cutter was used to cut out plate sections to cover holes in the firewall. Once the car is rewired no wiring will be in the wheel arches at all anymore. I hadn't seen one used before they're a pretty cool bit of kit!
More soon!
Old 06-07-2012, 08:43 AM   #154
CaBS
CaBS's Avatar
The plates we cut from the sheet turned out quite neat no more giant holes in the front wheel wells anymore. I started treating all the seam welds with rust convertor to minimize the risk of rust later on also going to go nuts with fish oil once all the welding has stopped. Getting the rust convertor in was quiet a tedious task I had to use the syringe to do it ugh.
Spot welding has almost finished up.
I went and bought the seam sealer and 1k primer this week from VG paints. I think I'll probably have to go back and get at least one more tube of the sealer from him though after looking at how much there is to seal back up.
Cleaned all the paint of the triangle gaps they'll have plate welded into them as they are no longer needed for wiring.
Some pics!
More soon! =)
Old 06-11-2012, 09:26 AM   #155
CaBS
CaBS's Avatar
So the next part was a super busy period on the car. All the rust protection priming and sealing had to happen in three weeks before the car went off to get some bodywork done. I'd been doing 7 day weeks on the car currently ranging from a min of 2.5 hours a day all the way up to 8 hour days on the weekends and days off. Lots of work has been getting done though! =D
The shell had the spots linaged back, rust treated, sanded, vacuumed, cleaned with solvent and then primed. This was an epic job and this doesn't include sealing which is another massive task in itself. It was really starting to come together now and not look so much like scrap metal though. =D The following Monday was the deadline for the body shop so it had to be rolling again by the Sunday prior. This was now very achievable with another big week stuck at it.
Oh and huffy sliders are fkn mad fun we wasted afew hours one night on those. =)
Some pics!
Taped up the strut holes so I didn't get primer everywhere while spraying underneath.
Primed!
same
More soon! =)
Old 06-12-2012, 07:30 AM   #156
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
lookin damn good man!
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 06-13-2012, 03:23 AM   #157
CaBS
CaBS's Avatar
Thanks mate, still a long way to go though! Itching to drive it onces its all together. =)
Old 06-14-2012, 10:07 AM   #158
CaBS
CaBS's Avatar
Sealing!
I managed not to get this all over myself accept when James decided to plaster my leg with it while looking the other way lol.
Very happy with how the front towers came out yesterday the rest of the engine bay is way time consuming cause I wanted it to look as neat as possible =)
The engine bay and the interior remained then I needed to get the suspension/running gear in so the car can the towed easily.
Some pics!
More soon!
Old 06-16-2012, 11:06 PM   #159
CaBS
CaBS's Avatar
The next week I got a surprise delivery from the UK, I wasn't expecting these so soon. Poly carbonate very light less than half the weight of the standard glass at a guess if not less.
I did a test fit on the rear hatch. Fits very well with the seal on there it should look very close to standard. Its awesome how they come with the black coloured in sections like standard glass does as well to hide all the pillars. =)
Some shots.
I sat it over the rear hatch to get an idea of fitment. They're pretty damn good I'd highly recommend them. Just keen to see how well they go with some time on the car and scratches. They comes with a scratch resistant coating as an option which I got. I might see if I can run some tear offs on them still anyhow as lexan ones look shitty once they get all scratched up.
More soon.
Old 06-16-2012, 11:48 PM   #160
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
Sweet! What UK company produces those pieces?
scottie is offline   Reply With Quote
Old 06-17-2012, 05:38 AM   #161
CaBS
CaBS's Avatar
plastics4performance champ.
Old 06-22-2012, 07:35 PM   #162
CaBS
CaBS's Avatar
Another big day on the caulking gun was had again. James came to lend me a hand too which was a big help. (thanks) =)
The interior is I would say 90% done there are only a few more seams which need to be done and then some fix up work in afew spots I'm not quiet happy with. Then the doors, steering column, front guards, running gear and suspension all needed to be refitted so the car was back to a rolling shell.
Anyhow some pics of the sealing work. I'm really happy with how its turned out its looking about as neat as I could hope for.
More soon! =)
Old 06-24-2012, 09:14 AM   #163
CaBS
CaBS's Avatar
Did a test fit of the rear quarter windows we pretty impressed with how they fit up. Basically identical to stock windows once they're fitted up with window seals.
More soon.
Old 06-24-2012, 10:08 AM   #164
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
Are you going to daily with those in?
Te37 is offline   Reply With Quote
Old 06-24-2012, 11:00 AM   #165
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Thies plexi windows are dope
Old 06-24-2012, 04:20 PM   #166
shinhed
shinhed's Avatar
shinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of light
I'd love to have your car just as it sits. Love how you actually sealed the seams after you stitched welded them. For whatever reason, most similar builds are never properly re-sealed.
shinhed is offline   Reply With Quote
Old 06-24-2012, 06:42 PM   #167
CaBS
CaBS's Avatar
Nah man weekend/track car only. No daily duties thankfully have a shit box hyundai for that!
Old 06-24-2012, 06:47 PM   #168
CaBS
CaBS's Avatar
Thanks man very happy with them! Just wait and see how they stand the test of time now
Yeh there is so much time in the shell just as it sits and still looked like a car wreck lol =)
Yeh I've noticed that but fear they all face rust issues after not too long cause the factory paint gets burned during the process so everything needs to be treated and oxygen kept away. I've put alot of effort into trying to do that so hopefully this can avoid issues later on. Time will tell though I guess!
Old 06-25-2012, 08:00 AM   #169
tricky_ab
tricky_ab's Avatar
This build is moving quite along. There's a lot going on with the body, but where are you at with the engine?
Old 06-25-2012, 08:48 AM   #170
CaBS
CaBS's Avatar
Things are powering along at the moment. There is a pretty epic engine for this in the pipeline will be more details of this in August. The SXDS15 is stealing alot of time away from my car cause it has to be ready before World Time Attack Challenge for testing.
So much to do so little time!!
Old 06-25-2012, 11:17 AM   #171
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Man, just took the time to read through this. Great parts selection and amazing dedication- awesome build!
I wish you were in the states so that I could swing by on trash day and grab those 180SX windows, lol!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 06-25-2012, 07:10 PM   #172
CaBS
CaBS's Avatar
Hahah, thanks man glad you enjoyed the read!
Nah you wont find those in the trash! Will be kept for a rainy day :P
Old 06-27-2012, 10:44 AM   #173
CaBS
CaBS's Avatar
Had a massive weekend following, picked up the old side skirts and rear bar from Matts who has been kind enough to store them for me since I stripped the car. (thanks again Matt)
Got the car back to a rolling state as well, just put the S13 frame back in so I didn't have to get all the new S15 arms dirty at the body shop.
I've got my concerns about fitting the kit there is a fair amount of work involved to get it to a stage I'm happy with. The origin guards are far from a perfect fit. Also did a bodge trial fit of a 18x9.5 +22 CE the new guards swallowed it whole. You could almost fit your head in the gap! Should fit 11's without much hassle I think!
Have to get up and organise a tow truck the following morning.
Some pics.
Sex =)
NOM NOM NOM!
More soon!
Old 06-29-2012, 10:21 AM   #174
CaBS
CaBS's Avatar
Basic idea of what it should look like. Not super happy with the fitment though will need some fine tweaking.
All sealed up again, passenger door.
This is now back in too. =)
More pics soon!
Old 07-05-2012, 12:01 PM   #175
CaBS
CaBS's Avatar
So the car was back out of my hands and over at Bodyform. It got towed over and slightly sprinkled on but I whipped out the car cover and also dried it down with a rag once the cover was on. The steering is now bodged up and its much easier to move around.
The front koguchi power guards going on have no top pin line through them so I'm considering removing it from the doors and rear guards too. My gut feel is it'll look good but I was slightly worried it might look odd without it as the rest of the panels are so plain.
Was looking forward to a few weeks of much less strenuous work!
Old 07-06-2012, 10:25 AM   #176
CaBS
CaBS's Avatar
The car sat at Bodyform for a lot longer than I'd initially expected which was rather frustrating as there was plenty of other stuff I could have been doing with the same time. After afew weeks Peter free'd up some time and got stuck into making the new inner guard out of the old guard. I popped over on a Tuesday to drop off some wheels that came in from Japan. The outer skin of the guards had already been cut.
You can see how much has been cut away from where in inner skin still sits.
This bend is to give the inner guard a lip to rivet too and the whole thing more strength.
I was pretty surprised how thin this metal actually is, so piss weak its not funny!
Reminds me of the garage sale flyers with the tear off tabs :P
You can see in this shot he car is actually stiff enough now that where jacking it from this point the front wheel lifts off the ground well before the rear. I really need to get the rear droop shortened though when the Bilsteins get a makeover in the not too distant future. The current rear droop is total overkill and is more just an annoyance when trying to jack the car up than anything else.
Should be alot more room in there soon! =)
More soon!
Old 07-09-2012, 08:36 AM   #177
CaBS
CaBS's Avatar
So the next time I went back Peter had riveted the inner guard to the new lip on the outside already and cut the excess off. The origin panel had been stuck on with afew self tappers to line it all up and see how it fitted. It was actually better than I thought when we did our bodge tape on method which was a pleasant surprise, usually its the other way around. :P
Looking up in the guard at the new riveted inner guard with the widebody panel on.
Lots of tiny cuts mean over all the whole thing can have a nice rounded transition. This will all get tied together with urethane paste once its done so it wont fill up with water.
The gap to the outer guard will be covered with a new section of fiberglass.
How the panel will sit.
You can see a dip in the back of the panel. Average glass work, will need to be skimmed with bog. =/
So while we were there with the guard on I thought we'd try on one of the 19x11 -9 SSR rims I'd ordered for a Mate of mine. At full droop this looks like it wont quite fit but once the suspension is compressed it should easily. I've heard the S15 rear subframe pushes everything out 15mm odd further each side though so I'll need to get that in before I can do a proper fitment and order some wheels.
I wish we could have jacked the wheel up. But nothing was handy to do it with that didnt risk damage.
There is a good 25mm or so space on the inside to the strut helped by the 19" size though. I'll probably stick with 18" wheels though so this might be a much tighter squeeze when it gets to ordering wheels. I'll have to wait and see though.
More soon! =)
Old 07-11-2012, 11:09 PM   #178
towlie
Those Pre made fender well weld in thingys, where can I buy them?
Old 07-13-2012, 12:00 PM   #179
CaBS
CaBS's Avatar
I went over to see the car and check how things were going again the week after wasnt quite as much as I was hoping for but there had still defiantly been big steps forward. The guard had been sanded back on the underside and re-glassed evenly making the fit tighter and the guard much more sturdy. It was also glued onto the car with epoxy resin before the glass resin had set so the new position on the car is where the glass will set. Rivets were applied for an extra tight fit as well.
A new fiberglass inner guard has been made and glued in bridging the gap between the new metal inner guard and new glass outer guard. There is still a tiny gap but this can be filled with sikaflex.
Very happy how its turning out there is still alot of sanding and probably a light skim of bog through the panel to remove all the waves and give it a nice glassy finish once painted. I was trying to organise with Jimmy to go over and check it out and show him what lay in stall for us to work on.
Some pics.
More soon. =)
Old 07-14-2012, 07:05 PM   #180
CaBS
CaBS's Avatar
Got them off a fabricator based in South Australia called Rex Kelway look him up on nissansilvia.com and send him a PM.
