04-27-2015, 12:16 PM | #1 |
Lack of power after knock sensor install
Replaced my knock sensor on my ka. Disconnected the battery for 30mins. Hesitates at 2.5k rpm. No power at all. Believe it's in safe mode. Installed Isis knock sensor and sub harness. Erased code also
Any ideas? |
05-08-2015, 06:52 PM | #4 |
Replaced my tps ground on the harness was broken. checked my timing. Car hesitates alot under full throttle and even half. Any one else? searched around didnt get solid answers
05-08-2015, 07:06 PM | #5 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
also, check voltage on TPS as well. if voltage is off, it can screw up your AF raitos pretty bad. why didnt you just buy an OE knock sensor? saving a few bucks on vital engine components is a BIG no no! if a nissan OE part can be had as far as sensors go, ALWAYS use OE! |
