12-03-2018, 11:53 AM | #1 |
5 bolt vs. 6 bolt axle bolt difference?
I recently pulled my open diff with 6 bolt axles and installed a lsd i bought from a friend with 5 bolt axles. I had to reuse the bolts that hold the axles to the output shafts and it feels like there is just a little bit of play in them.
Also, I torqued them down really well and after a few weeks of very light driving some of them have come partially loose. the 6 bolt axle bolts that I have look like this... Does any one know if 5 bolt axle bolts are slightly bigger (larger diameter) than 6 bolt axle bolts? if so, I'll have to make a trip to the hardware store |
12-17-2018, 03:50 PM | #7 |
Trader Rating: (24)
Feedback Score: 24 reviews
Axle bolts have a bigger shank than threads and I've only seen parts store stuff break because the bolts aren't tight in the flanges.
You can either j/y for some bolts from a j30/z32/other 5 bolt car, or you can also but the bolts new from the dealer (I've done that before). |
