08-28-2013, 10:27 AM | #1 |
FS S14 with RB25 swap
Car is SOLD!
Paid $7,150 for the car in 2003, invested $34,000 in parts alone, and am asking $19,000. I am not interested in negotiating price or trades at this point. Need cash for home repairs. http://chicago.craigslist.org/chc/cto/4673843918.html Engine: RB25DET-S1 CP Pistons 8.5:1 RB26 Rods King Bearings JUN Crank Collar ARP Fasteners N1 Oil Pump Rear oil feed blocked Tomei oil restrictor in mid oil feed Tomei valve springs Ferrea +1mm valves New hydraulic lifters New valve seals New seals throughout Intake/Turbo/Exhaust: 4-inch K&N Filter Garrett T04Z 0.84 w twin scroll housing 4-inch thick intercooler Greddy Type-R BOV Q45 TB Greddy Intake Manifold Gizzmo IM Gasket 6Boost exhaust manifold (ceramic coated) Tial 38mm wastegate Turbo exhaust housing is ceramic coated 3-inch SS downpipe is ceramic coated 3-inch test pipe Apexi GT-Spec exhaust Fueling: Deatschwerks 1200cc top feed injectors E85 Fuelab 41402 Pump Fuelab 6 micron filter and check valve -8 Aluminum feed line -6 Aluminum return line Custom aluminum fuel rail SARD FPR with gauge SARD Jet pump killer All other lines are PTFE braided to keep fuel smell from percolating through Ignition/Power: LS2 coil swap MSD spark plug boots/wires NGK copper plugs BCPR6EIS(?) Quest alternator swap Battery relocated to trunk Tuning: Haltech Platinum Pro EMS GM 4-bar MAP sensor GM AIT sensor Boost control solenoid Fuel pump speed control Cooling: SPAL 12-inch fans Dif Fan controller Griffin 3-inch thick radiator Drivetrain: RPS Max Clutch (550 ft-lb rated) Custom 1-piece driveshaft KAAZ 1.5-way LSD 4.63 rear ring and pinion Chassis: Endura-tech coilovers SPL front tension rods Tein tie rods Cusco rear upper control arms Progress front sway bar Whiteline rear sway bar SPL aluminum subframe bushings SPL aluminum diff bushings Brakes: Z32 master cylinder Z32 front calipers New S14 rear calipers Brembo slotted front rotors Brembo rear rotors Project Mu pads Brake line lock SS braided lines Wheels/Tires: Front: Work Emotion XD-9 18x9 +38 Front: Dunlop Direzza 234/40/18 (NEW! 0 miles) Rear: Work Emotion XD-9 18x10 +18 Rear: Mickey Thompson ET Street Radial II 265/40/18 (NEW! 0 miles) Front fenders rolled Rear fenders rolled and pulled 3/4" Interior: Defi oil pressure gauge Defi oil temperature gauge Alpine deck Pioneer 2-way front 6.5" speakers Pioneer 3-way rear 6.5" speakers Last edited by Darius; 01-05-2015 at 09:05 AM.. |
09-01-2013, 05:00 PM | #4 |
Nicely done!! Very impressive I envy your car its sick!! I too have s14 kouki rb25 live 5 mins away from SP, im looking to doing similar set up as yours....May I ask wat project are you trying to acquire next?
Free bump! |
09-05-2013, 02:39 PM | #5 |
Thanks for the compliments! I'm not in a hurry to sell it, but if the right offer comes along, I'll let 'er go. Until then, I will probably do some odds and ends projects this winter.
I was going to snag up a Lotus but the timing isn't right. Last edited by Darius; 09-09-2013 at 07:03 AM.. |
09-06-2013, 06:29 AM | #7 | |
09-06-2013, 01:29 PM | #9 |
It made 738 WHP when the wastegate line split and the boost spiked to like 34 psi. It still didn't lean out or knock on a retarded timing map area, so I know this setup has more left in it.
09-12-2013, 01:43 PM | #11 |
Bump for a nice car. Back when I had an RB, Darius was one of the few knowledgable people when it came to this swap.
I wouldn't hesitate to own anything he has built.
Jets > Cars |
03-16-2014, 05:02 PM | #17 |
Bump for legit car. Saw you at SCS a couple times over the summer. Looks and sounds great. Here's a video of it: https://www.youtube.com/watch?v=2470...ARxAk8Wz3FF2og
03-19-2014, 08:43 AM | #18 | |||
I can get some new interior pics but there really isn't much to see. It is stock leather interior with some wear on the outer seat bolsters. I have been debating on whether to reupholster the stock seats or go to the effort of installing new seats with a lower height since I'm 6'1". It is in excellent condition though. No cracks or stained carpeting, etc.
09-18-2014, 02:27 PM | #30 |
Hey Darius... Gorgeous Car!!!.. I have cash in hand (just sold my last toy, a pristine, numbers matching, 1969 Firebird, yesterday), not making a low ball offer. But, if you are serious about selling it, Give me a shout.. I'd like to talk some numbers.
Im really leaning heavily on going with a new S-Chassis car... last time I had a very nice S13, this time, it would have to be an S14... Does it have a clean title? any rust? AC hooked up? Did you retain the power steering? Any interior photos? My phone number is 540-921-7355... shoot me a text. Im very interested.. Like I said, Cash in hand.. not a tire kicker
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575 |
240sx, for sale, rb25, s14, swap |
