05-09-2018, 06:35 PM | #1 |
KA24E wiring harness problem?
Was cleaning my MAF today and put it all back together and after it had trouble idling. Wouldn't go over 2500 RPMs. So I went back an noticed if I wiggle my wiring harness around it has trouble idling. What would be the best route to take on this? I have no experience doing any harness swaps, or putting a new one in. Think if I bought a new maf pigtail/plug and just rewire it that would work?
Let me know what you guys think Thank you VIDEO LINK https://www.youtube.com/watch?v=YyTIs32vZKw 1990 240sx |
05-13-2018, 08:36 PM | #2 |
If it won't go over 2500 RPMS, it's the MAF. Since it worked before, likely wiring.
You need to determine where the break is in the wires. Is it right at the plug? You may need to get a razor blade and peel back the loom and look at the wires to see where the problem is, then just replace the broken section. If it is broken at the plug, then yeah get a pigtail and wire it up!
5.3 V8 Swap w/ Nitrous |
05-14-2018, 12:05 AM | #3 | |
05-14-2018, 08:58 AM | #4 |
Should be an easy fix! You can see the wires pulling out of the pins inside the plastic connector in your video. Get a new maf pigtail, and splice it into your harness. Make sure you solder it and heat shrink it.
Good Luck Next time please post questions like this in the small questions thread. Won't let me embed the link for some reason but here is the url: http://zilvia.net/f/showthread.php?t=297481
(づ。◕‿‿◕。)づ T E A M B L O O M |
05-16-2018, 12:57 AM | #5 | |
