Old 06-17-2018, 03:13 PM   #1
rob_240
rob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the rough
Garrett t3 stage 3 550 hp turbo brand new
Brand new turbo. It's been sitting on the motor for 2 years hasn't been ran. Fins in the housing are in great shape no wear. And clean. Garrett turbo number is 715583-5007
Comes with lines
Turbine housing is ceramic coated black.
Info
This turbo will flow enough for 550 HP. 100% genuine Garrett T3/60-1 (T04S) Hybrid Turbo charger. High Flow StageIII turbine wheel with your pick of turbine housing & A/R. Large T04S (60-1) compressor snail with 4.00 inlet and 2.50" outlet. An outstanding turbo for 4, 6 & 8 cylinder engines using a T3 exhaust manifold that require up to 550 horsepower. Comp housing is available with ported anti-surge & polished upgrade options. This turbo will provide more power then any T3/T04E turbo.
Compressor Wheel: 60-1 T04S*
Compressor Housing A/R: .70 A/R*
Compressor Housing: T04S with 4" inlet & 2.5" outlet*
Ported Anti-surge housing option?: Yes*
Polished Housing Option?: Yes
Turbine Wheel: T3 Stage III*
Turbine Housing options are:*
- T3 undivided w/ 4 Bolt discharge, .48 A/R (Use external wastegate)*
- T3 undivided w/ 5 Bolt downpipe discharge, .63 & .82 A/R (Use Internal or external wastegate)*
- T3 divided w/ 3" V-band discharge, .78 A/R (Use external wastegate)*
- T3 w/ special Cosworth 3 bolt downpipe discharge, .72 A/R only.*
- T25 Special, .72 A/R (Use Tial 44mm wastegate)
Center Section:*
- Oil cooled (no water lines needed)*
- Rebuildable Journal Bearing
600$
Call/text 714 260 1467
Sent from my SM-G930V using Tapatalk
rob_240 is offline   Reply With Quote
Old 06-20-2018, 06:25 PM   #2
rob_240
Still have the turbo
Old 06-23-2018, 08:31 AM   #3
rob_240
Weekend bump
Old 07-03-2018, 08:23 PM   #4
rob_240
still available
Old 07-08-2018, 11:56 AM   #5
rob_240
turbo still available
Old 07-14-2018, 09:46 PM   #6
rob_240
to the top
Old 07-22-2018, 11:12 AM   #7
rob_240
still available
Old 08-11-2018, 10:58 AM   #8
rob_240
Weekend bump
Old 08-21-2018, 08:27 PM   #9
rob_240
price drop 600$
Old 08-23-2018, 06:56 PM   #10
theskidmasta
theskidmasta's Avatar
theskidmasta is an unknown quantity at this point
check yo PM
theskidmasta is offline   Reply With Quote
Old 09-16-2018, 11:43 AM   #11
rob_240
still available, moving at the end of the month and like to unload all my parts
Old 12-13-2018, 12:19 AM   #12
rob_240
still have this
Old 01-06-2019, 07:04 PM   #13
rob_240
bump still have the turbo and updated price
Old 01-28-2019, 10:26 PM   #14
rob_240
price update
