Old 05-09-2018, 06:35 PM   #1
ParkerVX
ParkerVX's Avatar
ParkerVX is an unknown quantity at this point
KA24E wiring harness problem?
Was cleaning my MAF today and put it all back together and after it had trouble idling. Wouldn't go over 2500 RPMs. So I went back an noticed if I wiggle my wiring harness around it has trouble idling. What would be the best route to take on this? I have no experience doing any harness swaps, or putting a new one in. Think if I bought a new maf pigtail/plug and just rewire it that would work?
Let me know what you guys think
Thank you
VIDEO LINK https://www.youtube.com/watch?v=YyTIs32vZKw
1990 240sx
ParkerVX is offline   Reply With Quote
Old 05-13-2018, 08:36 PM   #2
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
If it won't go over 2500 RPMS, it's the MAF. Since it worked before, likely wiring.
You need to determine where the break is in the wires. Is it right at the plug? You may need to get a razor blade and peel back the loom and look at the wires to see where the problem is, then just replace the broken section.
If it is broken at the plug, then yeah get a pigtail and wire it up!
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 05-14-2018, 12:05 AM   #3
ParkerVX
ParkerVX's Avatar
yea I wiggled it around and it fixed the 2500 rpm problem. I have yet to take it a part. Need a full day that I know I won't be doing any driving haha. Its the wires leading into the pigtail plug. Should be easy to fix (i hope) never done splicing or any rewiring but was watching a few videos.
Old 05-14-2018, 08:58 AM   #4
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Should be an easy fix! You can see the wires pulling out of the pins inside the plastic connector in your video. Get a new maf pigtail, and splice it into your harness. Make sure you solder it and heat shrink it.
Good Luck
Next time please post questions like this in the small questions thread.
Won't let me embed the link for some reason but here is the url:
http://zilvia.net/f/showthread.php?t=297481
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 05-16-2018, 12:57 AM   #5
ParkerVX
ParkerVX's Avatar
Good Luck
thanks for the help. Going to order one and give it a try. Sorry about the wrong section, thanks for the help once again!
