Old 10-18-2018, 01:50 PM   #1
j-z
j-z has a spectacular aura aboutj-z has a spectacular aura aboutj-z has a spectacular aura aboutj-z has a spectacular aura aboutj-z has a spectacular aura aboutj-z has a spectacular aura about
MANY S14 parts and a few 1JZ z32 parts 350 pics!!
https://photos.app.goo.gl/8H76aNagukyhDyLS6
PHOTO LINK ^^^^
Contact 407 600 3884
Hi, Im selling the rest of my 240 parts. I took alot of time going through every single part to list everything accurately and have atleast one pic of each item in the photo album above. I also started to list some of the items on ebay under my username srfrjz3.
I will ship any item. Payment preferred is paypal. Handling time is no more than one day, and shipped priority. Im willing to work with you as having these parts laying around is doing nothing for me.
I have 350 pics and there is absolutely no way I can link each one into this thread. If theres an issue please dont hesitate to contact me. Heres a pic of the latest pic I posted on my IG account @nicetime_racing
Text 407 600 3884
s14 manual 5 speed transmission no grinds with sensors $300
s14 manual 5 speed transmission no grinds with no sensors $250
ka24de/sr20det b&m short shifter $200
s14 manual transmission crossmember $80
s14 manual transmission 5 speed ABS driveshaft $200
ka24de/sr20det shifter gaskets $10 each
ka24de clutch fork/new throw out bearing/pilot bushing $50
-z32 oem 5 spd crossmember $50
-z32 oem shifter bracket $40
-s14 oem ka24de cams $40
-s14 abs master cylinder $60
-s14 abs pump w/lines $70
-s14 oem amber front bumper marker lights $35
-ka24de alternator $45
-S14 fuel pump harness/rear panel/body harness/wire harness $50
-S14 rear body/speaker harness $50
-S14 power steering reservoir $40
-S13/S14 upper radiator mount brackets $30
-S14 apillar tweeters $30
-S14 lower radiator valance $25
s13 trunk release handle $25
s14 front sway bar brackets $35
s14 front sway bar $40
s14 SE rear sway bar with endlinks $100
s14 passenger side door belt molding $60
s14 driver side door belt molding $60
s14 passenger side window seal $60
s14 driver side window seal $60
s14 passenger side pinch weld molding $30
s14 driver side pinch weld molding $30
s14 trunk seal molding $60
s14 speaker amp $25
s14 brake booster hardline that mounts to firewall $20
s14 passenger mirror interior cover trim $10
s14 driver mirror interior cover trim $10
s14 cruise control actuator $30
s14 fuel tank straps $60
s14 trunk breather $25
ka24de ac compressor mount bracket $35
s14 hood prop rod $35
s13 steering column switch piece $25
s14 right trunk hinge $40
s14 left trunk hinge $40
s14 hood sensor $30
s14 rear seat mounts $25
s14 black seat belt cover trim $10 each
s14 gas filler neck $80
s14 jack holding bracket in trunk $30
s13/s14 oem front spring top hats $40
s14 rear top strut sound insulator $20
ka stock shifter $10
s14 steering column firewall flange insulator $30
s14 dead pedal $20
ka24de power steering pump bracket $40
s14 gas pedal stop cover $20
s14 intake manifold bracket $25
s13/s14 front bumpstops/dustboots $30
ka24de oil filter housing $25
s14 smart entrance box $30
s14 18930 70f01 $30
s14 cat heat shield $30
s14 trunk release cable $75
s14 tranny hump harness $30
s14 antenna cable $30
s14 left door window track guides $35
s14 right door window track guide $35
s14 lower left valance pinch weld 5.5'' up cut from pinchweld $100
s14 lower right valance pinch weld 5.5'' up cut from pinchweld $100
s14 right front white plastic harness through trim $20
s14/s13 radiator/condensor mount bracket $30
s13/s14 tranny breather $15
s13/s14 power steering hose bracket $25
-s13/14 OEM Mechanical fan shroud $25
-s14 complete cruise control system $60
-s14 power mirror switch 1996 $20
-s14 Rear bumper rebar $60
-s14 rear window lower metal trim $75
-ka24de PCV valve box (bolts to front cover) $15
-10 oem wheel studs $1 each
-horn x3 $5each
-s14 OEM fuel hardlines no rust $50
-s14 OEM front brake hardlines $25 each
-s14 OEM third brake hardline for rears $25
-s14 OEM dash bar $50
-s14 rear brake calipers with braided lines $100
j-z is offline   Reply With Quote
Old 10-18-2018, 02:16 PM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Thanks for the stuff.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 10-18-2018, 02:36 PM   #3
j-z
glovebox and keytrim rings sold
Old 10-18-2018, 09:33 PM   #4
Napalm
Napalm is an unknown quantity at this point
Texted-3526671532
Kouki in progresss
Napalm is offline   Reply With Quote
Old 10-22-2018, 05:28 PM   #5
j-z
S13 ECU is SOLD
Old 10-22-2018, 07:18 PM   #6
Mooch
Mooch is an unknown quantity at this point
S14 5 speed shifter surround plastics?
Mooch is offline   Reply With Quote
Old 10-24-2018, 12:17 PM   #7
j-z
Power steering pump is SOLD and SHIPPED. Thanks for the feeback!
Old 10-24-2018, 12:46 PM   #8
afishysilvia
Trader Rating: (31)
Got parts last night, thanks for the free colored pencil haha. Bump for fast seller.
Old 10-24-2018, 07:28 PM   #9
j-z
HAHA that's awesome. If it was the blue one it's my daughters and I'm going to have to ask for it back...
jk! Enjoi!
Old 10-26-2018, 07:19 AM   #10
j-z
Stock manifold is gone!
Old 10-30-2018, 09:59 AM   #11
j-z
Climate control shipped and sold.
Old 11-02-2018, 09:49 AM   #12
j-z
Fuel filter holder sold and shipped!
Upper alternator bracket sold and shipped!
Throttle body sold and shipped!
Thanks guys for making this so easy on me!
Old 11-05-2018, 08:19 AM   #13
j-z
I'm adding a black s14 gauge cluster surround in. $60 shipped has working cruise button and has three stick on gauge pods located on it as well that can be taken off.
Greddy front strut bar $120 shipped check link for pics
starter
alternator
check link for pics and first post for anything else
Old 11-09-2018, 11:22 AM   #14
j-z
Anyone need anything quickly?
Old 11-10-2018, 04:14 PM   #15
j-z
S13 Distributor sold and shipped
Old 11-19-2018, 04:59 AM   #16
j-z
Blower motor shipped and sold
Old 11-26-2018, 05:46 AM   #17
j-z
wiper switch sold and shipped
Old 11-26-2018, 04:01 PM   #18
JacksonBrown
JacksonBrown's Avatar
JacksonBrown is an unknown quantity at this point
Hi,
Regarding the 'SE passenger side A pillar cover $30'
What year S14 is this out of?
With tweeter cover? (I'm pretty sure all SE had tweeter covers)
What color? (black I'm assuming?)
Condition of clips?
Thanks in advance,
JacksonBrown is offline   Reply With Quote
Old 11-26-2018, 04:39 PM   #19
j-z
Its black in good condition. Came out of my 96 se. Yes has tweeter cover. Clips are there. I think I took a pic of this. Let me check.
Old 11-26-2018, 04:43 PM   #20
j-z
If you want it, I can send you a pic tomorrow. Just send me a text so I know where to send it.
Old 12-12-2018, 08:41 AM   #21
j-z
I've sold a few things since my last update.
SOLD
greddy front strut bar
hood release cable
1jz ecu
1jz wire harness
wiper switch
front frame rails
wiper amp
steering column tilt lever
Old 12-18-2018, 08:56 AM   #22
j-z
Right mirror is sold and shipped
Old 12-26-2018, 08:26 PM   #23
j-z
Now selling complete front z32 brake setup with 30mm aluminum calipers, 5x114 z32 rotors, s chassis stainless braided lines, hawk dtc60 pads, and autozone pads.
$250 shipping is on you
Old 12-31-2018, 06:36 AM   #24
j-z
Still have heater core and complete oem radiator setup available (ac fan,shroud, hoses). Also I have all door seals, and molding available too in great condition.
Old 01-07-2019, 07:14 AM   #25
j-z
ALL JZ parts are sold.
Still have alot of stuff up for grabs.
Z32 brakes with swap lines, pads, and rotors $250
Old 01-11-2019, 07:02 AM   #26
j-z
I also have everything windshield wiper related available too! minus the amp box.
Old 01-17-2019, 09:04 AM   #27
j-z
I have non rusted fuel tank straps in great condition along with chassis oem fuel hardline.
Keep in mind I have all door weather stripping and moldings in great condition!
Just sold an IACV. I have one more if anyone needs one! Lets get this stuff out of my hair
Old 01-21-2019, 07:27 AM   #28
j-z
It's cold here in florida. I know someone has a busted ass heater core. Take this one!
Old 01-21-2019, 08:15 PM   #29
madsipp
madsipp's Avatar
madsipp is an unknown quantity at this point
Do you have s14 passenger door lock actuator by any chance?
madsipp is offline   Reply With Quote
Old 01-22-2019, 08:25 AM   #30
j-z
@madsipp
I don't at the moment.
