09-22-2014, 12:00 PM | #3 |
So according to my searches of I get a -3an line I don't need a restrictor, If I get a -4an line I need a 0.40 restrictor, so Wich lines in the market offer -3 or -4 an lines?
Sent from my iPhone using Tapatalk |
09-22-2014, 12:09 PM | #4 |
Ok to answer your main question on if that's a built in Restrictor then no.as for the -3 or -4 lines changing anything I'm not 100% sure but I do know they require .03" restrictors.
Instagram username:angelmkiv |
09-22-2014, 01:33 PM | #9 |
Trader Rating: (25)
Feedback Score: 25 reviews
1.not a built in restrictor,
2.you need a .030"restrictor for the 2871r 3.looks like someone threw some jacks in there heyyyyoooooooooooooooo
@andymcfly |
09-25-2014, 07:09 PM | #11 | |
As for a restrictor, not sure if that is a built in one, but if you do have to run one, I recommend DIF's 0.040" restrictor. |
09-25-2014, 07:26 PM | #12 |
I was going with the dif lines and restrictor, turbo has a barley noticeable shaft play, Wich basically every ball bearing turbo has, I blow into the charger pipe of the cold side and the blades spin, even with the softest blow of air with my mouth so I'm guessing turbo is good
09-28-2014, 10:15 PM | #14 |
My turbo shop said, built in restrictor in my 3071R, however that's for 4 Bar oil pressure, a jap engine makes far far more than that!
OakHeart Racing |
