11-23-2017, 07:37 PM | #1 |
600+whp 1jz S14
SOLD!!!!
VIN:jn1as44d2tw052284 Up For sale is my 1996 240sx I have this car for almost 11 years and have gone through various setups. The goal was always high response and minimal lag. the car will come with 3 different Twin scroll housings the biggest one is on the car now and will do 700hp on race gas. as it sits now its making 606rwhp on E85 with the 1000cc injectors maxed out at 28psi. The paint on the car is new, the tires are new, the A/C works but needs a charge. the acceleration on this is incredibly breath taking thanks to the 4.63 final drive with Twin scroll Turbo. it is especially crazy with the smallest turbine housing, downright scary. Sunroof works and doesn't leak, all windows work, interior is great for its age, brakes have only seen Porsche Blue ATE DOT 4 brake fluid, Rear end uses Motul oil, Motor only uses Valvoline racing oil and the trans uses Redline mt90. the car has never been in an accident, no rust will throw in Drag radials for $200 more. If You have any other questions fees free to ask. Chassis: Clean title 160K 1996 German Glass Headlights All Polyurethane Bushings Hood vents from water jetting Carbon Fiber Bumper (painted over) Fresh paint Aero bumper Cover Tockico 5 way struts Staggered 18x11 and 18x9 wheels with new tires s15 LSD with custom 4.63 Final Drive and J30 Axles Engine 600+hp 1jz (freshly built, new pumps, bearings and rings) 2JZ-GTE USDM Cams Upgraded intake and TB Custom twin scroll manifold (Ceramic Coated) Dual Tial 38mm gates Holset HX35/40 hybrid (ceramic coated and three housings) Breather system Transmission Driftmotion built R154 with all available Marlin Crawler parts Custom catch can for the trans Southbend custom Fullface clutch with 3200 lb plate New OEM Flywheel New slave cylinder Redline mt90 Brakes: Z32 Aluminium Calipers on front with custom brackets for 12.8” rotors Two piece 12.8” rotors Custom z32 rotors and aluminum rear calipers with working e-brake New master cylinder Fuel: Bosch 1000cc Injectors Walbro 450LPH in tank Twin Bosch 044 in surge tank Dual -6 E85 lines -8 return Exhaust: Full 3” with Bootlogic cutout Dual Magnaflow inlines Last muffler is an Australian brand (total of three mufflers) Engine management: Stinger Custom wiring harness 12k OBO Last edited by Boostage; 12-08-2017 at 06:01 AM.. |
12-08-2017, 12:04 AM | #6 |
sad to see you finally put it up for sale man. whats next then?
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s |
