03-26-2015, 07:50 PM | #1 |
Trader Rating: (24)
Feedback Score: 24 reviews
R32 GTR diff in s13
Has anyone ever installed an r32 gtr diff in an s13 subframe ?
I heard it's like the q45 so you'd use a q45 and a z32 tt axle with gtr/z32tt/q45 hubs. Swap the rear cover from GTR to S13 But what about the input shaft ? can I just swap an s13 one in and bolt up my driveshaft ? gtr input shaft for reference |
03-27-2015, 04:34 PM | #4 |
how about a j30??
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
03-28-2015, 07:17 PM | #6 |
Just replace the diff input shaft with the S13 diff input shaft, that's it .. by the way you need to use a torque wrench for that so that you don't damage pinion by over tighten the input shaft nut
03-29-2015, 05:26 AM | #10 |
It is. Output shafts splines are bigger as well as axles
06-06-2015, 02:22 PM | #13 | |
Trader Rating: (24)
Well, i tried to swap the input shafts and it won't work. The splines are bigger on the gtr diff and so is the nut. What should I do now, since I won't be able to bolt up an s13 4 bolt driveshaft ? Get a driveshaft made with a gtr yoke ? Sent from my iPhone using Tapatalk |
06-09-2015, 04:03 PM | #16 |
I'm not 100% on this as I have never personally done it but you may have to follow the same steps as if you had an early model Q45 diff...
http://forums.nicoclub.com/install-g...e-t267924.html
06-09-2015, 07:36 PM | #17 | |
Trader Rating: (24)
That's actually the guide I was going by! Thanks for the input I measurar the gear inside and it turns out it's an R230 with a 3.69 which makes it a z32 tt diff. Looks like I need to have a talk with the person who sold this to me and wasted my time Thanks for the input everyone! Much appreciated Sent from my iPhone using Tapatalk |
