Old 09-01-2018, 09:56 AM   #1
Palombo
Palombo is an unknown quantity at this point
Smile 91 R32 Skyline Gts-T (forged motor)
This is the basic run down, I’ll update anything as I remember
1991 Nissan Skyline GTS-T
Engine- 97 R33 RB25DET (S2)
Trans- 91 300zx tt 5spd with RB25 bellhousing
Mileage on the cluster-166,821km
Mileage on current motor build-4000km~
310hp, 275tq @11psi, very light tune
El Paso, TX
Adult driven
**NO TRADES PLEASE**
25k obo, I have more then 28 into the car.
Up for sale is my R32, I have had the car for 2 ,almost 3, Year’s now. I love it. I’m in no rush to sell. Just have my eyes on another style of vehicle and would like to try that one out. I have no mechanical issues with it currently. It is a old car so keep that in mind. This car is daily driven and has never left me stranded. R&R of the motor and trans was done by myself and some trusted buddies. All machine work was done by me or my boss at my work. I have a lot of pics of the build process so those are available upon request. Car does NOT have AC/heat currently. Heater core cracked on outside of firewall and have just been to lazy to replace since it’s summer so I just bypassed it lol. I removed AC system in the bay because race car lol. Also doesn’t bother me. Car does have some flaws. Driver seat is torn from getting in and out(purchased like that), rear glass seal is starting to curl in on the top edges from heat (applied some black rtv as quick fix), doors have no speaker grills(not big deal just bugs me) .If the car does not sell I will just keep building it. But any mods are on hold while I finish another project.
I will update list if I remember anything else
Engine mods
-CP Forged Pistons (+.5mm/.020)
-H Beam RB26Manley Rods
-King main/rod bearings (std/std)
-ARP head/main studs
-Tomei Head Gasket (1.2mm)
-Oem Gasket set
-Arashi 20G Billet Turbo
-Greddy Type FV bov
-Silione vacuum lines
-deleted PCV grommet for fitting
-Hydro-dipped valve covers/intake/timing covers
-Spline Drive oil pump upgrade
-N1 Water and Oil Pumps
-Tomei oil orifice restrictor in block (x1)
-Nismo Thermostat
-Fresh Pilot bushing
-Nismo motor Mounts
-Rebuilt stock Cylinder head (done by me personally)
-Oil clearances are (.0015-.002) rods/mains
-New fan clutch (600miles)
-New Belts (500miles)
-Spec 3+ Clutch
-Resurfaced Flywheel
-Oil filter sandwich plate
-Raw Brokerage oil filter stud direct to Block
-Raw brokerage exhaust manifold stud kit
-Pancake downpipe with custom side exit exhaust (3in straight pipe)
-Fully wrapped exhaust and turbo blanket
Machine work performed (Dec 2017)
-Balanced rotating assembly (have balance report)
-Bored/Honed/ Plateau finished (diamond stones used)
-Decked Block (.004)
-Resurfaced Cylinder Head (.003)
-Cylinder head ——New stem seals(oem), 3 angle valve job, light port and polish, clean and drained lifters, polished cams and cam journals)
-Head and Block Soda blasted and acid Washed
-Installed ARP Main Studs—-Verified Line bore within spec
-Install ARP Headstuds
-Cut Crank for Spline Drive installation
-Clean and Mirco-polish crankshaft
-Long Block assembled by me
-Still have arp bolt boxes for any warranty claims*
Suspension
-D-max D1 drift spring coilovers
-Hicas Delete Driftworks
Transmission
-91 300zx TT 5 Spd
-Rb25det bellhousing
-Megan trans mount
-rb25det oem slave cylinder
-Spec 3+ clutch (Rb25det)
-New OEM Rb25det pivotball
-Xcessive Manufacturing shifter relocation kit
-300zx external shifter
-One piece driveshaft- made locally
Misc
-AEM boost,wide band, oil pressure gauges
-GTR steering wheel
-turbo timer( came with car,works great) unsure brand
-New door window trim/seals(will be installing this weekend)
-17x9 STR wheels all around
-uncut GTR key
-Car is wrapped,original color is black(have extra wrap left still)
-Burnt Titanium Dress up bolts engine bay kit
-Silicone vacuum lines
**just went and had injectors cleaned and flow tested yesterday
- I’m also changing the rear diff fluid after I post this lol
-Also have a set of R8 coils packs encrypted to upgrade stockers
File Type: jpeg 404EAE21-986D-4ED2-8CBE-2539553C77FE.jpeg (208.7 KB, 554 views)
File Type: jpeg 3629EE9A-F394-4F95-8B8D-F8CEC6F193AC.jpeg (73.7 KB, 342 views)
Palombo is offline   Reply With Quote
Old 09-01-2018, 09:59 AM   #2
Palombo
Thumbs up
I can’t seem to post more photos, so you can see plenty on my Instagram! @finallyrhd
Thanks
Old 09-01-2018, 10:32 AM   #3
Palombo
Also can txt photos and dyno videos upon request���� 386-466-9890
Old 09-01-2018, 02:00 PM   #4
AlwaysHungry
AlwaysHungry is a well-known jackass
i don't see a price unless I'm probably dumb/
Edit: 25k gotcha
AlwaysHungry is offline   Reply With Quote
Old 09-01-2018, 04:50 PM   #5
Palombo
25k “obo”
Old 09-03-2018, 12:33 AM   #6
Palombo
Bumpppppppppppp
Old 09-04-2018, 12:36 PM   #7
Palombo
Just had the injectors cleaned and flow tested, car is loving fresh injectors
Old 09-07-2018, 12:22 PM   #8
Palombo
Bump
Old 09-19-2018, 05:35 PM   #9
Palombo
Made some updates to the car still.
AUDI R8 coils, and a CF GT wing.
File Type: jpg B95AD00F-2C69-483F-8097-57DAB0549B17.jpg (295.4 KB, 57 views)
Old 09-25-2018, 06:27 PM   #10
Palombo
**Any serious offer will be considered ***
I was attempting to upload photos from the car show this weekend but I don’t have a small enough file 🤷🏼*♂️🤦🏼*♂️ O well
Old 09-25-2018, 07:16 PM   #11
Palombo
All the picture from the car show are too large of files sadly... zzz
^^^im open to any serious offers^^^
Old 09-26-2018, 01:06 PM   #12
Palombo
** price drop 22.5k**
Old 09-27-2018, 09:45 PM   #13
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
I wonder what I could sell mine for
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
