Old 10-18-2017, 03:55 PM   #1
roadsterruss
roadsterruss is an unknown quantity at this point
1989 White GTUs streetable race car, fresh 13b-re N/a engine, eproduction+ suspension
This is my Fourth Rx-7 between 2 GTUs’s and 2 FD’s. I’ve owned her for twelve years, and I am the third owner. The first owner was a very strict Japanese business man, who would only have it serviced by Japanese shops. When he accepted a job in Japan, he would only sell it to another Japanese man. When the job fell through, he tried to repurchase it back from the second owner, but the second owner refused. I was lucky enough to know the second owner through a friend, and although he was apprehensive selling it, and still regrets it to this day (now drives an rx8), I bought it from him for a heavy premium of $8,000 in 2003ish. His name is Daisuke from socal if anyone remembers him-very authentic collector.
This car has never been crashed, or raced wheel to wheel. Is got a perfect frame and excellent body, and I only have put about 14,000 miles on it in the last twelve +years, about 10k as a daily when i first got it. I’ve collected parts for a decade for this car, it’s a specialty car that deserves a good home. This is for a connoisseur who loves retro/vintage/classic raw rotary Mazdas, and who like the idea of a built from the ground up car without wanting to dump the time, huge money, and effort into building it themselves. Buying this car could literally save you years toward your goal and lots of money. It's also been garaged its entire life up until about 2 months ago, which is part of the reason i think its time to sell it.
Also, registration, insurance, and parts are cheaper for the FC than other cars, which helps with maintenance and upkeep. This is one of the last and best naturally aspirated rotaries to come out from the golden days of racing. Its meant to drive to the track with current tags, have a great day, and drive home. Its also meant to sit in a garage and be admired like the queen it is.
It’s an authentic 1989 GTUs, one of 1200 built between 89-90, in white. The GTUs was a very special car that came with NO SUNROOF, speed (vs standard rev) sensing steering, a closer steering ratio lock to lock, shorter competition 5th gear, 4.3 final drive, manual everything/no rear wiper, alum hood, special interior, etc. etc. The GTUs community is a sub division of the Rx-7 community, consisting of wing-nuts and die-hard collectors.
Because it’s a GTUs and not a Turbo II, I wanted to focus on the chassis, and my specialty, the suspension. A lot of Turbo FC’s drop in a high power motor and rely on that for speed, while ignoring the suspension and chassis overall. Because this stylistic focus, this car harps to an earlier era of purist racing, and is comparable to an E-Production car like AWR or Mazdatrix- except this still has a plate and is way more streetable. I think it would run Unlimited in Autocross, as well.
ENGINE
BRAND NEW 13B-RE COSMO rebuilt race motor, currently with N/A high compression internals, driven home from Lucky 7’s and unused!! GTORX-7 build replica, pumped out 216w on turbo rotors, now has NA rotors and GTORX7 LIM to match. built by fris @ lucky 7 racing. this engine is about as fast as a twin turbo stock fd with exhaust. its really the best a 2 rotor mild streetport can do without boost. it screams to redline really well and will never bog down like a 6 port. never loses torque or power past 7500-8k, just keeps climbing.
haltech sprint re computer tuned by daniel kuo with garagelife
Chopped lower intake 1 ¾ inch from GTORx-7 to follow his build making 236whp with the N/A cosmo streetport. improves high end torque and makes sure the HP keeps climbing to redline. (this mod was $750+shipping alone)
tii ported exhaust ports. new alum housings.
Custom LIM and Throttle body heat shield with gold adhesive, since the LIM is closer to the block
independent AEM coil packs
silicon radiator hoses from racing beat
knn cone intake filter with MAF deletion
comes with resonated midpipe AND bonez catalytic converter, currently resonated midpipe on car
stock exhaust manifold with rb downpipe. this gives the same power as the RB header but much less noise. sounds extremely smooth and great. helps tone down the exhaust for cali streets.
GREDDY POWER EXTREME DUAL STAINLESS EXHAUST
Aftermarket Fuel rails
New RC injector 750 primaries
New Injector Dynamics 850 secondaries
Custom SS fuel lines
Fuel pressure Regulator
Supra Fuel Pump
Custom air intake elbow
mild street port, sounds smooth but makes a shitload of power. about as fast as stock twin fd with exhaust.
fluidyne radiator, new rad cap
OMP delete
Fd oil pressure pellet
Solid corner seals
Mazda comp rotor bearings
Oil pan baffle
Fd oil pump
TII exhaust sleeves- ported
Delete coolant through throttle for coldstart
Red and silver painted engine/manifolds
AC/SMOG delete
Air Pump Delete
SS oil cooler lines
Dual Oil Coolers
New spark plug wires
Electric fan
S4 coolant overflow tank
CF radiator cowl panel
KNN Cone filter
Air Fuel Meter Delete
FD Alternator, under driven pulley custom lathed
pulley underdrive kit with alum pulleys on main pulley, coolant, alt, and PS
Thermostat/housing replaced
Water pump replaced
Coldstart pellet removed
New fuel filter
SUSPENSION
this car can turn 90 degrees at 45-55mph on a pivot. pushing on the frame it does not budge more than the sidewall flex as there is ZERO rubber between you and the tire. this car is the ultimate in FC suspension. i made sure of it.
*JRZ MOTON triple adjustable shocks w/ external reservoirs imported from the Netherlands. Valved by Eric Strass of JRZ for medium weight. These shocks were about $8600 new. I spent my entire life's savings at 20 years old on these shocks, and paid more for them than the entire car. They have millions of possible configurations and are very reliable. Custom mounted reservoirs w/ quick disconnect feature. i could roll over a quarter, not feel it, and tell you if it was heads or tails.
full partsbymax front suspension control arms, drop knuckles, and steering rack spacers. this fixes roll center, bump steer, makes you have huge angle, changes ackerman steering angles. moves front wheels forward 15mm and extends the track out 3 inches total on the front axle. the front wheels are about an inch further out than the back wheels, having that string ray affect with both looks and handling.
KSP alluminum billet front hubs with new bearings
aftermarket hardened steel tie rods (forgot who makes them but theyre totally badass)
Both front and rear subframes are new, acid dipped, stitch welded, and powder coated Barron Red.
Rear subframe solidly mounted to frame with AWR mounts
DTSS solid bearings
polyurethane steering rack bushings
Rear control arms are acid bathed, stitch welded, and coated black (much stronger than stock)
roninspeed camber links
Solid Ground Control lateral camber link
ground control top hats
New steering rack ball joints
New steering rack boots
Rebuilt steering rack, quicker lock to lock faster ratio than FD3s
Ground control camber caster front shock top hats w/ bearings
Hypercoil springs with amazing spring rates (E Production rates that have been confirmed to be the best for the chassis by Mazdatrix and AWR and Mariah) (also hypercoil’s tolerance is much more accurate than eibach, eibach can be off by more than 100 pounds per spring, or 10%)
Rear helper springs
Rear shock towers have been chopped and replaced with boxes that tie into the cage (stock shock towers are bad in rear). the cage goes down into the subframe and has feet at every contact point. it also has plates welded between the cage and the frame. one of the best cages ive seen on a rx7.
Pillowball endlinks
ZERO front swaybar and TII rear swabar. makes you go faster but you cant be absent minded as the front wheels are unteathered.
New wheel bearings
front old school racing beat strut bar
DRIVETRAIN
Miata type I torsen differential, mazdacomp rebuild kit hardened and zinc coated worm gears (good for up to 350hp using PP or turbo)
4.3 finals
Low miles JDM tii trans (shortest 5th just like GTUs), this is the best feeling trans ive ever felt in my life, hands down. Youll giggle when you shift.
OG giken twin plate turbo clutch and flywheel package.
C’s short shifter (discontinued)
Full solid mounted drivetrain including engine, trans, and diff
New trans seals
New shifter bushings
New axle bolts
New clutch master cyl
New slave solenoid
CC clutch line SS braided
Replaced starter but it wants a tII starter on the new trans
Custom TII trans to NA diff driveshaft
Redline fluids
Due to the solid mounts and cage, you can hear the gears harmonics like straight cut gears and you can hear the torsen doing some work, sounds really raw. really cool sound.
BRAKING
NO ABS!!
Rebuilt 4 pot calipers
New rotors
SS lines with Teflon coating
New brake booster
New master cyl
Master cyl brace so no flex in system (omg such a great mod)
Hawk HP+ pads
Brake pedal adjusted to be super touchy, stops on a dime, can lock on command
Mazda comp aluminum pedal set, factory with gtus
Power bled brakes
INTERIOR
Seven’s Only Racing 6 point cage. These guys make their own tube frame RX's. fully integrated/boxed rear towers with built in strut bar. Has two down bars, two diagonals (including main hoop), X door braces, and excellent feet that go all the way down into the chassis and tie to the subframe. This cage took sevens only a year to finish, and costed a walloping 6800. Seven’s only is a tube frame rx7 builder up at buttonwillow racetrack, located on the track premises. This cage was built out of steel to handle the car being cosmo turbo one day, able to take 8+ rolls. A and B pillars have plates welded in to connect the chassis to the cage. Custom shock reservoir mounts.
Sparco evo seats with custom mounting brackets and custom rails, stock floor pan humps chopped to allow lower seating. Rails adjust with pull pin release. Sparco 5 point quick release harnesses
Odyssey PC680 15 pound battery custom mounted behind passanger seat with cutoff switch on driver side dash.
Momo steering wheel, leather, tiny.
IMPUL horn button
IMPUL shift knob
forum member made triple gauge cluster replacing idiot cluster
Custom racing mirror mounted to cage
Fully gutted interior, gutted dash, no sound deadening whatsoever
lexan windows with slide windows for air flow and communications
Gutted doors with t3 door cards
New windsheild
Heater core removed under dash
foam filled chassis for added rigidity.
EXTERIOR
mariah mode 5 front bumper. this front bumper adds another layer of intake for the radiator and engine. it also adds a cowl to the front to help get air to the radiator correctly. it deletes the FTPS and is one of the few, if not only, front bumper that was wind tunnel tested. and its a really cool looking american front bumper. high high high quality and gives a jet plane look straight out of the 80's.
re amemiya tii hood vent
roninspeed 85mm front fenders.
Panspeed rear fenders
JRX wangan wing
10ae taillights
Eastbear mirrors
jdm sidemarkers
Replaced door handle gaskets
Repainted body- front clip needs a spray
Hella h4 bulbs/housings, best halogen fc lights ive seen. ive had the option to go with sakebomb hids and these do better and are less problematic. had hids on my fd and it was a deal breaker in the end..
Windshield wipers/motor
WHEELS AND TIRES
IMPUL c1 silhouette wheels. 17x9 +23 from the calsonic JGTC nissian skyline. They're worth 2k used and a appreciable collector wheel. Time period correct turbo style with cnc contoured concave face. Over 20 spokes, center cap and nut to cover lugs and prevent theft, 2 inch lips with no rash. Imported from Australia. Only a few sets in the world and fewer of this kickss modern size and offset. 2 pc wheels plus center dish and nut.
OR
ADVAN R3AD's 17x9.5 3 spoke wheels in white with blue lip. 19 pounds.
255 ra1 tires
everything on this car has less than 4k miles on it. the engine has literally zero miles. i brought it home and didnt drive it. i can easily rattle off 40+ grand of parts off the top of my head, let alone labor. car was built, not driven, and now is beyond California street law. im getting older with back pain and want something thats got an interior. would consider s13 coupe, ae86, or GC8 as partial trade.
here is a video of it getting tuned at lucky 7's by daniel kuo. car made 202wheel with the stock exhaust manifold and 28 pound wheels. right now with the 19 pound wheels id say its about 215, but can easily hit 225 with headers. way faster than lets say a s2000.
https://youtu.be/yDbB3RvA5Xg
$16,000 firm
russell
(949) 899-7015
[email protected]
File Type: jpg 15776775_10154392360273440_5646736712355822949_o.jpg (238.1 KB, 393 views)
File Type: jpg 10548186_10152355958648440_127271491809691083_o.jpg (263.1 KB, 376 views)
File Type: jpg 10382228_10152353592013440_9115382382218690300_o.jpg (454.3 KB, 326 views)
File Type: jpg 15515996_823052834502190_1706785512_o.jpg (111.4 KB, 293 views)
File Type: jpg 15723468_10154392248913440_5679192043787295752_o.jpg (270.6 KB, 417 views)
File Type: jpeg 535bb84715d86e9ae1bb759bc514e389.jpeg (155.3 KB, 258 views)
File Type: jpg 15723725_10154389381858440_379804023529046332_o.jpg (255.3 KB, 193 views)
File Type: jpg 15747445_10154389725768440_2827417561829102470_n.jpg (42.6 KB, 168 views)
roadsterruss is offline   Reply With Quote
Old 10-18-2017, 08:12 PM   #2
MandTPhotography
MandTPhotography is an unknown quantity at this point
Good lord.
All I can say is GLWS, and this is a fantastic, very informative for sale ad.
MandTPhotography is offline   Reply With Quote
Old 10-19-2017, 12:26 AM   #3
canyontougeFC3S
canyontougeFC3S's Avatar
Trader Rating: (36)
canyontougeFC3S is an unknown quantity at this point
Feedback Score: 36 reviews
I've been watching your ad on RX7club for what feels like over a year now. Its on my wishlist ��
canyontougeFC3S is offline   Reply With Quote
Old 10-23-2017, 11:06 PM   #4
roadsterruss
thanks guys, ttt!
Old 10-24-2017, 07:00 AM   #5
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
GAWDDAYUM...
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline   Reply With Quote
Old 10-28-2017, 08:41 PM   #6
roadsterruss
yyyyyyyyyyttt
Old 11-03-2017, 12:13 PM   #7
roadsterruss
tttttttttttttttttttttttttttttty
Old 11-06-2017, 06:44 PM   #8
roadsterruss
Ttttttttttttttttttttt
Old 11-11-2017, 05:14 PM   #9
roadsterruss
yyyyyyyyyyyyyyyyyyyyy
Old 11-23-2017, 12:39 AM   #10
roadsterruss
price drop 12,750 crazy steal
Old 12-21-2017, 04:39 PM   #11
roadsterruss
tttttty to the top
Old 02-05-2018, 02:12 PM   #12
roadsterruss
Price drop 11k wow
Old 02-18-2018, 06:05 PM   #13
roadsterruss
price drop 10k
