03-29-2005, 02:05 PM | #1 |
real quick will 18x8.5 f 18.9.5 r with +35 offset work on s13
real quick, I was offered a set of these staggared wheels with these specs. They are brand new so I was wondering will that offset work on my s13 coupe. If anyone has pictures of this setup would be awsome. Im looking for a flush with fender setup. Dont want it to stick out like a "lowrider".
03-29-2005, 02:14 PM | #2 | |
Yea it will be somewhat 'flush'. You could probably go lower with the offsets though w/o having to pull or roll your fenders. but those offsets will fit decently. Did you try searching the board by those sizes? What wheels are they? You can try searching by the wheel name. Or you could just do this all manual and get it right the first time by using the Offset Calculator |
03-29-2005, 02:25 PM | #3 | |
03-29-2005, 04:07 PM | #5 |
You'll need a spacer if you have coilovers for sure, and you should get a spacer for the front anyways. Then again it greatly depends on tire size. If you use 225's then get a 15mm spacer for the front.
