Baddest gauges you can get on the market. This requires no control unit and can be wired up on it's own, the guys that are familiar with Defi gauges know what I'm talking about.
This Tach retails for $400+. Looking for $240.00 OBO. Need to sell asap. Perfect gauge for those running VE and revving that beast out! Brand new, only opened the box to take pictures!
The dial diameter is 80mm(3 1/8in).
The switch illumination color is the same as the color of gauge illumination.
Install instructions can be found here:
http://www.defi-shop.com/media/bfrgta.pdf
Maximum angle of deflective 270 degrees (full sweep) is controlled by the microcomputer up to 4600 division (0.057degrees each) to provide high precision in the accuracy of information generated. The stepping motor is sufficient for quick response of all sorts of professional motorsports.
The gauge dial is invisible while the ignition switch is off. Once the ignition switch is turned on, a clear display appears by colored LED illumination. The gauge dial illumination and the red emitting needle pointer provide high visibility.
Racer Gauge 80 tachometer OFF
Ignition Off
Red Racer Gauge 80 tachometer
Red Racer Gauge
The scale is compressed to acquire great visibility and ease of use.
*Wide-angle scale is used at the idling range 0~3,000RPM.
*The scale is fitted to recent engine power band and linear scale is used from 3,000RPM to 11,000RPM.
The gauge dial and the needle pointer performs opening and closing modes interlocked with turning ON/OFF of the ignition.
The maximum RPM during driving can be stored and checked later.
BF Tachometer peak
There are 5 stages of brightness for the daytime and 6 stages for the nighttime. The brightness can be decreased/increased with the vehicle lights switched on/off.
Two customer-defined warning RPMs can be set. When the RPMs are exceeded, the warning LED blinks/lights up and the warning buzzer sounds.
The exclusive large-sized indicator which lights in green and red enhances the visibility of warnings in addition to the warning LED in the gauge.
The large-sized switch unit with light is fixable on the gauge and is also detachable.
Exclusive mounting band and back case
The gauge is clinched by using the exclusive mounting band and back case. Wires can be stored in the back case neatly.
Regular Position Bezel for 80mm (3 1/8") gauge is included in the product.
Demonstration Pictures***:
