07-02-2016, 10:16 PM | #1 |
Mishimoto rad neck leak common?
I've got a 240sx w/an overheating issue and what appears to be some seeping around the radiator neck (could be cap I suppose). I noticed that these neck seem to be press fit/brazed on and not welded.
Anyone have similar issues w/these rads or their China equivalents? |
07-02-2016, 10:55 PM | #2 |
Trader Rating: (37)
Feedback Score: 37 reviews
Could be you overflow hose if there isn't a good seal on it.
Other than that, just trolling. I don't have a Mishi. I am using a Koyo.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
07-02-2016, 11:00 PM | #3 |
Trader Rating: (130)
Feedback Score: 130 reviews
One of my friends had the same issue with mishimoto. His water neck nipple to the overflow tank broke off. It's not attached properly like it was just threaded into the neck and it's poor quality. Mishimoto warranties it for him though.
07-02-2016, 11:04 PM | #4 |
I have the exact same issue with my Mishimoto Radiator for my S13.
Unfortunatly my car is a DD and I dont have the down time to wait for a replacement. I did remove that tiny barb fitting and seal it with some teflon tape. Seems to leak less but I the problem is still there. Who ever drilled and tapped the neck, did an awful job and it leaks like a river. The radiator also doesnt keep the coolant cold because the neck was drilled such way that the radiator cap cannot seal it so no pressure ever is built in the cooling system. What's funny is that someone said that Mishimoto sucks, and had it been a year earlier, and I would have disagreed. Seeing a $300 dollar radiator with that quality of work really made me not want to get anything else from Mishimoto and I recommend you do the same. |
07-03-2016, 12:10 AM | #5 |
Didn't think to check the overflow barb. I'm talking more about the neck going into the tank.
I heard koyo had issues w/their hose pipes being overly thin and crushing over time as well. I've had a cx racing in the past w/no issues. And koyo brass OEM that was a solid unit. |
07-03-2016, 01:57 PM | #7 |
turns out the pooling was from the cap. I bent the holding tabs so it's tighter now and that fixed the leaking. I've still got vapor coming off the bottom of the rad now. I thought it was just spillover but I may have a pin hole/bad solder on one or multiple tubes.
Now whether it's worth the fix at a rad shop or cut my losses. Whats the usual rate to fix a rad tube leak? |
07-03-2016, 02:30 PM | #8 |
Trader Rating: (37)
Glad that the cap was the main issue. I'd recommend before going to a shop, pull the radiator and wash the outside down w/ soap and water and a soft bristle brush. It's a possibility that the steam is residue from the coolant. When you're done doing that, plug the inlet and outlet, let the radiator dry off pretty good and fill the radiator up w/ water. If there are any pin holes, the water will drip out. You can buy a pressure tester from Harbour Freight for a few bucks. It'll do you justice for determining if there's a pin hole or not w/ water in the system.
07-03-2016, 03:49 PM | #9 | |
07-03-2016, 03:52 PM | #10 |
Trader Rating: (37)
You won't pop a leak under the dash if you pull the radiator and pressure test just it.
07-03-2016, 05:33 PM | #11 |
07-03-2016, 06:44 PM | #13 |
I have used all three of the mentioned...just throw some bars stop leak in and call it good! one was rabbit put hole in it(hit at 75mph), one was me overtightening the drain, snapped off and leaked, current one holding with no issues! but bar s in there, just be careful I have heard it can clog heater core...
07-06-2016, 06:21 PM | #15 |
You only need 18-20psi. Stock cap is like 13.
07-10-2016, 01:45 AM | #18 | |
GM2 (SW/AW)
You sure you don't want to just have the neck touched up instead of getting a whole new setup?
KA-T for life! Current for sale advertisement |
07-10-2016, 08:03 AM | #19 |
I brought a cx racing radiator for my rb and my 1jz.
the rb lasted 2 years and the overflow barb broke off so I scrapped that radiator and I'm waiting to get a replacement. on the sc/1jz my neck was leaking so I got crafty and had my buddy weld the neck to the rest of the rad. before after
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
07-10-2016, 08:05 PM | #20 | |
In any case, 100 bux later I ordered an ebay/mishimoto/cx racing clone shipped to my door...guessing rad shop would charge 30$ to even attempt a fix. I'll run a 16 psi cap instead of the 19 psi cap on the previous mishimoto just for safety. My biggest fear was leaky HG pressurizing the system and causing all these leaks (I thought I had pressure when cold), but a HG test kit showed no reaction from exhaust gases. I did finally manage to get the pressure tester on there and it climbed to ~14 psi and dropped to as low as 5 psi when thermostat opened and fan came on. Does 5 psi sound normal at idle for coolant pressure (seems kind of low)? |
07-10-2016, 08:07 PM | #21 | |
I feared that was the problem w/mine...turned out to be the mishimoto cap |
07-10-2016, 09:15 PM | #22 | |
GM2 (SW/AW)
Read up on this, it's very informative.
http://zilvia.net/f/showthread.php?t=132967 Stock pressure cap is generally 7 psi, so figure you're running at 5psi you're safely under the threshold for opening the cap. Now he's using pictures for an RB so I think it's as close as it gets to your situation.
07-15-2016, 10:53 PM | #24 |
china clone came in, identical to the mishi but it seems like they counter measured the pressed/soldered neck by welding it now. Will update as the other stuff arrives.
07-21-2016, 02:53 PM | #25 |
Hello Everyone,
Thank you for the post. I would like to apologize if you are having any issues with our products. That being said we do have a great warranty and the process is painless. We can actually send you a radiator without you having to remove your factory one. For any additional questions please feel free to contact us directly at [email protected]
Mishimoto Automotive |
07-21-2016, 03:21 PM | #26 |
Trader Rating: (37)
Of course the radiator would have to have been purchased from a dealer and there would need to be proof of purchase.
Most things around here are at least second hand, so I'm assuming that Mishimoto won't warranty something that was purchased second hand? W/o a receipt?
07-21-2016, 05:13 PM | #27 | |
Trader Rating: (62)
Feedback Score: 62 reviews
I got mine brand new second hand, dude was suppose to forward me receipt for warranty he never got around it nor I ever thought I was have such issue now seems like I'm out of luck smh |
