02-15-2016, 04:04 PM | #1 |
Intake-Turbo-Cams-Manifold-Power-VVl- Power Commander-Other Parts
I am willing to ship at buyer expense.
I am open to price suggestions. Any question that you have, I will try and answer them. Call or text 917-636-9801. 1. Holset HX35W. Comes with two exhaust housings ; BEP .63 AR Housing. And the Twin Scroll Housing, T3 flange. I bought a brand new intake blade and a brand new exhaust blade and shaft for this turbo. It's been fully balanced and a brand new rebuild kit installed. 550 http://zilvia.net/f/attachment.php?a...1&d=1455612334 http://zilvia.net/f/attachment.php?a...1&d=1455612512 http://zilvia.net/f/attachment.php?a...1&d=1455612539 http://zilvia.net/f/attachment.php?a...1&d=1455613461 2. Custom build Ram Horn T3 Exhaust Manifold. Zero Leak. Zero Damage. 450 http://zilvia.net/f/attachment.php?a...1&d=1455612644 3. SR20DET S13 Greedy Intake Manifold. It's the Real deal. 475 http://zilvia.net/f/attachment.php?a...1&d=1455612678 4. Ogura 409 Series Single Disk clutch. Comes with the right bearing. all the clutch disk surfaces measured out to an average of 4.515mm. Brand new it's suppose to be 5mm thick. This clutch is pretty much brand new and has a lot of life left in it. 450 http://zilvia.net/f/attachment.php?a...1&d=1455612723 http://zilvia.net/f/attachment.php?a...1&d=1455612752 http://zilvia.net/f/attachment.php? attachmentid=90951&stc=1&d=1455612787 5. Fidanza light weight fly wheel for the SR20DET transmission. 250 http://zilvia.net/f/attachment.php?a...1&d=1455612857 6. ACT 6 Puck clutch kit, sprung, with the heavy duty pressure plate. Used for less then 500 miles. 300 http://zilvia.net/f/attachment.php?a...1&d=1455612882 http://zilvia.net/f/attachment.php?a...1&d=1455612897 http://zilvia.net/f/attachment.php?a...1&d=1455612923 7. Clutch fan. 25 http://zilvia.net/f/attachment.php?a...1&d=1455612945 8. IACV, with metal screw. 50 http://zilvia.net/f/attachment.php?a...1&d=1455612990 9. TB with TPS Sensor, i think it was 70mm. 75 http://zilvia.net/f/attachment.php?a...1&d=1455613019 10. Crank Angel Sensor, working condition. I have Two of these. Once with an AEM crank disk. 10 http://zilvia.net/f/attachment.php?a...1&d=1455613047 http://zilvia.net/f/attachment.php?a...1&d=1455613060 http://zilvia.net/f/attachment.php?a...1&d=1455613520 11. Front oil cover. Works perfect. Just needs to be sanded and repainted. Has a bran new front seal. 90 http://zilvia.net/f/attachment.php?a...1&d=1455613088 12. Sr20det Starter. It's been tested and works perfect. 70 http://zilvia.net/f/attachment.php?a...1&d=1455613114 13. VVl pressure solenoid relocation kit. Comes with all the necessary hardware. 100 http://zilvia.net/f/attachment.php?a...1&d=1455613143 14. Samco Radiator hoses. 30 http://zilvia.net/f/attachment.php?a...1&d=1455613162 15. S14 kouki power steering lines and reservoir. 75 http://zilvia.net/f/attachment.php?a...1&d=1455613187 16. Power Commander III from a 2007 CBR600. 250 http://zilvia.net/f/attachment.php?a...1&d=1455613218 17. Coil Pack with the Harness. I have three sets. 100 each http://zilvia.net/f/attachment.php?a...1&d=1455613243 http://zilvia.net/f/attachment.php?a...1&d=1455613251 http://zilvia.net/f/attachment.php?a...1&d=1455613267 14. Igniter with the Harness. 50 http://zilvia.net/f/attachment.php?a...1&d=1455613349 15. Auto Gauge 11k RPM gauge with the shift light. It has a switch in the back for 4,6,8 cylinders. 100 http://zilvia.net/f/attachment.php?a...1&d=1455613372 16. SR Exhaust gasket. 10 http://zilvia.net/f/attachment.php?a...1&d=1455613399 17. 5 speed drive shaft from an S14, i am pretty sure it was non ABS. 50 http://zilvia.net/f/attachment.php?a...1&d=1455613418 18. VVL stock Cams P11. 150 19. KA24DE 232/248 camshafts. 100 Last edited by outlawstar1023; 02-19-2016 at 11:58 PM.. Reason: Added Pictures. |
