Old 12-18-2014, 04:01 PM   #1
Sirius Black
Sirius Black is an unknown quantity at this point
KA 240sx. priced to sell $4500 firm.
must go price firm. or trade for sporkbike 2004+
txt951three8seven0731
Have my 91 Ka24de hatch for sale, it is a drift car and ready to go.
this is basically an s14 trapped in an s13 body.
its my DD purpose built for drifting. Im testing the waters and will not accept lowball offers.
JUST FISNISHED FRESH REBUILD . TURBO READY. FORGED INTERNALS!!!
Looking for a good home and some TLC,
176k on the odometer, but just rebuilt the ka24de with:
Mods/Specs
Engine-S14 Ka24de
-Wiseco Forged Pistons
-Eagle H-beam forged Rods
-ACL bearings
-block honed and hottank .020
-vavle job and decked head
-balanced crankshaft
-taped oil pan for turbo feed line
-Cosworth 1.1mm headgasket
-solid polyurethane motor and transmission mounts!
-new timing chain kit and tensioners
-Arp Headstuds and main studs
-New Fel-pro headgasket
-maintained with Castrol half blend sythetic
-new cam idle sprocket (done right so this baby will not strip or skip timing under stress)
-Aem intake
-Mizu Aluminum Radiator with Twin Manual Switch cooling fans.
- egr blockoff plate
-no smog gear
-Engine Torque Damper
-Walbro 190lph fuel pump w/fuse
New Transmission
-Manual 5speed Gearbox
-Exedy Stage 1 Clutch and Pressure Plate
-Maintained with Redline Gear/Trans fluid
-Fidanza 11lb Lightweight Flywheel, revs quick and great for heel toe downshifting, rev matching, very responsive.
-No pops or grinds, smooth shifts if you know wtf your doing.
-Welded Differential, solid never had a problem with it, very consistent and predictable. personal preference for drifting and canyon racing but others may disagree. be gentle in rain unless you know what you're doing.
Interior?
-usb/ipod head unit w, aux no bluetooth.
-Nardi Leather Steering Wheel
-Gold DRIFT BUTTON!
-S14 seats
-Driver and Passenger 4pt Harness
-Gutted...by this I mean no headliner, carpet, trunk panels. I run it with no rear seats, but do have them.
-Interior floor pan, transmission hump, and trunk sprayed w/ black spray on bed liner.
-LED dash lights
-Has door panels, (electric windows, which work!) A-pillars and back seat arm rests in, I like the look, but I also have the B-pillar panel in my garage.
-NO CRACKS IN DASH!!! rare find.
Suspensionsss!!!
-Powered by Max Pro Series Coilovers all around I purchased brand spanking new earlier this year,
with full camber and caster adjustability in the front, and 32way dampening all around.. this is why i dont want to sell
-Powered by Max front steering inner tie rods, w/ moog s14 outer tie rod ends recently replaced. Godspeed front toe rods, Godspeed gen 1 rear upper control arms, and gen 2 rear toe rods.
-front strut bar in engine bay, really stiffens the front up in my opinion, everything counts.
Wheels/Brakes
-5Lug Conversion all around!
-16in. Infiniti 5 lug chrome rims wrapped in fresh Dunlop Direzza DZ101s I bought new, very good tread and my favourite tires so far. (have the set of 4 but only running 2 on the front right now)
-18in. XXR 962's recently refurbished rears. may or may not sell with car, (5 lug)
-25mm Hubcentric Bolt-on Spacers, on front (have them for the rear but no need to run them right now)
-Q45 front brake upgrade w/ good rotors
-R1 Concepts Premium(high heat) Slotted Rotors w/ on the rear
-Ceramic Pads, new all around.
-rotor resurfaced all around
-I also have a full set of s14 se rims I can throw in if the price is right.
Body
-zip stitched and battle scared side skirts
-rear bumper body kit no cracks,
-"sharkface" oem front bumper sprayed black
-Dual exhaust catback exhaust, 2.5in piping w/ 3in. tips. comes with silencers?
-no cat, Backfires like a fire breathing dragon on aggressive downshifts and pulls with 91 octane
-Cherry Shinka Black Rx8 Paint, needs a good claybar and wax.
-Sunroof (although latch needs to be replaced.)
-HID headlights. however, headlight motors do not work, (for sleepy eye you can manually lower them for a cool look) can switch back and forth from HID to normal headlights with high beam switch.
This car handles like a go kart, very responsive and I've put lots of work into it to make it reliable.
new alignment just done and tires balanced
just "smoged" her and got new cali plates reg payed off
CONS
-NO A/C.. Needs new charge, compressor and belt. currently removed.
-gas gauge does not work always reads Empty, however fuel pump is a champ
-cracked windshield
-sunroof needs a new hinge to stay open (without duct tape)
I mainly built this car up to drift and didn't bother to spend time on much else and i like it that way, with that the cons are an easy fix if you wanted too, or if you have extra parts laying around or make a trip to a junkyard.
if you are serious give me a call and i will answer any and all Q's you may have to the best of my ability, as far as trades go...
will only trade for
supersport bike with no damage and never dropped,
clean title 2004 and up 600 or 1000cc
. cash is king, no payment plans or checks.
Sirius Black is offline   Reply With Quote
coilovers, eagle rods, powered by max, welded, wiseco
