06-05-2015, 09:44 AM | #18331 |
Coolant resivor tank sitting next to the wiper motor. That looks like a great choice for my setup (tubbed front end). Anyone make one? Most companies I have found just do the big cylinder style ones. Any info would be great.
06-05-2015, 07:53 PM | #18332 | |
06-06-2015, 09:23 AM | #18333 |
Same exact thing, all I keep finding are the cylinder type. I was thinking I might just have to take some measurements and see if there is a factory option from another car.
06-07-2015, 07:12 AM | #18334 | |
http://www.summitracing.com/search/p...rder=Ascending
06-09-2015, 06:50 PM | #18335 |
Wrapping up my sr swap; wired in the AEM uego and truboost as well as electric fans to the acc wire for the radio.
Fans are running to 2 relays with inline fuses and their own grounds. I turn the key to accessories and the fans turn on, but no power to the gauges. I ran out of time until next weekend -- the only difference between fans and gauges is that the gauges are grounded with the radio harness ground. That will be my first thing to check, could there be any other possibilities? Thanks! |
06-09-2015, 08:23 PM | #18336 |
My buddy and I were out cruising today, when he told me why my bumper was wobbling at high speeds. I tell him to drive it and he was right.
I converted my kouki to a full jdm front end swap. The swap was easy I used a jdm kouki bumper retainer, I did not use the foam but that shouldn't cause the bumper to be wobbling on the bottom should it? I'm confused because is there suppose to be another retainer that bolts the bottom of the bumper? Not completely sure. |
06-09-2015, 09:10 PM | #18337 |
stupid question, what OEM front bumpers or aero packages came on s13 silvias? I know of the standard regular one and the aero bumper, but I'm not super crazy about the aero bumper. Well at least not enough to spend $600-$1200 on it. And the regular one isn't quite aggresive enough.
Do they have a 3rd? or an oem lip for it? |
06-09-2015, 10:24 PM | #18338 |
Need Help Before throwing parts at my 93 s13 with stock KA24de, I had hard starting problems, found cylinder 4 injector not firing. Replaced with another used injector, now all injectors are firing and not leaking pass rail. Car is now flooding all cylinders with fuel, so much fuel that its getting into my oil and car doesnt run onless injector wire connectors are disconnected or fuel pump fuse out. Anyone have thie problem?
06-10-2015, 07:26 AM | #18339 | |
06-10-2015, 07:40 AM | #18340 | |
Your gauges should be wired and grounded with cluster, not stereo. Your fans should be wired with ignition hot so that they power up upon starting the car, run when temps hit 'center' on the gauge during idle, then run until total heat drops 10* when shut off(about two to three minutes). If you are using an Enjuku/Wire Specialties Fan Controller that is: Orange: Not used Black SMALL: Battery ground Blue: to both fans( + ) Black from fans: Frame Ground ( - ) Yellow: Ignition HOT(Fuse box) Red: Battery Acc terminal(small section that is on the side of the clamp)
06-10-2015, 08:53 AM | #18341 |
Yeah only on the bottom. It is oe bumper. But it only wobbles at high speeds 70-80 mph. What about those holes on the bottom of the bumper? Is that suppose to be attached to something?
06-10-2015, 01:53 PM | #18342 |
I have a prosport water temp gauge on my SR. Weird problem is...if I hit the lights or hit the brakes or even turn my radio up...the needle will go up and then back down when these things go back off.
Sometimes drastically and sometimes only a little bit? Did some voltage tests at battery (miata battery) to see if there was a voltage drop with everything on and there wasn't any issue. I noticed my ground for the water temp harness is at the dipstick at the water neck? could that be an issue? Any idea what could be the problem? Water temp and boost gauge are tapped into radio harness. (Aftermarket radio). |
06-10-2015, 02:34 PM | #18343 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
im surprised prosport isnt providing a digital sensor instead of analogue sensor that has to be chassis grounded instead of grounding itself via the gauge. |
06-10-2015, 02:57 PM | #18344 | |
I'm gonna go ahead and extend that ground to chassis this weekend and hopefully fixes the needle bouncing issue. |
06-10-2015, 11:28 PM | #18345 |
Question for anyone who has delt with the S14 Digital climate control.
With the A/C system charged, but the sensors not working (sun load/interior or exterior temp sensors.etc) Can the Air con still work by NOT using the "Auto" function? I'm looking to get my a/c charged but don't know if the (any) shop will bother as it is not stock. ***Background story*** Two previous owners ago someone attempted the DCC converion on my S14, tho the a/c system is complete, it does not work. The dcc unit does come on & control the blower motor as I had used the heater that way, but when I trouble shooted the sensors for the A/C (via dcc conversion link) it appears ALL sensors read errors. If I can't use the A/C as described above, I'll have to source an usdm unit and try to undo someone elses mess. Anyone know? |
06-11-2015, 07:00 PM | #18346 |
06-11-2015, 07:38 PM | #18347 |
Where does this go? I have a feeling it wasn't connected to anything ImageUploadedByTapatalk1434073028.074262.jpg here is the other end which I know where it come from ImageUploadedByTapatalk1434073074.785392.jpg
06-12-2015, 03:34 PM | #18348 |
I installed tein h-tech springs about 6 months ago and the rear passenger side looks like it's at stock height in person. I tried to redo the rear passenger shock/spring to see if I missed anything but nothing changed when I put it all back together. Could really torn up bushings in rear subframe cause this? If so, what is a good replacement for the rear subframe bushings?
first pic rear driver, 2nd pic rear pass. |
06-17-2015, 09:20 PM | #18350 |
Need to know if this is one of those "ain't broke don't fix it" situations. Have engine out of car and trams about to go back on. Oem sr20det long block, the rear main seal is fine not leaky. Maybe 50k miles on motor. Should I replace it or leave be.
06-17-2015, 09:36 PM | #18351 | |
Current prices may have changed though. thats kinda up to you though. Replacing is usually safer |
06-17-2015, 10:36 PM | #18352 | |
Im swapping an Rb into my S14 right now and first thing I did when I had the engine was spilt the trans while it was out and replaced all the seals and the clutch. Engine is in now and I feel I wont regret the decision. |
06-17-2015, 11:10 PM | #18353 | |
06-18-2015, 12:11 AM | #18354 |
What are you guys paying average to have an sr rebuilt to oem spec? my motor isn't too far out, I'm having it machined and sleeved and using oem pistons and rings. crank is being machine and i have nice cams to go in. also have a deck plate.
Would $700-$1000 be unrealistic? basically trying to decide between rebuilding the sr to oem spec using oem parts and having it actually last at 320whp or scrap the plan and drop in an rb25. |
06-18-2015, 12:28 PM | #18355 | |
320 is no problem for stock internals
06-18-2015, 02:24 PM | #18356 | |
06-20-2015, 01:32 PM | #18358 |
when my key is in the off position and even when its not in i can turn everything on just as if the key was in the on position, could this be caused by a faulty ignition switch or am i chasing some sort of wiring gremlin?
Car is a virgin 89 base model coupe, auto trans. Also, could i use a 5 speed ignition switch, or even an S14 one? whats different about them? thanks |
06-21-2015, 07:36 AM | #18359 | |
06-21-2015, 12:44 PM | #18360 |
Here's a stupid question! I did a 5-lug swap on the rear of my 240 this weekend, also replaced the rotors and pads. When I first applied the brake, they locked up and wouldn't release. Now they release when I apply the brakes and lock when I release the pedal! What is going on here? The calipers and brake lines are stock and I didn't remove them when i did the 5 lug swap. I'm guessing its something stupid i'm just not seeing, any ideas?
