Old 08-01-2018, 01:39 PM   #1
brian2323
brian2323 is an unknown quantity at this point
S14 Rb26
Pictures can be found at
http://s947.photobucket.com/user/tru...?sort=3&page=1
Stickers have been removed
Price is "or best offer" ALL offers are considered.
This is a perfectly working and ready to race machine, this is ideal for someone wanting to get into a racing/time attack series for pennies on the dollar.
The Car was built following the nasa rule book to run in HPDE, TT, and Global Time Attack unlimited rwd.
Cage is FD Legal as well, can easily be converted into drift car
Here are the specs:
Chassis:
1997 Nissan 240sx SE
Horsepower/Torque: It was detuned to 450 to run pump gas
old hp was
606rwhp @8000RPM 466rwtq @6446RPM @ 22psi (want more power? Just turn up the boost! We felt 600 was balanced)
Weight:
3030lbs With driver and Full Tank
Engine:
R32 rb26dett
Jun crank collar
Tomei oil restrictor
Tomei oil pan baffle
Greddy oil pump
Greddy clear timing belt cover
Greddy intake manifold
HKS 272 in/ex cams
HKS adjustible cam gears
HKS timing belt
HKS fuel rail
Wiseco 86.5mm pistons
Eagle H beam rods
Cometic head gasket
ACL Race rod bearings
ACL Race main bearings
ARP head studs
ARP main studs
Twin Garrett gt2871r-10's
TSI Ported OEM exhaust manifolds
TSI Ported ITB runners
TSI -3an SS braided turbo oil and water lines
TSI Divided OEM twin turbo pipe
TSI Ported and polished head
TSI Custom intake pipes
TSI -6an SS braided power steering lines and power steering cooler
TSI -10an SS braided oil filter relocation kit and oil cooler kit using
Greddy thermostatic filter relocator
ATI race crank damper and water pump pulley
Dual synapse blow off valves
Aem air filters
Mckinney Motorsports touge downpipe
Mckinney Motorsports fmic kit
NGK bkr7e spark plugs
Isis Performance blast pipe exhaust with 4" tips
FabWorks custom oil catch can
FabWorks -AN valve cover adaptors
Cooling:
Koyo aluminum radiator
Flex-a-lite 340 series dual electric pusher fans
Raw Brokerage radiator hoses
N1 OEM water pump
Nismo thermostat
NRG radiator diversion panel
DIF PWM fan controller
Fuel:
Injector Dynamics ID1000 injectors
walbro 385 fuel pump
Aeromotive FPR
Powerhouse Racing billet fuel hat
TSI fuel pump direct-wire relay kit
TSI -8an feed lines with inline fuel filter & -6an return lines
Drivetrain:
Rb25det transmission
Spec Super Twin clutch
Isis Performance Short shifter
Mckinney Motorsports engine and transmission mounts with solid isolators
Driveshaft Shop 4.5" aluminum "1000hp" driveshaft
S15 helical differential
Suspension:
Fortune Auto 510 Series coilovers with Swift Springs upgrade 12k front /10k rear
Fortune Auto tension rods
Fortune Auto ruca’s
Fortune Auto traction arms
Fortune Auto toe arms
Stance solid Subframe bushings
Stance solid Differential bushings
SPL Eccentric lockout kit
Sikky 32mm front sway bar
Oem rear sway bar
Brakes:
Z32 front calipers
Z32 rear calipers
Z32 rear e-brake assembly
R33 e-brake cables
Carbotech xp20 front pads
Carbotech xp10 rear pads
Powerslot rotors
Exterior:
Shine Auto front bumper
Shine Auto side skirts
Shine Auto rear valences
Shine Auto carbon fiber rear diffuser
OEM JDM s14 kouki rear bumper
OEM 180sx type-x turn signals
B-Magic 30mm front fenders widened even more
Origin type2 50mm rear over fenders
Seibon vented carbon fiber hood
Kognition chassis mount 72" wing
Euro spec oem kouki headlights
Sonar l.e.d. tail lights
Nagisa Auto GT front tow hook
TSI Custom Rear tow hook
Interior:
Sparco eve seat less then one year old
passenger is old junk seat
Nrg short hub
Nrg 2.5 quick release
Nardi 360mm deep corn steering wheel
Nismo Shift Knob
Battery relocation kit
Firecharger dual nozzle fire suppression system
Rjs racing harness
Rjs racing window net
Custom 8point D.O.M. rollcage with "Nascar" door bars
Electronics:
AEM v2 ems
Racepak iq3 digital dash with AEM interface
Dual AEM uego wideband gauges
AEM serial datastream gauge
Stri oil temperature gauge
Stri oil pressure gauge Stri water temperature gauge
Hotlap v2 laptimer
Wheels/Tires:
XXR 527 17x9.75 +25 wheels
Nitto nt01 275/40/17 tires
Project kics r40 neo chrome lug nuts
Project kics 10mm spacers all around
Nismo 60mm Extended Wheel Studs12046942_901707913197607_8554863833580148450_n-2.jpg
brian2323 is offline   Reply With Quote
Old 08-01-2018, 01:40 PM   #2
brian2323
18k obo dm for phone number
240 240sx, race car, rb26, s14, track car
