Old 02-16-2010, 06:52 PM   #601
udon!
udon! is an unknown quantity at this point
what online store has the biggest variety of those cup holders that go on the ac vents and stuff.
udon! is offline   Reply With Quote
Old 02-16-2010, 07:51 PM   #602
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Ebay.
blahblahblah
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 02-17-2010, 04:06 AM   #603
ayuaddict
ayuaddict's Avatar
I have a couple questions for you guys.
Question 1: What kind of paint stripper is the most effective and thorough yet safe to use on aluminum wheels?
Question 2: Has anybody replaced the studs on Project Kics spacers before? do you happen to remember the knurl diameter? i need get extended studs and i need to keep my spacers on the front so my wheels clear the tie rod.
Thanks for the help!
Old 02-17-2010, 09:37 AM   #604
Slammed180
I used this stuff when I stripped my Meisters.
Mar-Hyde Tal-Strip II Aircraft Coating Remover - 3711
Blow me, bitches.
Old 02-18-2010, 02:17 PM   #605
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Is there a filter for the automatic transmission fluid? If so, where is it located?
WheelsDirty
Old 02-18-2010, 04:02 PM   #606
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Where can I get bilstein shocks revalved locally,
OC!
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 02-18-2010, 04:30 PM   #607
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
for what tranny
usually its in the pan or just above the pan
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 02-18-2010, 04:38 PM   #608
stinky_180
stinky_180's Avatar
Trader Rating: (26)
ka/sr tranny. figured that it would be inside the pan.
WheelsDirty
Old 02-18-2010, 04:45 PM   #609
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
Since you're somewhat local, you can check out Super Autotoyz. They have A LOT.
www.realize-jp.net
Old 02-18-2010, 07:46 PM   #610
BIG_J
BIG_J's Avatar
BIG_J is an unknown quantity at this point
i have wheels i need tires for they are 17x9 +12 and 17x9.5 +12 i was wondering what size to run i was thinking 215 40 17 front and 235 40 17 in back would this be good or should i run 215 40 17 all around or another tire size
BIG_J is offline   Reply With Quote
Old 02-18-2010, 08:24 PM   #611
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
do 215/40 all around thats what im doing.
- Hong
Old 02-18-2010, 10:58 PM   #612
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Hearing a weird sound under acceleration. It sounds like a skreeching noise ONLY when turning right and sometimes when driving straight. DOES NOT make the noise when turning left.
I just swapped my SR in, NOTHING is rubbing anywhere, no zipties..nothing. I thought it might have been a small leak from the downpipe but sealed it up again and its still making the noise.
Someone told me that it might be possible that it might be my power steering mump going bad? IDK why only turning right and going straight though. Does the pump work hard when turning acertain direction?
It isnt the manifold, not a gasket, and theres no turbo play. Its blowing my mind.
http://i48.photobucket.com/albums/f209/mj2545/logo.gif.com
Marc240 is offline   Reply With Quote
Old 02-18-2010, 11:46 PM   #613
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
so finished up my 300zx rear brake swap, got some of those adapters for the e brake cables, and got everything bolted up, Now with the ebrake handle adjustment nut for the cable all the way loosened up the e brake cables still have lots of tension on them and still are engaged. I ran the cables through the stock holes in the subframe, and they are 2+2 cables on a s13. If i don't run the adapters the lines have too much slack and if i do they are too tight. Any one have any suggestions or might have had this problem?
Slip Gypsies Blog
not sure if you realize this
Old 02-19-2010, 07:09 PM   #614
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
are the upper engine and lower tranny harnesses the same between zenki and kouki model S14's?
Old 02-20-2010, 07:03 AM   #615
240sxChillen
240sxChillen's Avatar
240sxChillen is an unknown quantity at this point
What Bulb type do zenkis have? h4? halp.
EDIT-It was H4
240sxChillen is offline   Reply With Quote
Old 02-20-2010, 09:20 AM   #616
Jakob
Jakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to all
are s14 oem kouki and zenki sideskirts mounted the same way?
what i mean is the stock kouki sideskirts are mounted with screws and clips on the body of the car.
are the locations of the holes and clips the same on kouki and zenki skirts?
Jakob is offline   Reply With Quote
Old 02-20-2010, 12:57 PM   #617
Mr.Bobble
Mr.Bobble's Avatar
Mr.Bobble is an unknown quantity at this point
What do you guys use to reseal the bead on 3 piece wheels? taking them apart to get refinished..
Mr.Bobble is offline   Reply With Quote
Old 02-20-2010, 01:02 PM   #618
Bushido
Bushido's Avatar
does anyone know where i can find a sticker that has the diagram for the main engine bay fuse box.
I want to repaint my fusebox cover...
Old 02-20-2010, 03:17 PM   #619
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
I have some pbm knuckles and would like to know what caster all the peoples with modded knuckles run?
NMs14.5kouki is offline   Reply With Quote
Old 02-20-2010, 03:18 PM   #620
schrapnel85
schrapnel85's Avatar
schrapnel85 is an unknown quantity at this point
Send a message via MSN to schrapnel85
i was looking at getting an origin aggressive body kit. my vehicle is a 95240sx with the kouki front end conversion. do i jst order a complete 97 kit? or 97 front bumper, 95 side skirt and 95 rear bumper? im really new to this and have tried searching this. my apologies.
schrapnel85 is offline   Reply With Quote
Old 02-20-2010, 04:41 PM   #621
Mr.Bobble
Mr.Bobble's Avatar
You can get the whole kit. Everything else will work out just fine. Correct me if i'm wrong somebody else..
Old 02-20-2010, 05:28 PM   #622
NMs14.5kouki
Trader Rating: (38)
you are correct. all s14 sides and rears are the same front is the only difference between zenki and kouki
Old 02-20-2010, 06:36 PM   #623
I LUV MY S13
I LUV MY S13's Avatar
aight guys, after 4 LONG months of rebuilding my motor, i finally finished...got it in, wired and bolted up, fluids are in and it sits good..now it doesnt start and i cant find out why..motor turns over just fine, it seems like it doesnt get any spark, fuel does pump
what can be the issue? spark plugs/cables are fairly new, maybe a year old and they're ngk..dizzy was aligned properly with the oil pump spindle, is hooked up and grounded
so again whats the issue? any suggestions?
please guys im so close to driving it again i wet myslef just thinking about it
oh its a SOHC ka
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 02-21-2010, 10:20 AM   #624
Mr.Bobble
Mr.Bobble's Avatar
Kouki sideskirts have I believe 5 holes on the bottom? Navan zenki sides there are two holes that mount to the front mud flap location that's already pre drilled. Also two holes in the rear. You may have to make a custom bracket unless it comes with it or drill additional holes.
Old 02-21-2010, 11:15 AM   #625
I LUV MY S13
oh its a SOHC ka
bump c'mon guys i need some advice..ive searched and all i find is "fuel or spark" but both are fine for me..
my moms car just got hit and i need this car running ASAP
-Jorge
Old 02-21-2010, 11:21 AM   #626
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
One of my friends bought a caulking gun and some silicone caulk. Didn't leak at all. Someone also used rtv with no leaks
MisawaJason is offline   Reply With Quote
Old 02-21-2010, 11:23 AM   #627
Slammed180
Silicone.
I used Dow Corning silicone.
Blow me, bitches.
Old 02-21-2010, 12:12 PM   #628
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
oh its a SOHC ka
Does it spark? Pull a plug, crank it, and check for spark. Does the fuel prime? When you turn the key to the ON position, do you hear the fuel pump whine?
If both are good and you are cranking strong, start checking electrical. Check all the grounds. Check all the connections - make sure they are properly snapped together.
On my DOHC, it would not fire but would crank hard. It turned out I didn't put together a connector correctly so it wasn't getting a signal to spark. Look it all over. If you narrow it down some more but have no luck, post your progress.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 02-21-2010, 12:50 PM   #629
R33E8
R33E8 is an unknown quantity at this point
Anyone have any recommendation of tires to put on rear z32 wheels? They use 245/45/16 which is kinda hard to find.. The cheaper the better..
R33E8 is offline   Reply With Quote
Old 02-21-2010, 04:07 PM   #630
I LUV MY S13
yep triple checked..im 99% sure its grounded/wired properly..gets fuel and spark
-Jorge
