Old 04-17-2008, 06:15 PM   #1
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
SOHC-DOHC cluster conversion
has anyone done the SOHC gauge cluster conversion so that the cluster reads DOHC tach? i want to make sure it works and pictures would be a plus... its detailed in this link http://www.nicoclub.com/articles.php?id=272023
let me kno thanx.
s13drob is offline   Reply With Quote
Old 04-17-2008, 06:37 PM   #2
projectRDM
projectRDM's Avatar
Conversion?
Remove SOHC cluster.
Install DOHC cluster.
There's nothing else to it.
FORMERLY R240NA
Old 04-17-2008, 07:04 PM   #3
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
Originally Posted by projectRDM View Post
Conversion?
well I have also heard of guys wiring signal from coil directly to tach of sohc..works fine...
you need to solder a couple wires to back of cluster...on a couple of pins...I read it on a diff forum, that has info and not just neg rep.
good luck. either way.
the easiest is forsure swap out for a dohc tach...cheapest is solder.
sillyvia13 is offline   Reply With Quote
Old 04-17-2008, 09:50 PM   #4
s13drob
s13drob's Avatar
Trader Rating: (29)
yea i kno that dohc cluster the best 2 go but the thing is i got 2 SOHC cluster and i might as well put them 2 use. thanx all... ill try the "nico" method
Old 04-17-2008, 11:55 PM   #5
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
You can swap the whole cluster. Or, just swap the tach(remove via screws in the back.) from clutster to cluster.
KA-T_240 is offline   Reply With Quote
Old 05-09-2008, 03:06 AM   #6
JDMSTYLE
JDMSTYLE's Avatar
JDMSTYLE is an unknown quantity at this point
reviving this thread from the dead...but i need to know how to directly wire the tach to the ignition coil...or distributor.
if anyone can help me out that would be great!!!
JDMSTYLE is offline   Reply With Quote
Old 02-27-2011, 09:45 AM   #7
dathkdrifter
dathkdrifter is an unknown quantity at this point
Talking
from what i've read online and i am also doing on my s13 right now
1. find the tam wire behind the cluster (yellow w/ red stripe)
2. run a wire from the tam to the engine bay near the ignition coil
3. cut or strip the coil positive wire and attach
now here's the part im stuck on...... i can't tell which is the positive wire on the ignition coil
dathkdrifter is offline   Reply With Quote
Old 02-27-2011, 10:55 AM   #8
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
I have done the swap. I have a bunch of SOHC digital clusters so I ran a tach driver wire to the cluster and it works perfect.
I did a write up on it , but it is in the preemie section. This is the one I tested as the positive.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 12-04-2011, 02:59 PM   #9
CertifiedGil
CertifiedGil is an unknown quantity at this point
Ordered premium, but have not got access yet. bummer.
CertifiedGil is offline   Reply With Quote
Old 12-04-2011, 02:59 PM   #10
CertifiedGil
really need to fix my deng Tach, haha!
Old 12-04-2011, 03:00 PM   #11
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
the irony of post 7 is he was actually the one reviving a 3.5 yr old thread....
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 01-08-2017, 10:32 AM   #12
bb4_96
bb4_96 is an unknown quantity at this point
I know right
bb4_96 is offline   Reply With Quote
Old 01-20-2017, 03:13 PM   #13
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Originally Posted by bb4_96 View Post
I know right
The irony
msglgnth
di-devol is offline   Reply With Quote
Old 01-26-2017, 09:13 PM   #14
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
Holy fuck...
slow40sx is offline   Reply With Quote
Old 01-26-2017, 09:30 PM   #15
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
6 fcking years he waited for that
'92 HB HX35 rb25 - sold
'89 Coupe GTX35 VVT-I 2JZ - yeah buddy
AS240 is offline   Reply With Quote
Old 01-02-2020, 05:13 PM   #16
bb4_96
Getting to be that time of year again.
Old 01-02-2020, 05:46 PM   #17
S14rebuild
Que fuckkkk?
