Old 12-27-2018, 05:45 PM   #1
Silvia180_
Silvia180_ is a well-known jackass
Transmission crossmember nut broken
Hey guys so I recently picked up a 95 s14 shell as a project. Very clean shell over all until I got to installing my transmissions cross member all was going good until I noticed the final hole didn’t have any thread at all and as I peeked over to side I noticed there was a hole there. Idk what to do now just leave it there and go on with my day or is my whole shell fucked. How can I fix this if possible at all
Silvia180_ is offline   Reply With Quote
Old 01-31-2019, 09:20 AM   #2
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
Looks like they stripped it and made the hole so they could put a bolt through and a nut on the back?
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 01-31-2019, 10:14 AM   #3
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
^Hes most likely correct. If it had stripped or been broken by the P.O. thats the only solution you have. It shouldnt be an issue unless you have a solid trans mount and it's putting a lot of stress through that area.
Put another nut in there, tack weld it in similar to how it would have been done by Nissan. Looks like it would be a bit difficult but not impossible to weld the hole back up with sheet metal for some real peace of mind.
Unless the surrounding area is covered in rot and is falling apart, it shouldn't be an issue. Just clean it up, weld some sheet in, and toss some paint on it so it wont rust.
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
