12-21-2016, 12:53 AM | #1 |
Battery Relocation Help
Im relocating my battery to the trunk of my s14, im using 4 gauge wire for power and ground. Im looking into distribution blocks and fuses.. Is a 100 amp fuse enough? If anyone can name a good block and fuse itd help alot thanks
12-21-2016, 06:20 PM | #3 |
If you're building a custom distribution box, you should match the factory fuse sizes for everything. You shouldn't ever use a fuse between the starter and battery. The starter draws 120+ amps and would blow fuses instantly.
12-22-2016, 11:03 AM | #6 | |
I don't remember the exact fuse I used, sold that car 11 years ago, but definitely use thicker 0 or 2 gauge wire. |
12-22-2016, 03:16 PM | #8 |
+2 on 1/0 Welding Wire. Then I ran my ground from the battery in the back of the trunk through the vent on Passenger side and bolted it to the frame of the car. By doing this my started does not drag at all. Do it right the first time.
842whp KA-T "Anyone can make power but how long can you make it last?" |
12-25-2016, 08:46 PM | #9 |
check out http://www.sonicelectronix.com for a good distribution block and just run a 150amp circuit breaker between your battery and the distribution block, thats what i did works flawlessly
93' sr sil-40 |
