Old 01-11-2019, 12:16 AM   #1
mewantkouki
Trader Rating: (32)
mewantkouki is making his/her stupidity well-knownmewantkouki is making his/her stupidity well-knownmewantkouki is making his/her stupidity well-knownmewantkouki is making his/her stupidity well-known
Feedback Score: 32 reviews
Nissan Datascan 2
Found what I needed. Delete
mewantkouki is offline   Reply With Quote
Old 01-11-2019, 10:34 AM   #2
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
You can put the ECU in set timing/idle speed mode by warming the engine fully and disconnecting the TPS.
OnTheChip is offline   Reply With Quote
Old 01-11-2019, 04:16 PM   #3
mewantkouki
Trader Rating: (32)
Old 01-11-2019, 07:01 PM   #4
dct223
dct223's Avatar
dct223 will become famous soon enoughdct223 will become famous soon enoughdct223 will become famous soon enoughdct223 will become famous soon enoughdct223 will become famous soon enough
Send a message via AIM to dct223
Follow the FSM procedure to get into timing mode.
IIRC you are supposed to warm up the car to operating temperature..
turn off the car and unplug TPS
start the car and rev it a few times
if you still cant get into timing mode or if your timing is not stable, you probably have other issues affecting your timing.
Originally Posted by mewantkouki View Post
My car wont do that... I cannot get it into timing mode. That's my reasoning for using the software. I've had many SR and KA cars and done it that way in the past. No luck this time.
Sfourteen
dct223 is offline   Reply With Quote
Old 01-12-2019, 11:13 AM   #5
mewantkouki
Trader Rating: (32)
Old 01-12-2019, 11:29 AM   #6
Mwknoerzer
Mwknoerzer is an unknown quantity at this point
My car will not enter timing mode. I have tried it about 20 different times over the past week. It is running an oem thermostat and warm while I'm trying to do it. Idle will not drop below 1500rpm with tps unplugged. There are no boost leaks, the system has been pressure tested to 20psi. I know the proper procedure to make the car enter it. I want to know if the datascan 2 software is compatible with a SR20det #62 ECU...
Clueless on the data scan but I was having the same problem idle not dropping below 1500 rpm on my ka and I had to set idle with the harness that went to my iacv unplugged, maybe itís worth a try.
Mwknoerzer is offline   Reply With Quote
Old 01-12-2019, 11:57 AM   #7
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
You need Nissan Data Scan 1 for Consult 1 based ECUs. The different versions are not backward compatible. Kind of frustrating since I have an S15 SR, an 06 G35, and an 18 Armada: 3 different versions of Consult.
So far I've had to buy NDSI and NDSII phone apps, luckily those are only $10 each. Just don't have all the features of the desktop versions.
I think I found a list once of Consult 1 software and played with them all. Don't have my laptop with me, but should be able to find with some google-fu. Some were easier to get running than others.
Like someone mentioned above, if you're having issues getting into timing mode manually, there might be another issue. You can check for pending codes and make sure all sensors are working with the free NDSI lite app, if you have android and the right USB adapter for the cable. Common ones are the neutral switch not showing you're in neutral, or not driving around for 15 minutes to ensure car is fully warmed up.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Copyright © 1998 - 2015, Zilvia.netô
