Old 10-24-2013, 07:31 AM   #181
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Originally Posted by Silviastunter View Post
Wow you have a really aggressive driving style it's dope though.
Aggressive as in fast? I guess, my car only has a stock sr w/t25 at 9lbs so I try to make up for the lack of power by holding down the throttle more.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 10-24-2013, 08:08 AM   #182
TeamFRAT
TeamFRAT's Avatar
TeamFRAT is an unknown quantity at this point
DIRTYlove
Originally Posted by 1on1 View Post
Dirty Love!
TeamFRAT is offline   Reply With Quote
Old 10-25-2013, 09:19 AM   #183
Nissansota240
Wanted to add a few more pictures and maybe some video if my friend ever uploads it.
And some more of the awesome track that is USAIR, damn I love this track.
Photos by this awesome dude
thepointlesseffect | Where Pointlessness Runs Wild
Drift Day 46 - a set on Flickr
DLG - DIRTYLOVE
Old 11-04-2013, 07:35 AM   #184
Nissansota240
Well the drift season is pretty much over up here in MN so the car is going back into the shop. Have a few ideas on what I want to do to the car to make it better for next year, but nothing set in stone yet.
Friend let me borrow her camera so I took a chance to snap some photos (instead of using my horrible camera on my phone) didn't edit them though
Some shots of the white s14 I picked up late last winter. In the process of getting winter tires, looking forward to having some fun this winter with this car again.
And something just wonderful happened this weekend. Had to swap the sunroof out of my blue car for now. Sometimes its nice having duplicate cars.
DLG - DIRTYLOVE
Old 11-25-2013, 07:26 AM   #185
Nissansota240
Did a few thing with the drift car. Diving into another winter filled with buying and building new parts.
Also starting to work on getting everything together to start making custom sunroof brackets, and fiberglass glass replacements. Had a buddy that was parting out an s14 that was crashed, so I told him I wanted the roof. That way when creating the fiberglass deletes I don't have to deal with trying to fab using my own car.
That's it for now, ordering the metal for the brackets this week, should be starting on fabricating them this coming weekend.
DLG - DIRTYLOVE
Old 12-02-2013, 04:34 PM   #186
Nissansota240
Also, I picked this up last Wednesday, exactly what I was looking for for this winter build.
Garret GT2860RS
Doesn't quite fit right on the stock manifold so it will need a custom waste gate bracket (maybe) and a 90 welded onto the outlet of the compressor to get the coupler farther away from the exhaust manifold.
Also popped the top of the sr for the first time, IDK looks alright to me, except for where the gasket around the coilpack/spark plugs leaked a bit. Unless anyone sees anything else wrong.
DLG - DIRTYLOVE
Old 01-13-2014, 12:11 PM   #187
Nissansota240
Haven't been able to do much lately on this car mostly because I wasn't to interested in heading out to the shop in the recent cold temperatures.
Ordered a few parts though to help with my power goals for this season.
Subaru sti Side Feed Injectors (520cc)
DIF s13 Bottom Mount Lines
Few other odds and ends
Last Saturday worked on mocking up the lines and figuring out how to extend the compressor housing. Installed the sti injectors as well. Will be hopefully getting the outlets welded up soon, a new wastegate bracket made as well.
Now with temps at least around or above freezing its a little more motivating to head out to the shop so hopefully be doing more updates.
DLG - DIRTYLOVE
Old 01-16-2014, 12:04 PM   #188
Nissansota240
Also got in my AEM UEGO wideband.
Recently been spending more time building some sunroof track delete brackets though. Created a new design for the s14 version and have finally had a chance to build the one for s13 coupe with power moonroof/sunroof.
Version2 of the S14 Bracket
S13 Coupe Bracket
Spent most of last night getting this figured out, would have been awesome if they where the same as s14, but everything is completely different.
Put a lot of work into these things despite how simple they look.
DLG - DIRTYLOVE
Old 01-16-2014, 06:55 PM   #189
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
I totally want one of the S13 coupe sunroof brackets!
@s13cole
FourtyKid is offline   Reply With Quote
Old 01-17-2014, 07:21 AM   #190
Nissansota240
Just let me know, I may try to make a couple more this weekend. I have a bit of down time while waiting for new parts to come in for the car.
Also a good friend just uploaded his recap video from Drift Days at USAIR this past season. Well worth a watch.
DLG - DIRTYLOVE
Old 02-03-2014, 07:00 AM   #191
Nissansota240
Was able to have a friend modify the compressor housing on the gt2860rs to work best with the bottom mount setup I'm running. Turned out great.
Was able to mount everything up, all lines hooked up except for one of the coolant lines, the DIF Bottom Mount line kit fit pretty great except for one line. I didn't like how it had a straight fitting that when hooked up would lay the line on top of the intake pipe. Will be switching to a -6AN 90* fitting to allow the best clearance.
Also while installing the STI injectors I decided to upgrade the fuel rail bolts to something less likely to strip out.
DLG - DIRTYLOVE
Old 02-10-2014, 12:17 PM   #192
Nissansota240
So I would suggest to anyone that buys the DIF S13 Bottom Mount line kit to modify the coolant line from the -6AN straight fitting to the -6AN 90* fitting. Makes the line kit fit so much better.
Other then that got the motor put back together, installed the Drift Freaq mounts with new heat shield.
The turbo setup looks pretty factory so far.
DLG - DIRTYLOVE
Old 02-10-2014, 02:19 PM   #193
89coupe666
89coupe666's Avatar
89coupe666 is an unknown quantity at this point
Any chance you have an open diff kicking around ? I live up in Thunder Bay Ontario but could come pick it up. Also me and a buddy from up here are going to try to hit as many events as possible down in MN this year . What are the most worth while events/ tracks in MN?
89coupe666 is offline   Reply With Quote
Old 02-10-2014, 04:16 PM   #194
Nissansota240
Nope, I got no spare diffs down here. As for events, there are only a few
Proving Grounds 2014.1 and 2014.2
Drifting - Autox - Drag Racing - Road Course- Car Show- Nightlife : MAPerformance Proving Grounds
There is also Powercruise, I've never been to it so I have no idea how that is.
Other then that, that is about all MN has to offer, I personally would rather drive to USAIR in Shawano, WI to drive the ClubFR events.
DLG - DIRTYLOVE
Old 03-10-2014, 08:34 AM   #195
Nissansota240
Plenty of progress planned for this coming week.
Got this in, hopefully the ps doesn't boil over anymore. B&M Supercooler 70264
Got some other cool parts in as well.
Relocated to a friends shop this weekend in hopes to have everything except painting aero and a tune done by next weekend.
DLG - DIRTYLOVE
Old 03-10-2014, 06:45 PM   #196
dftsilvia
dftsilvia's Avatar
dftsilvia is on the path to ruindftsilvia is on the path to ruin
love this build and car. so simple, yet so effective! great job
dftsilvia is offline   Reply With Quote
Old 03-11-2014, 12:20 PM   #197
Nissansota240
Thanks, yeah simple yet effective is always the plan with this car. I like to keep this thing reliable.
DLG - DIRTYLOVE
Old 03-13-2014, 08:02 AM   #198
Nissansota240
Slow progress but its something.
Had Full Blown Motorsports clean and flow test my injectors.
Got the power steering cooler setup done. Really like the way it turned out.
Ordered a CXRacing intercooler pipping kit, I ordered this kit mostly to get the bends, plus I won't be so upset to hack it up in order to modify it to fit my setup.
Made some progress on the intercooler piping but it was late, forgot to take some photos.
DLG - DIRTYLOVE
Old 03-13-2014, 01:01 PM   #199
Nissansota240
Forgot to add a pic
DLG - DIRTYLOVE
Old 03-17-2014, 07:48 AM   #200
Nissansota240
Some photos from this weekend.
Forcewerkz Navan Front and Sides with Kouki Rears, fittment is pretty spot on for the kit. Except my car had damage to the rear wheel wells so there will need to be modifications to the skirts to make them fit.
Intercooler setup is pretty much done except for adding the Blitz BOV. Took quite a bit of modifications, plenty of cutting and welding but have successfully turned the cx kit into a 4 clamp setup that can fit the tubs, and ic location.
DLG - DIRTYLOVE
Old 03-25-2014, 10:17 AM   #201
Nissansota240
Finally got the new flange for the the BOV so that got welded on, also added a nipple for the vacuum line that connects to the T fitting on the valve cover. (Will add pics once I head out to the shop again.)
Got the car started, found some leaks, fixed those, seems to idle pretty good. Currently still only have the SAFC2 but hopefully will be switching over to an Apexi Power FC in the next few weeks. But for now at least the car can move under its own power.
Also started on the side skirts, fitment for the forceworkz sides was pretty good on my white s14, not so much on my blue car (which had previous rear wheel well repair).
Sides need to be cut and extended to make fit.
Hopefully after all the work to fit aero on this car I don't blow them up right away at the track.
DLG - DIRTYLOVE
Old 03-26-2014, 12:44 PM   #202
ka-titties
ka-titties is an unknown quantity at this point
so the sides would have fit had their not been repair work to your wheel wells?
ka-titties is offline   Reply With Quote
Old 03-26-2014, 01:01 PM   #203
Nissansota240
Yeah, doubt I would have to do much trimming to get them to work on the white car. Front looks off a bit because a ziptie holding the wheel well in is pushing on it a bit.
DLG - DIRTYLOVE
Old 03-31-2014, 07:55 AM   #204
Nissansota240
Made a tad bit of progress this weekend.
Picked up a Apexi Power FC so now I can get rid of the SAFC2 I was previously running.
Also my friend made some progress on the sideskirts, almost ready to prep them for paint.
DLG - DIRTYLOVE
Old 04-07-2014, 10:14 AM   #205
Nissansota240
Got the Power FC installed and the car up and running now. Also cleaned up and made some room in the shop.
DLG - DIRTYLOVE
Old 04-15-2014, 04:07 PM   #206
Nissansota240
So while setting up the pfc during idle I notice that the car was having a vacuum leak.
Ended up pressure testing the system and found a leak at the IACV hose, BOV, manual boost controller, and the compressor housing of the turbo.
Swapped in another Blitz BOV that a friend had laying around, ended up just getting rid of my manual boost controller, got a new clamp for the IACV hose, and had a fun filled day of removing and resealing the compressor housing. Although I'm happy to say that now I have no more vacuum leaks.
Engine hoist worked out well to hold the manifold since I was the only one in the shop all day.
For the most part the engine bay is finally buttoned up, may add an adjustable fpr setup but that's about it.
Now all that's left before I can take the car to Drift Days is to finish/prep/paint the aero and to get the car tuned. Safe to say I can't wait to just drive this car instead of working on it all the time.
DLG - DIRTYLOVE
Old 04-15-2014, 08:38 PM   #207
TonyToniTuna
TonyToniTuna's Avatar
TonyToniTuna is an unknown quantity at this point
I love your build man! Keep coming with the updates!
Question: Where are you running your wastegate vac line too? I am curious because
it does not look like you have it plumbed into the hot pipe and am debating on how to run mine without plumbing into the hot pipe.
TonyToniTuna is offline   Reply With Quote
Old 04-15-2014, 08:46 PM   #208
Nissansota240
Thanks dude,
I actually bought a 1/8npt aluminum bung and welded it onto the hot pipe right before it makes its bend towards the headlights (its on the bottom side of the pipe, not really visible) then just put a 1/8npt to 4mm hose end fitting in.
DLG - DIRTYLOVE
Old 04-21-2014, 06:43 PM   #209
Nissansota240
Made a change for some rims that fit my stock bodied chassis a little better.
Wish they where the real things but there are more important areas to spend my money on this car before I dump money into rims. Will be painting them as well.
DLG - DIRTYLOVE
Old 04-21-2014, 07:51 PM   #210
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
do you guys sell the dirty love stickers? i kinda want one for lols
vJilly is offline   Reply With Quote
drift, minnesota, s14, zenki
