Old 05-01-2017, 12:26 PM   #1
MEFISTO
MEFISTO's Avatar
MEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of lightMEFISTO is a glorious beacon of light
Arrow [STAGE 2: 1JZ VVTi Swap - S13 240sx Convertible] - Los Angeles, CA
Alright, after a few months i finish the Stage 2 - Engine Swap
so here are the pictures from the whole journey
If you didnt saw previous stage..check link below
Link: * [S13 240sx Convertible - Stage 1: Restoration] (body/suspension/engine)
Link: * [S13 240sx Convertible - Stage 2: More Power] (engine swap)
Link: * [S13 240sx Convertible - Stage 3: New Look]
This is the transformation you gonna see in this thread
- UPDATED SPECS -
1JZ VVTi (stock harness)
R154 Transmission
Kakimoto Racing Hyper Full Mega N1
Odyssey Fab Turbo elbow/downpipe
D-MAX D1 Spec Coilovers
350z Seats
Ichiba 5-lug conversion (front/rear)
Q45 Brakes (Drilled, Slotted and Vented Rotors)
DMAX smoked Tail Lights
OEM 180sx Sideskirts
Sneakers:
front Sumitomo 245/40/R18
rear Bridgestone 255/40/R18
.... And more
Alright, this is my 1992 Nissan 240sx Convertible (some of you may know this car from prev owner)
i bought it on February 2016 and start to get her beauty back
This is my first time working on a car, (i was focusing on restoring old school BMX bikes) so
everything here was new to learn.
Believe it or not all this is on a budget, from tools to engine parts
trying to spent LESS possible without compromising quality
DO IT YOURSELF...to save money and LEARN
in the process (and that's priceless)
Google and YouTube will be your best friends from now on
if you notice i post too many part prices is because i want you to see that you dont have to be rich to
do all this.
This is not about being cheap... is about to being Smart
STAY UPDATE !! like and subscribe :P
Youtube channel:
https://www.YouTube.com/FollowJulian
Instagram: iFollowJulian
MEFISTO is offline   Reply With Quote
Old 05-01-2017, 01:30 PM   #2
MEFISTO
MEFISTO's Avatar
Just bought some more horses!
Picking up!
New Engine.. 1JZ VVTi (JZX100)
2.5L Turbo 280hp stock
some parts of the Puzzle here
forget about horse power.... Cat Power FTW
New Fuel pump, Deatsch Werks DW200
R154 transmission (Toyota Supra)
needs JZ bellhousing and shifter extension for S13
already have my Christmas R154 Snowman!
checking gears
R154 are really heavy duty transmissions
Yep, im a sick motherfuc*er
Aluminum parts on car are intended to be light and cooler
if you paint them u are taking that property off.
But.. i paint this anyway
Removing all the things i wont be using it
im a newbie on this so i better LABEL EVERYTHING !!
i have to remove the A/C
i will put it back in some near future
downpipe Out!
Valve covers out!
it came with an US waterpump from Japan, but unbranded, so i better change the front/back complete for an OEM
Here is when the Freak starts making beautiful parts again.
If you do a really really good masking..you dont have to take all apart (see the tape inside housing?)
Another part that must NOT be painted..oh well
Removing tape
Intake manifold is out!
This small oil filter sometimes gets dirty, better take a look while u can
The injectors had the seals/insulators worn
and they have an specific shape that fits,
luckily i found new seals and o-rings (Viton made) u can get them here:
http://www.ebay.com/itm/282325188402
Aluminum gets dirty very easy..the only best way to get the original look is sandblasting it...so lets go
After sandblasting!
Old 05-01-2017, 01:31 PM   #3
MEFISTO
MEFISTO's Avatar
Here is a good example of why u should sandblast aluminum parts.
50/50
Before
After
After having the aluminum clean, is better to tape so dust/dirty hands doesn't fuck your work
had valve check and groomet missing
1JZ VVTi ISC Valve Check Part# 25748-88400
Grummet Part# 90210-25001
Done
And taped
New Viton seals for the Injectors!
And all together finally!
Stock R154 housing needs to be extended to fit 240sx shifter hole in place. So i found this place in Florida who does that and better pricing than here in CA
Here is what they did... very nice
and i order the Downpipe for the turbo also from them
Fully open, not restricted = More power
Another part to get sandblasted
tape ALL so u have to work less to clean later
and.. here is it
Everywhere i look i found new pieces to clean...
i found that gasket where pretty good..for now i will use them, i will get new ones in the future
Valve covers back together
and more taking apart
Before
After
All back together
Needed some studs for the O2 sensor..
i went ACE Hardware and found some (short)
Because i wanted a clean engine bay look, i cut the water neck so i can use a straight hose to Radiator
Because my harbor freight welder is not THAT PRO (maybe my pocket is not that pro) to weld Aluminum, i have to get someone to weld this like that
Found someone...and done!
and then of course.. Sandblasting !
lmao
Old 05-01-2017, 01:33 PM   #4
MEFISTO
MEFISTO's Avatar
Started needed some refresh
Turbo heat cover needed some love also
All parts needed for this Swap, mostly i got from eBay ... yes i bought all at eBay and save, all OEM Toyota/Lexus sealed boxes and HALF price
(if you are ignorant don't read that)
(missing Driveshaft and Rad fans in photo)
1JZ VVTi Turbo elbow (OdysseyFab)
Pilot bearing, throwout bearing and clutch aligment tool
Aisin Toyota OEM Pressure plate
Sometimes is better to keep it OEM
(when money is short)
Toyota Oem Clutch
Toyota Oem Flywheel
Trans didn't came with Shifter, i found OEM one on eBay.
Shifter housing extension and shift linkage made
and Marlin Crawler Urethane Shifter Bushing + Nylon Shifter Marlin Crawler Socket
R154 to 1JZ Bellhousing
NTN Timing Belt tensioner
ARP Flywheel bolts
1JZ/2JZ vvti US Water Pump
US Pulley Part# 16371-46020
Aisin Clutch Slave cylinder
Toyota Oil Filter
Mishimoto thermostat 68c
Timken
R154 Transmission Intput Shaft Seal
R154 Transmission Output Shaft Seal
HKS (really?) Air Filter
1JZ VVTi Timing Belt tensioner idler
Toyota Part# 13505-46070
Timing + Serpentine Belts
Stinger Distributor Block (Battery Relocation)
Fuse Holder + 250Amp Fuse
Facebook used Intercooler
eBay Special, Universal 2.5'' inch intercooler piping 12pcs
Made in California
and found a Dual Flex-a-Lite Fans
Putting pressure plate and bearing together
Old vs New
All Done!
i got these mounts included with engine deal
He told me they are from Suspicious Garage
they look soooo clumsy that i go ahead and did a lot of welding on them
(Update: to fit engine in the right place i had to make new holes/sliders on these mounts)
Block needed some refresh!
[IMG]https://lh3.googleusercontent.com/biENyXw77bor3HAjdwKQMxoCleCRDbyShZN42l1S-vOjlEHe0vJu-vVAGvLOXUOlrnYUcRHQEEqFykRLTlLvbMbNqS6PsjYSSUwnDVe EVnNbP8ATsZN-tHhb-W0AqvonJsVSM3zT6UT18Z5nbj3ITRX3H4vdkf_MrfEJkBAlIBz XB70qMwXS7NMW1Kkx5QRK_QGrx-g4AaxLM3tGy95l_Fv9Fc7LTZxSm2PXMXipxiNMlB7JdziXutaX Q_dsnwX4PC_bBV8PShjSrG1PSiwh-Hg74RxTK8QNDTXkMdogCeqDUTgvaTyk1IR7gVBmm4CFsBJOeif gT7aJGIX6d7_NX7Du9nHUmGxqhpEGBQtZv9Pua1KVB8Rs1Te1c oNPMy5eUMw83yXRiQ-lsmU_Bcd6tkTH9O0dzDmM7NE_oMLmhOXOu8DeYZL1GDhzQhQj6 k3nf8-CAn1nWnAc7Osl_OQ7pgJJUS5met-s-ph-yI31Al5CM7QmUIattBlOD158FCWjr9OtHQ4OFMcOQ7EtQmYbOH nSw1Jb5CFAMv5Kp1hn-kW7X3hOyjsJi9viB_l-ER7QJfLVoPKU8EUKXX8xpYpSXQN6_iA7XsipB8ldi4oiigHVl1 BknMrK=w1212-h909-no
Old 05-01-2017, 01:34 PM   #5
MEFISTO
MEFISTO's Avatar
Now the fun starts!
must put this puzzle all back together!
Looking good..
LOOKING REALLY GOODDDDDD!
and now the day has come.. KA24DE will be OUT!
without this guy none of this would have been possible that fast. THANKS Steven!
extracting her soul
i was waiting this momment to tuck this wire harness
the only problem is that Verts came with these Arms right in the place u have to cut
i manage to cut and make it work, hoping wheel not rub later
Done
About engine bay.. Take all what dont need OUT
Cleaning
remove all
Masking
R154 need some clearance in trans tunnel
u need some help to make it
Starter side + upper side hammering
Cover holes that you dont use to make bay cleaner
i used JB Weld Metal putty, and then sand it
i used JB metal putty
i tape (actually hold with finger) and apply putty
After dry
masking hood to paint!
Base color
Ready to paint base color
White as a base color.. which color will be ?
R154 + 1JZ VVTi about to get married
R154 + 1JZ VVTi finally together
#r154 #1jzvvti #1jz
Yup, engine bay is going PINK....because California bro!
Old 05-01-2017, 01:36 PM   #6
MEFISTO
MEFISTO's Avatar
Best way to 'tape' is with metalic foil, it shapes perfect and easy to remove
Ready to go IN !!
Fuc*ing engine mounts...not only were welded as shit, also out of square, i had to make new slots and work on fitment
engine is IN now..for 1 day
Transmission wont shift so i had to took it out and fix that, it was out of sync and then i manage to lock it on reverse, damn
After found i made the mistake removing bearing before taking housing off...i fix it
moved shaft back again to neutral and locking with ball.
Inspection covers for R154 are expensive AS... so i made my own
and they came out pretty cool
fitment is great
and painted looks better
look oem (from 5mts far)
Alright, all fixed and getting ready to put engine back again
Making wiring slim to fit behind block
Removing paper tape cover
Kakimoto 1JZ pipe for S13
i have to work on making an extension now
Fuel lines are not Heat friendly
Old 05-01-2017, 01:37 PM   #7
MEFISTO
MEFISTO's Avatar
because fuel line are not heat friendly..i took the cat heat shield from stock KA ..cut and make some shield for the other side
way better
Battery Relocation... beta test
Fuse box + 250A fuse
Battery Relocation... Final
Gauges are here!
Cheap and Good !!
8awg from fuse box to power block
4awg black wire from Starter to power block
stock KA24 fuel lines can be bent by hand
Making Fuel lines routing
Done, way better than having rubber hoses lines around the block
making a heat shield for the fuel lines next to the downpipe
My Harbor Freight welder melt that plate, so i had to make that patch and weld it like that
Painted High heat paint
Testing Fitment.... Good!
Next: Themal tape EVERYTHING
Finally draining the oil
There is no enough room to place my dual fans without cutting everything...
i added the rubber to make it seal better as a pusher on front
so i went Pusher side (i ordered pusher blades)
The air flow power on these is impressssssive
now i have plenty of room
More seal and less vibration
Mounting the Intercooler
Testing..
Piping
Hole from intercooler (ex battery place)
now intercooler fitment
and this is how shifter sits
i need 3 new gauges so i have to make my own plate
measurements
Old 05-01-2017, 01:38 PM   #8
MEFISTO
MEFISTO's Avatar
testing
done
So..because i have to solder many wires at the harness, i wanted to make it better so i went to the Junkyard and got many wires in different colors AND.. a lot of factory Plugs so i can make it easier to remove ECU/Harness in the future
my Work station
Lunch at work station lol
My wire harness came pretty hack
i will use this plug (one of them) to join harness with ECU
something like that
starting looking gooood
and voila!
Finished
Super finished!
Last step... get downpipe with exhaust together
and... F I N I S H E D
Old 05-01-2017, 01:40 PM   #9
MEFISTO
MEFISTO's Avatar
here is a video of the car revving, running, pulling!
http://www.youtube.com/watch?v=-MRJLtIp6q8&t
Old 05-01-2017, 04:52 PM   #10
Ken1222
Ken1222 is an unknown quantity at this point
This. Is. Awesome. Video/sound clip soon?
Ken1222 is offline   Reply With Quote
Old 05-01-2017, 05:36 PM   #11
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Polished intake pipes, radiator, and pink bay aside, I'm actually impressed at how factory this looks in your car.
-Jspec-
Instagram/CrimsonRockett
Old 05-01-2017, 05:49 PM   #12
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
I miss my 2j/Vert now ::sad panda face::
**Just move your fuel hard line to the driver side
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 05-02-2017, 10:29 AM   #13
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
Very nice, love that a vert is getting some real love!
tb13 is offline   Reply With Quote
Old 05-02-2017, 10:46 AM   #14
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
Super clean, nicely done.
On that last pic, why does the engine look like it's in crooked? The rear of the engine looks centered on the firewall, but the front of the engine appears to be pointed towards to passenger side. Or maybe it's a weird optical illusion from the camera angle.
jaysgottaredtop is offline   Reply With Quote
Old 05-02-2017, 11:18 AM   #15
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
Shifter also looks offset towards the driver's side; I believe you're right
crash n' burn is offline   Reply With Quote
Old 05-02-2017, 11:20 AM   #16
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
looks good man keep it up.
Old 05-05-2017, 11:51 AM   #17
MEFISTO
MEFISTO's Avatar
VIDEO IS UP !!
more videos comminggggggggggg
Thank you all for the comments
even with the pink looks pretty oem lol
45 days i did the swap with my friend, full detail
I did not feel like doing it so i made the shield plates
300z came from factory with lines next to the exhaust manifold, covered by just with a shield
Maybe in the future i will..is way better i know, but too much work as i dont like using just rubber lines
yes! because the fuc*ing engine mounts brackets, i got them with the swap deal
then i found out they were weld out of square..
and it was worst, just i made new slots so i can get engine sitting properly
Old 06-17-2017, 02:15 PM   #18
MEFISTO
MEFISTO's Avatar
Some mechanical update !!
Starter doesn't start when i want, so i take it apart and see whats wrong with it.. found a lot of Carbon so i clean it
(it wasn't carbon issue, added more grounds..still having the issue, it may be the key ign cylinder)
After some love.. all clean (starter works on floor every time, but sometimes fail into car, still looking for answers
Installing the sensor for the gauges (Oil pressure)
Remove the OEM sensor (next pic) and u need to put this adapter: 1/8-27 NPT Female to 1/8 28 BSP Male (silver one) and then u can screw the AutoMeter one
the one to remove:
Water temp gauge... this is the water neck with both OEM sensors, i remove the small one which is the gauge sensor and need to put the AutoMeter one in same place
Oem sensor is metric, so u need to tap the hole to get the new one
(Thank you Steven's dad!)
And this is how it looks after
All 3 mechanical gauges hoses in the same hole
(Boost - Water temp - Oil pressure)
new Upgrade! J30 VLSD Differential
for S13 u need 95/96 Infiniti J30 differential
they come 6 bolts (use your stock axles), u need to swap the stock S13 diff cover, get solid bushings (front mount only) and longer bolts (M12 x 1.25, 85mm long) and 2 washers
(info from www.ka24development.com)
Removing old bushings
Taking stock diff out
removing cover so i can use with J30 diff
Left side J30 VLSD - Right side S13 stock open diff
Getting the S13 cover into J30 diff
Adding juice!
This is the stock S13 bolt, after placing the solid mounts bolts get short, u need longer
This is the new bolt, M12 x 1.25, 85mm long, and get 2 washers for it
All done and ready to install
Going in !
Old 03-02-2018, 12:27 PM   #19
mattro
mattro's Avatar
mattro is an unknown quantity at this point
man i love this, very well done. makes me want to go out and buy another sx.....
grip like roots, float like leaves.
wtb s13 sus.
mattro is offline   Reply With Quote
Old 03-02-2018, 01:56 PM   #20
MEFISTO
MEFISTO's Avatar
Thanks !!
if right now u can have all the planets aligned (money/time/space) go for it !
Old 03-02-2018, 03:28 PM   #21
MEFISTO
MEFISTO's Avatar
Alright... i was having Temp issues so i did A LOT of mods to fix it !!
SOLVED: Issue was.. i was using Mechanical Temp gauge and wire was kinda close to the turbo
so every time i hit the gas hard, turbo got hot and wire shows high temp reading to the gauge inside.
i changed Water temp gauge for a Electronic and done
(ay ay ay Julian...)
so all these mods next were intended to fix the FAKE temp issues
bought a new Radiator cap!
higher pressure, nothing changed but i improved quality
Went to the junkyard and got temp sensors and Volvo relays because they are the besttt
got many sensors so i can chose which one has best low/high temp switch
Setting Volvo relays + BMW coolant sensor (P/N 1378073) with 420 Flex a lite fans
Sensor kicks FAN1 when hit 91c(195f) and kick FAN2 when hit 99c(210c)
Champion radiator, i paid $110 eBay, is working awesome and has Lifetime warranty
Bought some Water hose adapter (36mm) on eBay for $5, did a bigger hole and for M14x1.5 thread (bmw sensor)
Part # 1 378 073
BMW Dual Temp 91c / 99c
Volvo relays installed
did a bigger Air Filter lower hole to get more fresh air
(yes, thats a home A/C pipe but fuc* it)
Wrapped Mechanical water temp gauge wire in heat shield tape
because it was too close to the Turbo and Downpipe so i was getting wrong numbers
Now modding Rad support to move radiators from Pushers to Pullers
Welding piece of metal underneath to keep strength
as u can see here
Bending lip
Finished
Found these Radiator brackets at Junkyard from a Volvo 240 and i really like them to use
i just need some mod to make them fit
cut some rubber parts
Volvo rad brackets are too long so i need to cut and make them short
ok... lets cut these
testing them short
welding..
Done!
both finished
now i need them to look better
primer, sand and paint next
Now lets bring the beauty back to the radiator support
Bondo ALL
After sanding a lot to get same surface level
Painting....
http://www.youtube.com/watch?v=gBvq1OF-qMU
Done
Ready to clear coat
This clear is awesome, wish i had found this before
you can be generous and it won't run !
Testing fitment
Testing the volvo brackets
Making moves, i mean holes..
and done!
Old 03-02-2018, 03:28 PM   #22
MEFISTO
MEFISTO's Avatar
All finished!
Since i got the engine i was looking for these part,
you from Ichiban JDM... Thank you a lot again !!
Now it breathes more air and it looks way better
Now is finished and working PERFECT finally
actually..it worked perfect always, it was that Fake issue
Old 03-02-2018, 03:33 PM   #23
MEFISTO
MEFISTO's Avatar
Latest videos of the car
http://www.youtube.com/watch?v=7H9jHF3xgEI
http://www.youtube.com/watch?v=xJahLBE8Bv4
Black Cardinal brand took the car for promotion videos
http://www.youtube.com/watch?v=Pf5TITpVPjg
Old 03-05-2018, 09:51 AM   #24
codyzsilvia
codyzsilvia's Avatar
codyzsilvia is an unknown quantity at this point
I love this build! This is what perfection looks like!
codyzsilvia is offline   Reply With Quote
Old 12-31-2018, 11:15 AM   #25
cole d
cole d is an unknown quantity at this point
Did you ever fix your starting issue?
cole d is offline   Reply With Quote
