Old 10-21-2018, 11:41 AM   #1
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Replacing fuel line S14: My question is what kind of fuel line do I use?
Things I know:
Diameter 5/16"
Things I don't know:
  • Do I need fuel injection line?
  • Does it matter if it can be submerged in fuel if I only plan on doing the lines to the tank?
Why I am doing this:
My S14 has the dreaded fuel tank crack curse.
I've replaced it and the gas tank I dropped in is cracked as well.
Now I'm getting ready to replace the tank again as well as any fuel lines that look questionable.
What I have on my list of things to purchase so far:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
https://www.amazon.com/gp/product/B0...GFTUYR30&psc=1
Old 10-21-2018, 12:05 PM   #2
Kingtal0n
Kingtal0n's Avatar
I used -6an braided w/ hose clamps
Just short runs from the top of the tank to the factory size hardline
supports approx 750hp forced induction application
Same thing on the other end. I prefer the long-runs of fuel line to be hard steel (safety and reliable) and if possible make the short runs easy to access, leave a little bit extra in case you mess the end up and need to re-cut it again.
-6an is pretty cheap now $2-$3/foot so it was only around $10~
If you are not going to use braided hose, make sure whatever you buy is Ethanol compatible, and will stand up to 100psi~ or so.
Old 10-21-2018, 12:13 PM   #3
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
5/16 fuel line will work fine. you do not need fuel injection line (its for higher pressure newer fuel systems and is much more expensive) just make sure it is rated for fuel
fuel line can be had by the foot at any parts store. I wouldn't buy it online cause you have to buy a whole roll
The Game
you lose haha
kyral is offline   Reply With Quote
Old 10-21-2018, 12:58 PM   #4
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
sounds like I have an amazon order to cancel
Old 10-21-2018, 02:19 PM   #5
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Track tech inspections require SAE J30R9 (or better) fuel line for a reason.
Use J30R7 only if you want your lines to seep and set your car on fire.
dbeiler is offline   Reply With Quote
Old 10-21-2018, 06:54 PM   #6
jr_ss
If you're doing any type of SS fuel line replacement, spend the extra money and get the teflon inner lines. You will not have the fuel smell seep through the lines with this route. -6an will support plenty of power for most, however the fittings are typically where the restrictions are(smaller ID). If you have any plans for E85 and big power, go with -8an.
Old 10-21-2018, 10:40 PM   #7
Kingtal0n
Kingtal0n's Avatar
What am I missing here. Why would anybody pay more than $3/foot for line that has weaker properties than 1000psi ethanol compatible braided hose.
Better yet, why would anybody use a non fuel injection hose on a fuel injected car. Or or any car for that matter.
I.e. if I have a carb'd fuel system running at 3psi and I know that I can get away with line rated at 3psi, why wouldn't I not use the highest possible quality line anyways since I was changing the line anyways?
The only reason I could see to use the cheaper line is to save $$$
but seriously, saving how much $$ for is worth safety in the fuel system? I am better off with the fuel injection hose even in a 3psi system because it is truly stronger and more reliable. Its the same for any other car part- yeah they sell cheap brakes, cheap plugs, cheap whatevers. But how much $$ is it worth the savings for a part that I only change once every 10-20 years?
Old 10-21-2018, 10:53 PM   #8
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
what the fuck are you crying about? are you saying those stainless steel lines with hose clamps (what i've always considered to be knock off -6an lines for people who can't afford -6an and want the -6an "look") to be capable of 1000psi and ethanol compatible?
i've never looked into those "knock off -6an", so how bout you post links to actual discussions of this, instead of your blah blah hissy fit.
are you saying those "knock off -6an" lines are better than SAE J30R9 hoses?
240KA is offline   Reply With Quote
Old 10-22-2018, 12:37 AM   #9
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Okay the one I posted has that sae rating so imma buy it...
Old 10-22-2018, 01:57 AM   #10
FRpilot
FRpilot's Avatar
I had to replace the fuel tank on my s14 a few months ago too to fix an evap code (discovered a leak/gasoline stain after dropping the fuel tank). I was considering changing the fuel lines too, but was given the advice that factory fuel lines don't usually fail and upon inspection they seem to be in good shape so I just swapped them over.
Anyways, I did find this thread while doing research that may be useful to you too and gives some insight on those SAE 30Rx ratings.
http://zilvia.net/f/showpost.php?p=3489824&postcount=18
FRpilot is offline   Reply With Quote
Old 10-22-2018, 07:21 AM   #11
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
awesome i'm in the same boat thinking of what i need right now. great thread
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-22-2018, 11:32 AM   #12
kyral
kyral's Avatar
I see a lot of fearmongering, the only thing that concerns me about fuel lines would be, i see someone mentioned track inspections and them requiring a certain rating of hose. (and ofc e85 is a no go with regular fuel lines)
other than that at 40 psi any fuel hose will do, they wont leak they wont seap idk where this is coming from. i run basic fuel line on all my cars and never had a leak
and my s13 stopped smelling of fuel a long time ago
The Game
you lose haha
Old 10-22-2018, 01:27 PM   #13
slider2828
slider2828's Avatar
Why not just do it once and do it right? Teflon lines fuel injection hoses.... Its such a pain to change them out.... just leave nothing to chance.
Turn and Burn!
Old 10-23-2018, 01:54 PM   #14
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
That's what I've done to my s14. I used teflon FI hoses and got them at oreilly and autozone a few years back (i think the brand was goodyear). Looks like a standard fuel line but it has a inner hose (usually black or blue colored).
instagram
1on1 is offline   Reply With Quote
Old 10-24-2018, 02:43 PM   #15
Kingtal0n
Kingtal0n's Avatar
this is what im saying. Instead of trying to meet the current demand (3psi for example) just use the best possible thing so you only have to do it once. that is all I said.
Old 10-24-2018, 02:52 PM   #16
slider2828
slider2828's Avatar
Totally man.. I was just talking to the other posts.... And if you go to the track, fuel is not something to f around with if you have a big crash or run the rear end into a wall.... Unless you don't mind losing everything
Turn and Burn!
Old 10-28-2018, 01:01 PM   #17
fitbmx180
fitbmx180 is an unknown quantity at this point
I used vibrant -8 an fuel line and -6an for return. That is more than enough
fitbmx180 is offline   Reply With Quote
Old 10-28-2018, 04:53 PM   #18
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
https://goodyearrubberproducts.com/2...s/page0032.pdf
For oem applications, I like to use this stuff. The nitrile inner liner makes it safe for e85 also. also for fuel injection clamps use oem clamps, I never have good luck with the aftermarket parts store crap. I also like to use pinch clamps for rubber hose applications as they're more secure, but it does require a tool to clamp down. They're also limited in range.
https://vibrantperformance.com/catal...99a911d4f8ce34
@adamcs14
NiSilS14 is offline   Reply With Quote
Old 10-28-2018, 09:42 PM   #19
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I didn't have to replace any lines this time around had a pinky sized crack in the tank though...
Old 10-30-2018, 07:11 AM   #20
s13silvia123
you can get those crimp clamps from home depot, menards, lowes, etc...in the plumbing section. those are also used for pex. way cheaper than what vibrant sells them for. a pex crimp tool will cut or crimp the clamp.
Old 10-30-2018, 12:16 PM   #21
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
we just used that good year hose on my buddies 89 dodge and it came out great. it replaced all of the hardlines that were rotted out. it was very easy to cut and get it all situated in place. I also believe my father uses this hose (or some similar form) on the sprint car he works on. he sells a lot of it at the hot rod store he works at and cant say enough good things about it.
jumpman2334 is offline   Reply With Quote
Old 10-30-2018, 12:50 PM   #22
NiSilS14
I actually haven't ever used vibrant for the crimp clamps, it was for illustration purposes. Sometimes with home depot, I've noticed the clamps fall in between diameters with certain size fuel hoses since it's marketed toward pex plumbing.
@adamcs14
