Old 01-06-2019, 01:12 PM   #1
lflkajfj12123
USED - Tanabe Revel 52mm Digital OLED Wideband Air/Fuel Ratio Gauge
USED - $200 Shipped
This gauge was in perfect working condition before pulling it off the car. Comes with the bosch sensor, gauge, all wiring, and cord for data output for tuning. If you don't already have a wideband you will probably need to by an o2 bung to weld into your down pipe or exhaust.
DESCRIPTION
Tanabe's 52mm Digital Wideband Air/Fuel Ratio Gauge is one of the highest quality AFR Gauges on the market today, and a DSG Favourite. The Revel VLS 52mm OLED gauges are top of the line for accurate and dependable monitoring of vital engine components, such as AFR. Tanabe utilizes the best in sensor technology with the included in the box LSU 4.9 oxygen content and Lambda value sensor in the 52mm Wideband Air/Fuel Ratio Gauge. While many aftermarket wideband gauges are still operating on the older, inaccurate sensors OE manufacturers and Tanabe have made the switch to LSU 4.9, the new standard. which is also compatible with gasoline and E85.
Using modern OLED displays (Organic Light Emitting Diode, much like your smartphone) maximum comfort is attained on the numerical display. When compared to a traditional LCD display, the OLED display provides sharper contrast resulting in a deeper black for a crisp, clear images that is easier to read at a glance.
What does this mean? No eye strain, easy reading of the gauge in all times of day and all types of light. The technology also allows for undistorted viewing angles approaching 170 degrees, so no matter where you are seated in the car or what angle you are viewing the gauge from, you can see it perfectly. The OLED display also does not require a backlight to be clearly visible at night, which gives the slim profile of the gauge -- perfect for mounting in areas where space is an issue.
Old 01-07-2019, 09:57 AM   #2
lflkajfj12123
bump to the top
Old 01-09-2019, 04:12 AM   #3
lflkajfj12123
Bump to the top
Old 01-09-2019, 11:58 AM   #4
lflkajfj12123
Bump to the top
Old 01-10-2019, 07:34 AM   #5
lflkajfj12123
Taking offers!
Old 01-13-2019, 10:17 AM   #6
lflkajfj12123
Bump to the top! Make an offer
Old 01-23-2019, 11:55 AM   #7
lflkajfj12123
bump to the top
Old 01-30-2019, 09:25 AM   #8
lflkajfj12123
$150 shipped bump to the top
Old 01-30-2019, 12:29 PM   #9
lflkajfj12123
Sold thanks for looking
