Old 12-16-2018, 03:06 PM   #1
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
SR20 broken rocker = more problems
Having an interesting issue with my SR, its a s13 redtop. A couple of nights ago I managed to shatter the exhaust rocker arm on cylinder 4. I replaced the rocker arm with a new one and reassembled everything. When I started it back up, it ran like shit and after unplugging coil packs I found that it was only running on cylinders 2 and 4 (the one with the rocker I replaced). Cylinders 1 and 3 when unplugged did not affect the motors running.
I checked compression and I had 155 psi on cylinders 2 and 4, but literally 0 psi on cylinders 1 and 3.
When I crank the engine by hand, there’s no noise or resistance of a piston contacting a valve, however the starter has a hard time cranking the engine as it’s cranking noticeably slower and less smooth than before.
I’ve checked mechanical timing once, and I’m typing this as I’m doing it again to be sure, but I’m stumped and if there’s any input about this that’d be greatly appreciated. Thanks!
nisileighty is offline   Reply With Quote
Old 12-16-2018, 07:00 PM   #2
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
I don't suppose you have a leak down tester, do you?
Sent from my SM-G930P using Tapatalk
[240sx] is offline   Reply With Quote
Old 12-17-2018, 07:25 AM   #3
TheRealSy90
TheRealSy90's Avatar
Hate to break it to you but sounds like the timing was off and bent some valves possibly.
Such a good signature.
Old 12-17-2018, 09:07 AM   #4
jedi03
+1 on bent valves...how did the rocker shatter?
Old 12-17-2018, 09:29 AM   #5
TheRealSy90
Also the dead cylinders could have gotten bent valves when the rocker broke, not that you assembled anything wrong when you fixed the rocker.
Old 12-17-2018, 09:52 AM   #6
nisileighty
So when the rocker breaks, can that somehow throw the timing off? I was under the assumption that on the cylinder the rocker breaks, the valves will immediately close. As for the other cylinders, I couldn’t think of a reason that one missing rocker would cause the timing to be thrown off enough to contact a valve.
The rocker shattered under hard driving/high rpms. Tapped the limiter once and it went. It’s an ignition cut at 7k, and I’ve never spent much time on the limiter, a tap or two at the most in second when I drive the car hard which isn’t often.
Old 12-17-2018, 10:09 AM   #7
TheRealSy90
It really shouldn't have. Signs are leading to the mechanical timing being off when you initially cranked it after the repair. The starter has enough torque to bend the valves if they contact.
Old 12-17-2018, 10:25 AM   #8
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Timing can be off from your reassembly process, I've done it before
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 12-17-2018, 11:53 AM   #9
nisileighty
Alright, that’s definitely a possibility. I’ll get the cylinder head pulled today and let you guys know. Thanks!
Old 12-17-2018, 12:18 PM   #10
nisileighty
Here’s a pic of the rocker. If anyone is interested lol.
Old 12-17-2018, 01:12 PM   #11
TheRealSy90
I just wanna say if you have rocker arm stoppers go ahead and remove them now. And look into doing dual rocker guides.
Old 12-17-2018, 03:02 PM   #12
nisileighty
Never believed in rocker arm stoppers actually helping so I never installed them. I also plan on doing the dual guide conversion.
Old 12-17-2018, 03:15 PM   #13
snafupossum
snafupossum is an unknown quantity at this point
Did you over rev the engine? Like accidentally shift into 2nd instead of 4th on the freeway? Sounds to me like the engine spun too fast causing that rocker to break and make others valves kiss pistons?
snafupossum is offline   Reply With Quote
Old 12-17-2018, 05:48 PM   #14
nisileighty
Nope, literally turned out of my neighborhood and got on it in second from 25ish mph until redline. Kissed the limiter once and took a shit. Ran and idled funky and there was a super loud tick. Pulled the valve cover and the rocker was just sitting in two pieces.
Old 12-17-2018, 06:28 PM   #15
slider2828
slider2828's Avatar
Is it this easy?
http://www.youtube.com/watch?v=StxF9aLMoSg
Do you just grind outter side of the arm?
Turn and Burn!
Old 12-17-2018, 06:58 PM   #16
nisileighty
Old 12-17-2018, 06:58 PM   #17
nisileighty
No signs of piston/valve contact.
Old 12-18-2018, 04:41 AM   #18
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
thats no way to tell if the valves are bent or not. there's a your video on how to tell if they are leaking or bent.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 12-18-2018, 04:55 AM   #19
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Pour some acetone or similar and see if it leaks out. If it does, valves are bent. Unless bent significantly, the naked eye cannot tell if the valve is sealing or not.
Old 12-18-2018, 07:56 AM   #20
jedi03
also put spark plugs back in or will leak real fast lol, additionally what is between the valves in your first pic of the head?
Last edited by jedi03; 12-18-2018 at 07:56 AM.. Reason: needed to be more specific
Old 12-18-2018, 07:57 AM   #21
RalliartRsX
Trader Rating: (32)
^^ Looks like oil and carbon.
Old 12-18-2018, 04:52 PM   #22
nisileighty
I dropped the head off today at a machine shop to have it vacuum bench tested and waiting on the results.
Between the valves was just a bunch of flaking carbon and some spilt oil from when I turned the head over.
Old 12-18-2018, 05:02 PM   #23
Nysil Via
Nysil Via has a spectacular aura aboutNysil Via has a spectacular aura aboutNysil Via has a spectacular aura aboutNysil Via has a spectacular aura aboutNysil Via has a spectacular aura aboutNysil Via has a spectacular aura about
your pistons look way cleaner than mine. I put a scope into my spark plug hole and snapped some pics.
Nysil Via is offline   Reply With Quote
Old 12-18-2018, 05:07 PM   #24
nisileighty
My bottom end was rebuilt about 2k miles ago which is why the pistons are so clean. All the built up carbon wiped off with alcohol.
Old 12-18-2018, 11:37 PM   #25
Kingtal0n
Kingtal0n's Avatar
I run a fuel cut rev limiter soft 6400rpm for daily driver oem sr20det engines
it won't do this if the head is right at 6400-6600
Ask yourself if you really need that last 500rpm, if not, ditch it for the increased reliability
Old 12-18-2018, 11:45 PM   #26
nisileighty
I’ll definitely lower the limit a few hundred revs. It’s an ignition cut which I believe was the main reason the rocker broke.
Old 12-19-2018, 06:22 AM   #27
Kingtal0n
Kingtal0n's Avatar
oh yeah. We see that all the time. Its rare to have a rocker failure at 7k on the fuel cut limiter, it would have surprised me.
What happens on the ignition cut is some fuel explodes in the exhaust system, which creates a high pressure between turbine and head, pops the exhaust valve open if a spring is weak enough.
The valve then being open when it isn't supposed to be is now 'in the way' when the cam comes around, rocker loses its 'grip' and cam cuts it in half more or less. might leave a huge gouge in the cam lobe too. It basically jams sideways in there till it fractures like a brittle chalk, often sending little shims and guides into the oil pan if ur lucky hah.
If not, you never find them ;D
tinyurl.com/4l80er
Old 12-19-2018, 06:50 AM   #28
TheRealSy90
Ignition cut is a no-no on stock valvetrain. I ran my old sr almost 8 years raping the stock 7,500rpm limiter and never popped a rocker lol.
Old 12-19-2018, 07:22 AM   #29
RalliartRsX
Trader Rating: (32)
The is more the constant laying on the limiter vs just touching it prior to switching gears.
Drift cars and the like is a perfect example. On all my SRs, reving to 7-7500 RPM track day cars (300-360+ WHP) and touching the limiter (and just so on most shifts unless short shifting) I have yet to break a rocker or spit out a shim. This is with Spark Cut limiter (hard cut) and progressively cuting each cylinder in 100 RPM increments until redline (so cylinder 1 cuts @ 7100, cyl 2 @ 7200, and so on). This is very similar to a stock SR ecu logic. Never an issue.
The only folks I really se spitting shims are ones which lay on the limiter.
Old 12-19-2018, 11:55 AM   #30
TheRealSy90
Yeah I layed mine on limiter for seconds at a time so idk haha.
