Old 02-13-2018, 07:05 PM   #1
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
power steering banjo bolt adapter
as the title says i am trying to figure out if anyone knows what kind of power steering banjo bolt adapter i can use on my power steering pump. its this little piece, and i cannot find it anywhere and am wondering if there is some other generic adapter that i can use on it. basically i need it because my power steering line will not fit into the pump.
http://i.imgur.com/5sjtf.jpg
as you can see in my picture i am missing it
https://imgur.com/a/XCxVm
oLemurs is offline   Reply With Quote
Old 02-13-2018, 08:08 PM   #2
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Just buy any high pressure line from any shop and be done with it.
di-devol is offline   Reply With Quote
Old 02-13-2018, 08:14 PM   #3
oLemurs
oLemurs's Avatar
ok, do you know the line sizes by chance, my car doesnt drive and i heard driving without ps fluid in your car will ruin the pump or rack,
EDIT: ive heard the connector also acts as a restrictor so the steering isnt so assisted
Old 02-13-2018, 10:57 PM   #4
di-devol
Some info I found in some thread here.
Originally Posted by Xise View Post
Starting from the PS reservoir --->6an hose clamp->6an oil hose->6an hose end->6an to m14x1.5(w/ oring)
from the pump to the rack is m16x1.5 to 6an adapter(w/ crush copper washer)->6an power steering hose end (90 deg)->High Psi PS hose (8ft SOHC/6ft DOHC)->6an power steering hose end(45 deg)->m16x1.5 adapter (w/oring)
the small fittings on the rack are m12x1.0, not sure what size brake lines to use for that, I still need to get some
Old 02-15-2018, 10:09 PM   #5
oLemurs
oLemurs's Avatar
thank you my guy
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
