Old 03-08-2016, 06:52 PM   #1
Heflin_93
Heflin_93 is an unknown quantity at this point
1995 pro am fd legal ls7 s14
- 95 240sx
FD 2012 spec legal cage
Front tubs with dimple plates
Rear fenders cut/welded for over fenders
Custom bolt on front bash bar
Car has a clear title
- LS7 7.0L
Motor has been freshly rebuilt
Tuned with HPTuners
PSI standalone wiring harness
PRC .675 dual valve springs w/titanium retainers
Comp cam LS7 magnum push rods
DC power 180amp alternator
Lingenfelter 160F thermostat
CSF 3" dual pass radiator
Taurus radiator fan
Aeromotive Stealth 340LPH w/ -6AN lines from tank to the fuel rails
GM Corvette fuel regulator and filter
Fueled Racing headers
Fueled Racing Moroso dry sump pan
Fueled Racing urethane engine and transmission mounts
Fueled Racing remote oil filter kit
ChaseBays power steering -6AN lines
ChaseBays power steering reservoir
ChaseBays overflow tank
JEGS 10 row power steering cooler
GM Corvette dry sump tank
Custom -12AN dry sump lines
Custom 4" intake with 5ply coupler
Custom tig welded SS and Vband 3" Y-pipe to 4" single exit exhaust
- GTO T56 transmission (freshly rebuilt)
Billet shift keys
Steel 3-4 shift fork
Bronze fork pads
All carbon syncros
ACT heavy duty clutch
ACT prolite flywheel
Wilwood clutch master cylinder
ChaseBays clutch line kit
MGW shifter
Fueled Racing aluminum driveshaft
Nismo 2way w/Z32 finned cover
Driveshaft Shop 600HP Axles
- DMAX type 3 kit
Origin 20mm front fenders
Origin type 2 50mm rear over fenders
DMAX vented hood
Aerocatch hood pins
Supermade clear headlight lenses
JDM OEM Kouki tail lights
Kognition carbon fiber sunroof delete panel
Graphics designed by Mario Johnston at White Crane Tattoo in Cincinnati, OH
Nissan super black paint
- Cockpit and engine bay pain GM white
Driver seat is an authentic Bride Zeta 3 with authentic Takata harness
Passenger is a Bride Zeta 2
Buddy Club seat rails
Suede wrapped dashboard
Greddy oil pressure and water temp gauges
NRG short hub
NRG 1.5 quick release
Grip Royal steering wheel
- Fortune Auto 500 gen. 5 Coilovers with swift springs (8k/5k)
Modified PBM FLCA tension rod combo
PBM front drop knuckles
PBM rear drop knuckles
PBM toe/traction/camber arms
Tein inner tie rods
SPL outer tie rods
Johnny Fraz bolt on power brace
Stance Solid subframe risers
- Z32 30mm front and rear brakes with EBC blue pads and EBC dimpled rotors
ChaseBays SS line from master cylinder
Exedy 1-1/16th brake master cylinder
ASD hydraulic handbrake
New OEM replacement wheel hubs with extended studs
Muteki red SR48 lugnuts
- Cosmis XT206Rs
18x9.5 +10
18x11 +8
I also have a set of Enkei RPF1s (18x10.5 +15) that I will throw in if the price is right.
I'm asking 25,000 but also open to trades. Text 270-210-3487 if interested, don't waste my time.
Heflin_93 is offline   Reply With Quote
drift, kouki, ls7, s14, turbo
