06-25-2015, 01:50 PM | #1 |
CCS Autoselect Urethane Engine Mounts $100.00 Shipped.
CCS Autoselect Urethane Engine Mounts The CCS Autoselect 240sx Engine mounts are designed to replace your worn out factory engine mounts.These mounts will eliminate the slop that your old stock mounts have and will keep the engine from rocking and slapping around in the engine bay. This will help improve power transfer from the engine to the ground and help reduce wear on your drive-line CCS Autoselect Engine Mounts are made in the USA using CNC laser cut steel and are professionally welded. We use high quality grade 8 fasteners. The nuts we include are flanged to eliminate the need for washers, they also have nylon locking rings built into them to keep them from coming loose over time. These engine mounts use Energy Suspension Urethane Bushings and sleeves. We chose to use their bushings rather then molding our own to keep cost lower and the quality high. Energy Suspension has been manufacturing quality urethane bushings for decades so it just made sense to trust them. CCS Autoselect 240sx engine mounts - Fits KA, SR, CA, and some swaps CCS Autoselect Z33 Engine Mounts $100.00 shipped.
http://www.forcedfabllc.com/ Last edited by slw240sx; 07-01-2015 at 01:14 PM.. |
06-25-2015, 03:58 PM | #2 |
Trader Rating: (29)
Feedback Score: 29 reviews
Those look awesome, dead serious that is exactly the kind of mount I would want on a KA/CA/SR. Super awesome price point too, if I end up with another stock type swap s-chassis I will try these out for sure. GLWS, I hope these take off.
06-25-2015, 09:03 PM | #4 |
very little if any. They were based of the dimensions of the stock mounts.
We have over a hundred sets on cars and only one complaint about fitment. That was in a SR S14, it had to have been his chassis being tweaked because these are all made in the same fixtures and no one else had a complaint.
http://www.forcedfabllc.com/ |
06-25-2015, 10:26 PM | #6 |
no not at all. His was the mounts would not line up to the subframe so he had to notch the holes in the subframe front to back. I think either chassis was tweaked or he tightened up the center pivot bolt before installing the mounts completely.
07-01-2015, 12:24 PM | #8 |
It will not be that bad, but it does increase it. Most customers have never complained of it being excessive. They have less vibration then the straight through bolt designed Urethane mounts that most companies sell.
