08-16-2018, 07:03 PM | #1 |
Trader Rating: (26)
Feedback Score: 26 reviews
2JZGTE VVTI low idle when warm
When cold it starts right up and idles fine but when it gets past 170/180 it wants to idle around 300 and die.
Also what should it idle at cold? bone stock 2j oem ecu stock injectors small single runs amazing unless I come to a stop lol Any help would be great I wanna drive this damn thing
08-19-2018, 07:41 PM | #2 |
idle is controlled by airflow mostly
let more air into the engine somehow you could simply open a vacuum leak or drill a hole in the throttle body or find out why the IACV/DBW isn't doing this for you |
10-05-2018, 12:11 PM | #4 |
Try adjusting throttle cable to have less slack. I had the same issue and that fixed my problem. I thought it was a boost leak at first but ended up being that my idle was set so low it would drop rpm and die when coming to a stop.
