11-11-2018, 03:06 PM | #1 |
S14 HKS HIPERMAX COILOVERS/ Revel by Tanabe Coilovers
HKS HIPERMAX IV SP $SOLD
1k Miles used for break in and review The highest and newest line of coilovers for the s14 by HKS The HKS HiperMAX GT coilover was designed for the enthusiast that wants to upgrade the handling of their car while being able to lower it for style while not losing out to much on daily driving comfort. The Hipermax GT features a 6kg front 5kg rear spring rate. The has an adjustable front pillow ball mount up front to allow for camber adjustment while the rear features a hardened rubber upper mount to help keep road noise and other sounds that come with lower quality coilover systems. The GT even though it has a focus on comfort will still perform on the track. Not recommend for cars that will be tracked for competition use as there are better options when building a dedicated track car. HiperMAX IV the new damper from HKS returns to the core of tuning, the street. Featuring an advanced shock absorption system, the MAX IV captures the bumps on the road to give a supple yet stable ride. MAX IV aims for a high level balance of comfort with sporty handling. It’s perfect for daily street drive with style and performance. You and your passenger can have a comfortable ride even with a low-down. Single Tube Damper Design Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride. Dust Boot Protect the shaft from the flying stones. PNE Coating Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment. M Shaft With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range because of the optimized oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience. New Design Needle Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride. Reduction of Unsprung Weight In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles) 30 Step Damping Force Adjustment 30 levels of dampening adjustment allow fine tune adjustment for street or circuit. Lowering (Front): -47mm (From 0 to -81mm) Spring Length (Rear): 250mm Lowering (Front): -47mm (From 0 to -81mm) Spring Length (Rear): 250mm Damping Force (Rear): 839m/sec (Rebound) & 382m/sec (Compression) Spring Length (Front): 220mm(Barrel) Damping Force (Front): 211m/sec (Rebound) & 137m/sec (Compression) Front Upper Mount: Rubber Spring Rate (Front): 59N/mm (6kgf/mm) Lowering (Rear): -45mm (From 0 to -80mm) Rear Upper Mount: Rubber Spring Rate (Rear): 49N/mm (5kgf/mm https://www.hksusa.com/products/80250/AN002/3028 Revel Coilovers by Tanabe Monotube 1k miles on the set $Sold The 32 way adjustable Revel Touring Sports Damper is the ideal solution for the most comfortable ride in a coilover kit while achieving an extremely low ride height and utilizing the perfect balance of dampening forces and spring rates to deliver smooth performance when it is needed. Pillowball upper mounts give the driver greater driving feedback when compared to OEM rubber upper mounts. A spherical bearing is used in place of a rubber bushing and an adjustable camber plate is utilized on certain applications which aid in achieving improved tire traction and alignment. Teflon thrust washers reduce friction during steering movement and eliminates spring binding and movement. Also eliminating unwanted noise and maintaining proper adjustment of the height adjustment. Larger piston valves and oil capacity allows for a faster reacting dampening force and efficiency through all temperature ranges. High strength and rigidity brackets ensure the driver has the utmost confidence for all driving types Both sets sold please lock! Last edited by tacotacotaco; 01-30-2019 at 08:53 PM.. Reason: SOLD LOCK |
