Old 09-20-2011, 01:32 PM   #1
s13tmont
s13tmont can only hope to improve
Exclamation FS: LSX s13 coupe
Well I believe I've decided to sell this to move on to some other toys.
Pretty much I picked up the shell and built it from the ground up, so I can answer practically anything about it, so on to the car.
It's a 92 240sx s13 coupe, mileage on the shell isn't exactly known but it's obviously up there. It has a 02 Silverado 5.3 LM7 w/ ~60k miles on the motor with an 01 Camaro T56 6 speed behind it.
-92 240sx s13 coupe, clean & clear title
http://www.youtube.com/watch?v=cX77H902haQ
http://www.youtube.com/watch?v=ci8UablmiFk
12/9/11 EDIT: 02 zo6 cam, springs and pushrods were installed as well as a SLP 25% underdrive pulley. New coolant and oil as well as AMSOIL ATF fluid in the trans. New FLCA's with balljoints and bushing were installed and Energy suspension Tension Rod bushings. New glass was put in so the tint is not pealing and the driver door was realigned so that it shuts now. I just purchased a Dakota Digital so that the speedo will work and will be wiring that in this week! New Federal 595's 235/40/18 were put on the fronts. The exhaust setup was changed from the old sagging HKS hi-power to a 3" inline dynomax muffler.
MOTOR, TRANS & ANYTHING UNDER THE HOOD!
-5.3 LM7, runs strong, no smoke, no knocking or ticking
-01 T56 6 speed, grind downshifting to 4th
-LS6 intake manifold
-LS6 Throttle body
-LS6 Fuel rails & injectors
-NGK TR55 Plugs
-Brand new plug wires
-Camaro accessories (PS pump/bracket, ALT/bracket, Waterpump, tensioner)
-1 3/4" Daft Innovations Long Tube Headers, Custom 3" Ypipe, HKS hi power catback. (NO CATS)
-Brand new Battery
-3.5" straight intake with 3.5" K&N filter
-Daft Innovations s13 LSX Mounting Kit
-Wilwood Clutch Master Cylinder w/ Daft Innovation adapter plate
-C5 Vette fuel filter setup w/ Stainless braided 6an fuel line
-BRAND NEW Power steering rack
-C5 Vette o2 sensors
-Stock LS1 Clutch setup
-Stock LS1 Flywheel (resurfaced)
-Short throw shifter (to keep from hitting the 240sx shifter trim)
-Brand new OEM Slave Cylinder
-Daft Innovations s13 steel driveshaft
-J30 diff
-Aluminum Radiator
-Dual E-fans
-C5 Corvette Fuel Rail Covers (Clean up the engine bay a ton)
SUSPENSION, BRAKES, WHEELS & TIRES
-Megan Street Coilovers (s13)
-5 lug swap
-New rotors and brake pads
-New steering rack
-New tie rods (outer and inner)
-Daft Innovations Sway Bar Spacers
-18x9.5 +12, 18x10.5 +15 Varrstoen 2.2.2 Full Polish Wheels
-235/40/18 Yokohama Advan Sports (60% tread) , 265/35/18 Federal 595's (90% tread left)
BODY
-Painted a titanium silverish color, not quite sure how to explain it.
-Origin Type 1 30mm rear overfenders (molded)
-Stock Silvia metal fenders
-Stock Silvia front bumper
-Stock Silvia Dual Projector headlights
-OEM Silvia Headlight Brackets
-Smoked Corner Lights
-Smoked Bumper turn signals
-Carbon Fiber silvia stock style hood
-Tinted Windows
INTERIOR
-7/10 dash, it has two cracks that I will post pictures of. It's clean otherwise
-S14 Gray cloth front seats, no rips or tears, great condition
-S13 black rear seats
-Brand new molded S13 black carpet
-Brand new headunit, works great, not sure of the brand off the top of my head
-RPM, Gas & temp gauge work. Speedo will work when you wire in a Digital Dakota Box
-Power windows
-Heat works, A/c could work if you want to get LS to 240sx lines made for it and do the wiring
Honestly, there is probably a ton of little things that i've forgot to mention through out all the stuff that I have mentioned so far. Anything you want to know about the car I will tell you, i'm not trying to hide anything about any of it so I will go ahead and list the cons...
-No a/c
-CEL stays on due to the long tube headers and placement of the o2 sensors. It's just an o2 slow response code.
-Gas door isn't 100% flush
-No front speakers, rear's only
-Gutted Trunk (If that even matters to you)
-The LS PCM lays in the floor board of the passenger side, if you can find a place to stick it out of sight... more power to you.
-Paint job is by no means superior, but it is all one color, definitely could use a new paint job.
-Carbon fiber hood is flimsy, could use hood pins to fix this.
-Small popping in front left suspension when turning right occasionally.
That's really the only things that come to mind when I think of negatives of this car but feel free to point out anything else you disagree with.
Now on to the pictures.....
Now a few pictures from the build process,
I WILL CONTINUE TO POST UP SO NEW PICTURES OF THE CAR, IF THERE IS ANY SPECIFIC PICTURE THAT YOU'D LIKE TO SEE, LET ME KNOW!
http://www.youtube.com/watch?v=wyk4YzPWXuc
http://www.youtube.com/watch?v=3tJovLCRyEk
http://www.youtube.com/watch?v=VE7jat_UuN4
http://www.youtube.com/watch?v=cwmNjLYIkHw
NEW FRONT TIRES
HERE IS THE NEW EXHAUST SETUP
AND A VIDEO OF HOW IT SOUNDS
http://www.youtube.com/watch?v=IWhLp3Z_OYI
QUICK VIDEO OF 1st THROUGH 3rd GEAR PULL
http://www.youtube.com/watch?v=2G22UaHX_ew
Email - [email protected] or you can PM me on here
$10,500 OBO OBO OBO OBO
s13tmont is offline   Reply With Quote
Old 09-20-2011, 07:41 PM   #2
EnvyS13
EnvyS13 is an unknown quantity at this point
clean lsx swap. bump
EnvyS13 is offline   Reply With Quote
Old 09-21-2011, 02:23 AM   #3
itsguyguy
itsguyguy's Avatar
itsguyguy is an unknown quantity at this point
AC and new coilovers would make this a perfect fun driving DD.
I've got my eyes on another S14 though, so yeah...
If you want to trade for my Z31, I'm down!
itsguyguy is offline   Reply With Quote
Old 09-21-2011, 11:28 AM   #4
nicksr20
nicksr20 is an unknown quantity at this point
SOOOOOOsoooo interested, trade for my clean built sr20 hatch, id drive it down to fl in a heartbeat. PMd
nicksr20 is offline   Reply With Quote
Old 09-21-2011, 01:41 PM   #5
slippinsideways
slippinsideways is an unknown quantity at this point
done right! great job, clean car
slippinsideways is offline   Reply With Quote
Old 09-21-2011, 03:03 PM   #6
curb bound
curb bound is an unknown quantity at this point
Glws, i want to do this to an s14 and maybe turbo it.
curb bound is offline   Reply With Quote
Old 09-21-2011, 04:36 PM   #7
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Dang already selling? That was fast....
Memberofthe600hpkaclub is offline   Reply With Quote
Old 09-21-2011, 04:46 PM   #8
1180g35black
1180g35black is an unknown quantity at this point
What part of flordia? Also if you are interested in trading for an 04 twin turbo 350z shoot me a PM
1180g35black is offline   Reply With Quote
Old 09-22-2011, 04:12 PM   #9
alex89
alex89 is an unknown quantity at this point
Holy ***K!!! WHY WOULD YOU PUT THIS MUCH POWER IN SUC A LIGHT CAR?!??!?!!? YOU ARE INSANE AND A VERY BAD MAN!!!
seriously though, clean car bro.
alex89 is offline   Reply With Quote
Old 09-22-2011, 08:21 PM   #10
96rbs14
96rbs14 is an unknown quantity at this point
ive got a 200 honda s2000 with some mods id trade for this and meet 3/4 the way down there lmk
96rbs14 is offline   Reply With Quote
Old 09-22-2011, 10:35 PM   #11
s13_rb25
s13_rb25 is an unknown quantity at this point
you sir have a very clean car. AWESOME! bump.
s13_rb25 is offline   Reply With Quote
Old 09-27-2011, 03:40 PM   #12
s13tmont
Bump #1, due to adding a few videos of this thing just to give you a better look at it!
Old 09-28-2011, 10:55 AM   #13
YyungDdragon
YyungDdragon is an unknown quantity at this point
what a piece of shit. )
YyungDdragon is offline   Reply With Quote
Old 09-28-2011, 05:42 PM   #14
Eyegazm
Eyegazm is an unknown quantity at this point
Car looks excellent. Glws!
Eyegazm is offline   Reply With Quote
Old 10-02-2011, 12:41 PM   #15
s13tmont
Last and Final Sunday bump! Lets get some offers going here people, price has now been lowered some!
Old 10-14-2011, 10:10 AM   #16
YyungDdragon
bummmmpppppppp
Old 10-16-2011, 11:39 PM   #17
curly
curly is just really nicecurly is just really nicecurly is just really nicecurly is just really nicecurly is just really nicecurly is just really nicecurly is just really nicecurly is just really nice
Is this thing sold?
curly is offline   Reply With Quote
Old 10-17-2011, 09:19 AM   #18
s13tmont
Nope, the car is still up for sale!
Old 10-17-2011, 09:31 AM   #19
Krazykouki
Krazykouki is making a name for him/her selfKrazykouki is making a name for him/her self
How do you get LSX from an LM7? free bump none the less.
Krazykouki is offline   Reply With Quote
Old 10-17-2011, 10:13 AM   #20
s13tmont
Because the LM7 shares the same design of the LSX, minus the fact that it's iron. The physical dimensions, bolt holes, ect.. it's an all interchangeable design all based from the LSX setup. Thanks for the question though.
Old 10-20-2011, 06:55 PM   #21
d-man478
d-man478 is an unknown quantity at this point
damn. sucks to see your getting rid of it.
bump for you!
d-man478 is offline   Reply With Quote
Old 10-23-2011, 09:33 PM   #22
boostergod
boostergod is an unknown quantity at this point
Yo im really interested in it man...... is it still up for grabs?
boostergod is offline   Reply With Quote
Old 10-23-2011, 09:37 PM   #23
grimm199
grimm199's Avatar
grimm199 is an unknown quantity at this point
Wanting to know, How easily does this thing break loose? Like if you are full throttle accelerating, what's the highest speed it has broken loose on you? Wanting to know because i may do a swap like this.
grimm199 is offline   Reply With Quote
Old 10-23-2011, 09:52 PM   #24
jesse_s13
jesse_s13's Avatar
Its a v8 son
glws really clean car man
jesse_s13 is offline   Reply With Quote
Old 10-23-2011, 11:06 PM   #25
djslothfedup
djslothfedup's Avatar
djslothfedup is an unknown quantity at this point
you need to lower this shit like 3 inches
XXX pileofsheet.blogspot.com
djslothfedup is offline   Reply With Quote
Old 10-23-2011, 11:16 PM   #26
s13tmont
Yes the car is still up for grabs.
Well it has more torque in the lower rpm's and produces the torque quicker, therefore it will spin if you really want it to.
Originally Posted by jesse_s13 View Post
Its a v8 son
Thanks a lot!
Maybe another 3/4" in the front and another 1" in the back... but I still haven't rolled or pulled my fenders and I wouldn't say that I'm rushing to get to it. Maybe one day.
Also, I'm installing and 02 zo6 cam, ls6 yellow springs and ls6 pushrods, as well as a SLP 25% underdrive pulley, then will be getting retuned and maybe even dyno tuned. I will update this with further information when it happens.
Old 10-23-2011, 11:31 PM   #27
95RB
95RB is an unknown quantity at this point
nice...very nice i think i just cam lol
95RB is offline   Reply With Quote
Old 10-24-2011, 05:58 AM   #28
ST(I)mpreza
ST(I)mpreza's Avatar
ST(I)mpreza is an unknown quantity at this point
I sure do like this car, wish I had 10.5... free BUMP just the same!
ST(I)mpreza is offline   Reply With Quote
Old 10-24-2011, 06:05 AM   #29
zz_kouki_zz
zz_kouki_zz's Avatar
zz_kouki_zz is an unknown quantity at this point
Nice Silvette! Bump to a fellow Floridian
1997 KOUKI SR'D SKEPTRON POWER!
zz_kouki_zz is offline   Reply With Quote
Old 10-24-2011, 06:17 AM   #30
mx597turbo
mx597turbo is an unknown quantity at this point
No one still has the yellow "Made in Germany" springs anymore. They only have the blue "Made in Mexico" springs. These are still good, and come stock on the LS3 C6 and Camaro. I have them in my C5, rev to 7k, and have no problems.
BTW, when you do this job, make sure to get the Proform LS Valve spring compressor. It makes the job very easy, you can do two springs at once. It costs about $70, and is well worth it. Also, don't use an air holder. Just take 1/4" nylon rope. Put it in the cylinder through the spark plug hole, and turn the engine until it stops. It holds the valves perfectly, and takes way less time than that stupid air holder. Not to mention, I could never get the air holder to actually get a good seal and hold the valve.
mx597turbo is offline   Reply With Quote
240sx, build, for sale, ls1, notlsx, s13, wannabe lsx
