Old 11-05-2018, 12:58 AM   #1
Blackmassive2669
Blackmassive2669 is an unknown quantity at this point
Fuel Cut 5 gear, 4k rpms Ka24e
Alot of threads based on fuel cuts for dual cams and SRs but not for single jingles. I would appreciate if someone can link me to a thread about my question if it exists.
I have a fuel cut around 3500 rpms in fifth gear. Im probably going 75 mph to keep up in traffic(my speedometer doesnt work), but accelerating a little more and boom, cant accelerate till im around 3500 rpms.
Since i bought this car(89 240, ka24e) my speedometer would work randomly. My odometer was working, but out of nowhere, it just stopped. Around 207,000 miles.
So i just assumed it might be speed senor(still kinda believe it is. Kinda). But the weird part is that when the speedometer randomly works, i can go waaaaay past 4000 rpms, and dont experience any fuel cuts.
Now yesterday, there was a bug on my cluster and i tapped it with my hand and the speedometer and odometer started working, and eventually died out. But i can keep on doing and it'll work for a little bit.( im hitting around the speedometer btw)
So the main question, has anyone ever experienced this problem? Can a bad cluster give bad reading, telling the computer im going too fast and then cuts its fuel? Or the problem most definitely the speed senor?
No fuel cuts when speedometer is working
Fuel cuts when speedometer isnt working
Blackmassive2669 is offline   Reply With Quote
Old 11-06-2018, 11:30 AM   #2
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Probably best to look at the FSM and review the wiring diagram of the speedometer. Then check your wires from there to see if you have a loose connection or corrosion.
instagram
1on1 is offline   Reply With Quote
Old 11-07-2018, 05:32 PM   #3
Ugly SR
Ugly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura aboutUgly SR has a spectacular aura about
I have the exact same problem, zero issues after the HUD/ speedo starts working. I read somewhere that a resistor in the HUD doesnt work until it gets hot (like an hour of driving, or sitting in the heat on a summer day) After that all is well.... I have not looked into it further, but would love to find the fix for it.
89' s13
88' quest
Ugly SR is offline   Reply With Quote
Old 11-29-2018, 06:30 PM   #4
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Your 4th and 5th gear are speed limited via RPM by the ECU. That's why you can't go above 3500.
LayNLow is offline   Reply With Quote
