Old 11-06-2017, 05:46 PM   #1
Angelrb240
Angelrb240 is an unknown quantity at this point
Thumbs down 550cc r35 denso injectors on rb20!!!
I have a set of 550 gtr injectors on my aftermarket intake manifold!! Not starting! Why? Nothing else was changed other then the injectors. There are high impedance just like the stock injectors are.... PLEASE HELP.
Angelrb240 is offline   Reply With Quote
Old 11-06-2017, 05:51 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
So you switched from the stock 270CC injectors to 550cc?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 11-06-2017, 05:53 PM   #3
Angelrb240
Yes! Desno injectors
Old 11-06-2017, 05:56 PM   #4
Angelrb240
Note: one of the two relays on my rb harness(next to ecu) (which are injector relays) gets warm/hot.... ran fine before.
Only reason i switched injectors. Because i went with an after market intake. Stock injectors dont fit because there not 14mm top feed injectors
Old 11-06-2017, 05:59 PM   #5
Angelrb240
Post
Should it not atlease start??? I know i need to tune(for driving)
Old 11-06-2017, 06:13 PM   #6
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
If you’re lucky it’ll start, but very very unlikely.
nisileighty is offline   Reply With Quote
Old 11-06-2017, 06:22 PM   #7
Angelrb240
Thanks for the reply guys highly appreciated! Any more info would be great ����
Old 11-08-2017, 05:22 PM   #8
ex_rabbit
ex_rabbit is an unknown quantity at this point
If it wasn't getting hot before, my thought is that there's some type of high resistance somewhere.. If you could trace the wire or read a diagram. Also, did you swap the manifold too? Maybe it's not bolted down properly..?
If fuel is the issue, check your system, confirm fuel is actually dumping into the cylinders on startup
Sent from my SM-G900V using Tapatalk
ex_rabbit is offline   Reply With Quote
Old 11-08-2017, 05:24 PM   #9
ex_rabbit
Sorry, read that wrong about the relay, confused it for 'wire'. Can you trace where the wires lead?
Old 11-08-2017, 07:54 PM   #10
Angelrb240
Other forums say the 2 relays are some sort of the power source to the injectors. And yes its an after market intake manifold. Ive pulled the fuel rail off with the injectors still on and turned my CAS sensor to see if they were firing. And they sound very weak ( the firing) compared to my stock ones. And only #3 injector fires with a very ugly spray pattern.
Old 11-08-2017, 07:57 PM   #11
Angelrb240
And i have read that these r35 gtr injectors have different omhs then compared to the stock rb20 injectors. Am only running these r35 gtr injectors because there a perfect fit. Ive also read rb25det NEO injectors work to. The car has ran before and beautifully too.......... am just lost in the injector world..
Old 11-08-2017, 07:58 PM   #12
Angelrb240
Yes gose some what to injector harness
Old 11-08-2017, 09:09 PM   #13
ex_rabbit
Kk, I'm not a guru with mix & matching parts, if you're doing this as trial & error I guess this could be the 'error' part. Maybe grab some other injectors meant for your motor & see if they fire up properly..
Old 11-08-2017, 09:12 PM   #14
ex_rabbit
The R35 injectors may have physically dropped in perfect, but maybe the electrical part is all off. If that happens I'm thinking it would make sense why you're not getting proper fuel for your startup, or why your relays are heating up
Old 11-09-2017, 05:14 AM   #15
Angelrb240
Thats the plan. Either going with rb25neo injectors or try sending in my ecu for a tune... Cheers
Old 11-09-2017, 11:21 AM   #16
ex_rabbit
[emoji482][emoji482] good idea, I think the neo injectors are a better bet, although I've never used them, I'd think that's more proven tech to work. Good luck, keep us posted how you made out [emoji106][emoji109]
Old 02-16-2018, 04:37 PM   #17
Angelrb240
Update i got my tune ecu back from jtw and i got fuel now! THANKS guys!
Old 02-17-2018, 11:47 AM   #18
ex_rabbit
Awesome, good stuff, dude!!
