Old 11-10-2015, 07:42 PM   #1
Rocketbunny240sx
Rocketbunny240sx is an unknown quantity at this point
Sr20det throttle body for s13
Hey guys just wondering what you guys recommended for an sr20det throttle body upgrade. I want alittle more throttle response and would it increase alot of hp? Just wondering. Im pushing 400whp atm. Thanks!
Rocketbunny240sx is offline   Reply With Quote
Old 11-10-2015, 07:54 PM   #2
Rusker
Rusker's Avatar
Rusker is on a distinguished road
Redtop? Blacktop?
For reference here are the specs on the different TB for SR's.
S13 SR20DET throttle bore = 60mm
S14 SR20DET throttle bore = 50mm
S15 SR20DET throttle bore = 50mm
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 11-10-2015, 07:54 PM   #3
Rocketbunny240sx
Its a redtop.
Old 11-10-2015, 07:57 PM   #4
Rusker
Rusker's Avatar
Tomei sells a 70mm throttle body. If this isn't big enough you can use a Q45 with the right adapter. I believe they are between 80-90mm.
1990 S13/SR20
Old 11-10-2015, 07:58 PM   #5
Rocketbunny240sx
Would 10mm more really make a difference?
Old 11-10-2015, 08:14 PM   #6
Rusker
Rusker's Avatar
Are you putting down 400whp, or just assuming you're making this much? If so, I would imagine you'd seem some improvement but nothing mind blowing. IIRC the stock SR20 60mm TB is good for about 350-400hp.
Without listing what you've done with the motor, I don't think anyone can really give you a good idea wether or not it's worth upgrading the TB.
1990 S13/SR20
Old 11-10-2015, 08:22 PM   #7
Rocketbunny240sx
I guess. Im literally pushing 400 whp i can show you my setup
Old 11-10-2015, 09:16 PM   #8
Kingtal0n
Kingtal0n's Avatar
Waste of money
We can make 500-700 horsepower maybe even more on the OEM throttle body.
Using a larger part there just makes the car more difficult to drive and reduces the resolution at the pedal, reduces fuel economy, etc... its all negative, there is very little positive benefit at 500 horsepower and less for sure.
Old 11-10-2015, 09:19 PM   #9
Rocketbunny240sx
Thanks for that!
Old 12-23-2015, 05:13 PM   #10
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
would performance/drivability improve on a redtop by reducing the size from 60mm to 50mm? Has anyone tried that?
240knockout is offline   Reply With Quote
Old 01-21-2016, 11:05 AM   #11
vipergtsr1000hp
vipergtsr1000hp is an unknown quantity at this point
Originally Posted by Kingtal0n View Post
Waste of money
How sure are you of this? I am currently building a S14 SR20 with a GTX3582R. Planning to make 600 whp+ I was debating whether to get a Greddy IM for the stock throttle (50mm) will most likely use KA TB (60mm) instead of the 70mm N1 TB which are rare and expensive. Would the 10mm make the difference i.e. more hp at upper RPMs, broader peak power at upper RPMs, etc??? This is what is causing me not to get a Greddy IM because of the TB sizes. I am currently looking at Velocity Elements IM which they will custom in Q45 TB flange. I just don't want the TB to be a limiting factor in making power.
vipergtsr1000hp is offline   Reply With Quote
Old 10-09-2018, 09:50 PM   #12
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
Love those VE manifolds
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 11-06-2018, 07:18 PM   #13
RomulanS13
RomulanS13 is an unknown quantity at this point
With the aspect of forced induction you can only do so much. pretty simple all you can do is smooth things out porting/polishing cause you are forcing air in. CFM in duration will play a big part but to an extent there is always a capacity or limit to where it become less efficient IE to small of an IC or displacement.
RomulanS13 is offline   Reply With Quote
240sx, s13, sr20det, throttle body
