Old 05-15-2015, 01:42 PM   #1
Trizimo
Trizimo is an unknown quantity at this point
s14 1998 Nissan 240sx w/ Rebuilt SR20DET
1998 Nissan 240sx
Clean title
Price: $11,000.00 OBO
Cash only
Located in: Lexington, Kentucky
Cash in hand for test drives. Absolutely no joy rides. Car is sold as is. Vin is available upon serious request.
Backstory/Car History:
I purchased the car in October of 2013 from my brother. I have not touched the exterior of the car at all. During my ownership, I've rebuilt the motor, replaced all the wiring, and fixed/replaced other multiple items here and there.
This is a true 1998 kouki (only 2,178 ever made). I only say this because I don't think many people realize how rare the 98s are. The original color, silvermoss (engine bay color) makes the car 1 out 500 (don't remember the exact number - 576 i think)
The car currently has 1200 miles on the engine, wiring, clutch, and tires. This car is originally a 5-speed manual.
Exterior Modifications:
Front tire size: 235/40/18
Rear tire size: 255/35/18
New tires Front & Rear with 95% life remaining
Wheel Rims: Racing Hart CP-F tune forged wheel for competition (currently discontinued)
Body kit: Duraflex V-Speed
VIS Racing Sport Carbon fiber hood
Exterior Paint Color: Velocity RX-8 red pearl (2008-2009) color -- triple stage.
Crystal clear corner lights -- side marker lights
Aftermarket tinted turn signals (Front bumper)
Tinted license plate cover
Engine Modifications:
S14 SR20DET -- Rebuilt with currently 751 miles -- The car is still in the break in process
Rebuild Specifics:
Rebuilt by B&A Corvette (and their machine shop they use)
Bored .20 over
Milled and decked
Wiseco Forged pistons
ARP Head studs
Apexi Head gasket
All new gaskets and seals
New valve seals, valve job
OEM oil pump
OEM water pump
OEM timing chain
OEM cams
In short, everything else internally is OEM minus the performance mods listed above.
Other Engine Goodies:
Stock turbo (Currently running stock boost)
New main wiring harness
New Fuse box wiring harness
New (Used) S14 SR20DET ECU (All wiring component were replaced with the rebuilt motor)
Mishimoto radiator
Aftermarket blue radiator hoses
Aftermarket Odyseey Extreme Battery
Front mount intercooler
All new Micro-V belts
New idle air control valve
New Throttle Position Sensor
New Coolant Temperature Sensor
300zx fuel filter
Walbro 255 fuel pump
Circuit Sport Mini Oil Catch Can (currently not fully installed because the hose provided was extremely cheap and looked like a garden hose)
HKS cold air intake with HKS green pod filter
AEM boost solenoid
HKS blow off value
RS*R Catback exhaust
Cat delete, replaced with Megan racing test pipe
Cooling fans (not installed yet, will go with the car)
Aftermarket exhaust manifold
WORKING AC (the system just needs to be vacuumed down. I accidently undid an AC line when removing the motor)
Power steering Works
New horn
New horn relay fuse
New horn button
Buddy Club Aluminum oil cap (I believe)
Nismo motor mounts
Nismo transmission mounts
Megan racing stainless steel downpipe
ACT street (xtreme -- I believe) clutch kit -- same number of miles the rebuilt motor has
New Stock Flywheel -- same miles as motor
Suspension Modifications:
Megan racing adjustable coilovers
Sustec front engine mount brace
Megan racing front tension rods
Energy suspension -- solid urethane rear subframe bushings
Energy suspension differential bushings
Welded stock differential
300zx Brake Master Cylinder
300zx Brake booster
300zx Front Calipers
300zx Front brake rotors
Pads replaced all the way around ~1200 miles ago
Circuit sport stainless steel brake lines
5 lug swap
Fresh undercoat on all four wheel wells
Interior Modifications:
AEM Tru Boost LED gauge
AEM Air/Fuel Ratio LED gauge
Double Pod A pillar gauge cluster
New ignition cycloid
Apexi Auto Turbo Timer
Isis v2 Short Shifter (Equal if not better than the B&M shifter)
Tomei short shift knob
White gauge cluster
Unknown aftermarket drift knob
Kicker front & rear speakers
Front Kicker tweeters
Pioneer Stereo
Rear seatbelt delete
New passenger side window switch
Tinted windows
The CONS
The only serious cons to this car are cosmetic problems. The back bumper is the worst. Bumpers are cheap and you're probably gonna Tokyo drift this into a wall anyways...
No mechanical issues with the car.
Conclusion
Its a 17 year old car - its not gonna be perfect. I can be SOME WHAT flexible on the price but I'm not giving away a car with NEW major components (engine, tires, wires, etc..)
Car is for sale as is!
PLEASE READ THE ENTIRE AD BEFORE ASKING QUESTIONS.
PS: Shoutout to bottlefed97 for kindly uploading my photos to this thread. I was struggling to get them uploaded properly.
Trizimo is offline   Reply With Quote
Old 05-15-2015, 02:56 PM   #2
bottlefed97
bottlefed97 is an unknown quantity at this point
I uploaded your pics to Imgur. Glws!
bottlefed97 is offline   Reply With Quote
Old 05-15-2015, 06:01 PM   #3
Trizimo
Thank you for doing that! I really appreciate that.
Old 05-16-2015, 12:49 PM   #4
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
i'm not trying to hate or anything but how is that a 1998? The color of that engine bay is gold? and that color afaik only came on gold zenkis. It also looks to be a 100% original engine bay, all the stickers are there and what not. At the same time.. the interior is from a 98 so i'm confused.
What was the original color of the car? Moss?
Old 05-16-2015, 01:41 PM   #5
Trizimo
I believe the original color of the car was silver moss (I can't remember if that's the proper name or not). The title says 98. Would the vin prove that it's a 98? I can provide that to you if you need it.
Old 05-16-2015, 02:20 PM   #6
turbo11
turbo11's Avatar
turbo11 is an unknown quantity at this point
looks good
turbo11 is offline   Reply With Quote
Old 05-16-2015, 03:21 PM   #7
Trizimo
Thank you. It's priced a bit high (I carried over the same price I posted for craigslist), but remember it is OBO. I will reply to reasonable offers.
Old 05-18-2015, 08:13 AM   #8
dreimers
dreimers's Avatar
dreimers is an unknown quantity at this point
good looking car. Price is good for a mechanically sorted 98 Kouki. Rarest of all 240's. We as owners of these sorted cars need to keep strong with the prices. Fair, but firm. GLWS nice car btw
This is a site ran by the US government, not some crazy biased organization
dreimers is offline   Reply With Quote
Old 05-18-2015, 09:10 AM   #9
Trizimo
Thank you for the compliments on the car. I really appreciated your comment on my asking price for the car. It’s difficult pricing a rare and heavily modified vehicle. I made sure to search this forum and try to find other very similar cars to ensure that my price was within the right ballpark.
Old 05-18-2015, 12:29 PM   #10
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
can i get the vin?
240KA is offline   Reply With Quote
Old 05-18-2015, 12:53 PM   #11
Trizimo
Originally Posted by 240KA View Post
can i get the vin?
Not a problem. I just sent you a PM that included the vin.
If you (or anyone else) needs anything, just ask.
Old 05-21-2015, 10:39 AM   #12
Trizimo
Price drop. $14,000.00 OBO
Don't like the price? Make me a reasonable offer and i'll consider it.
Old 05-25-2015, 11:49 AM   #13
Trizimo
Update on the car.
No new issues! The weather has been nice enough here in KY to take the car out for some spirited backroad driving. This car pulls strong for being on 7psi and now has around 900 miles on the motor.
Im flexible on the price so feel free to PM reasonable offers. Thanks!
(bump)
Old 06-02-2015, 10:01 AM   #14
Trizimo
Price Drop!! $13,000 OBO, lets make something happen.
Old 06-20-2015, 09:58 AM   #15
Trizimo
The car is still for sale
Old 06-30-2015, 07:41 PM   #16
Trizimo
Price drop to $11,000.00. I'm a little bit flexible on the price, but much lower and i might as well keep the car.
Old 07-01-2015, 02:05 PM   #17
wild streak
wild streak's Avatar
wild streak is an unknown quantity at this point
If the 10th digit of vin is a W it is a 98.
wild streak is offline   Reply With Quote
Old 07-03-2015, 02:02 PM   #18
Trizimo
Thanks for sharing, i didn't know that. This car is definitely a 1998. Again, vin can be provided upon request.
Old 07-22-2015, 05:08 PM   #19
Trizimo
Update: The rear hub bearing has been replaced. I've received multiple offers, and am waiting for a few people to come view the car.
Until i have cash in my hand, the car is still for sale. I'm still a bit flexible on the price. Bump for those close to KY.
Old 07-22-2015, 05:41 PM   #20
240KA
do you have a picture of the vin number that is on the firewall?
Old 11-19-2015, 03:47 PM   #21
DKnissanman
DKnissanman is an unknown quantity at this point
trade for my 1jz s13.4?
keep your wheels and whatever else till you can agree on a price?
DKnissanman is offline   Reply With Quote
Old 12-01-2015, 04:37 PM   #22
Puroeuro
Puroeuro is an unknown quantity at this point
Is this still for sale? If so, is the engine bay the only part that is silver moss or is the rest of the interior parts also same color as in trunk and under the carpet? Im a picky guy and just need to know what im ganna need to get painted if i decide to buy this
Puroeuro is offline   Reply With Quote
Old 12-01-2015, 05:07 PM   #23
Puroeuro
Sorry misread what you said about the color. Still for sale though?
Old 05-11-2016, 08:34 AM   #24
kb3x
kb3x is an unknown quantity at this point
I know that you want a nice daily family car to trade for this
kb3x is offline   Reply With Quote
kouki, rebuilt, s14, sr20
