Old 03-23-2017, 07:05 AM   #1
R3cK
R3cK is an unknown quantity at this point
Exclamation sr20det redtop ARP main studs
my sr20det redtop going for ARP main studs that will arrive tomorrow.
but just found some horror stories about two rear bolts being to long for the oil pan and damaged threads / wrong torque specs..
arp #202-5402
http://www.frsport.com/ARP-202-5402-...99_p_1948.html
can somebody clear things out?
should i reuse my nissan studs and send them back? or use the ARP and how? with loctite or with the arp lubrication or both?
cheers
R3cK is offline   Reply With Quote
Old 03-23-2017, 07:12 AM   #2
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Reuse or purchase OEM mains. They are good for 500WHP +. If you get ARP mains, you MUST align hone the mains and you better make sure a machine shop is capable of doing it.
Old 03-23-2017, 07:29 AM   #3
R3cK
thanks for your fast reply.
will the torque change for reusing the oem mains?
Old 03-23-2017, 07:49 AM   #4
RalliartRsX
Trader Rating: (32)
Refer to the FSM for the proper torque. Unless the bolt is stretched (at which point, it's useless anyways), the torque should be the same as in the FSM
But again, please refer to the FSM for the correct and relevant information .
Old 03-23-2017, 08:06 AM   #5
R3cK
in the FSM there is only info about the HEAD Studs length for reuse.
nothing about the main studs :/
Old 03-23-2017, 08:30 AM   #6
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
The main bolts are re-usable, they're not torque to yield fasteners. The ARP studs have issues on the RWD blocks because ARP designed them for use on the US version of the SR20 which is FWD with a different upper oil pan. If you want a performance fastener made with ARP material we have studs that fully bottom out into the block and clear the RWD oil pan which are good for over 500hp.
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-23-2017, 08:34 AM   #7
R3cK
perfect thanks!
Old 03-23-2017, 10:20 AM   #8
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Here is a good thread with lots of Q-A's:
http://zilvia.net/f/showthread.php?t=440251
di-devol is offline   Reply With Quote
arp, main studs, redtop, sr20det
