Old 05-21-2010, 03:34 PM   #1621
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
Originally Posted by Jwow View Post
Is it possible to pull the key out without pressing that pin? It's kinda annoying. Thanks for helping again.
is that seriously annoying? wow. just sell your car if you think that is annoying.
shiftdrift is offline   Reply With Quote
Old 05-21-2010, 03:50 PM   #1622
I LUV MY S13
I LUV MY S13's Avatar
ok i have no power inside the car; stereo, auto seatbelts, gauge cluster, head lamp..
my assumption is that im getting no power to the fuse box, but then the little clock inside the car turns on. what do you guys think?
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 05-21-2010, 07:11 PM   #1623
thetopcow
thetopcow's Avatar
thetopcow is an unknown quantity at this point
I am wondering why you have to use all the 93 DOHC S13 KA stuff when swapping a 95 obd1 DOHC S14 KA engine into a 89-90 chassis? Looking for specifics not just, it's easier. Thanks
Facebook Link: https://www.facebook.com/brickhouseproductsllc
thetopcow is offline   Reply With Quote
Old 05-21-2010, 07:52 PM   #1624
Corbic
Corbic's Avatar
Just a guess but the S14 harness is different then the S13 harness.
So yes, it IS easier as you are having to too screw with two completely different EMS and wiring systems.
Old 05-21-2010, 08:34 PM   #1625
Patrick Bowering
Patrick Bowering's Avatar
Patrick Bowering is an unknown quantity at this point
Hey guys I need a gm intake air temp sensor anyone know which vehicles use the threaded one?
Patrick Bowering is offline   Reply With Quote
Old 05-22-2010, 10:17 AM   #1626
alonroz
Trader Rating: (98)
alonroz is an unknown quantity at this point
Feedback Score: 98 reviews
Is this an oil sandwich plate or a remote oil filter relocation mount?
theres a very big threaded hole on it's side...took pics of it on both sides
Thanks in advance to all helpers!
alonroz is offline   Reply With Quote
Old 05-22-2010, 10:43 AM   #1627
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
This is an oil sandwhich block. I wasn't aware that Nismo made an oil filter block for our cars. I'm pretty sure that block would be for a G35 or 370Z. It looks like it's missing three pieces. You need the oil filter adapter piece that slides through the center, a cap for the open port, and a rubber o-ring to sit inside the circular slot in the last picture. If you get it, make sure it fits the M20 size which is what the majority of the SR20s use (My SR uses a M19, but I purchased the Tomei N2 Adapter instead.), as well as KAs.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 05-22-2010, 11:59 AM   #1628
ki_JDM_ds
ki_JDM_ds's Avatar
Trader Rating: (56)
Feedback Score: 56 reviews
When you run an oil filter relocation kit and/or oil cooler do you have to put more oil in than normal to compensate for more volume?
ki_JDM_ds is offline   Reply With Quote
Old 05-22-2010, 12:05 PM   #1629
alonroz
Trader Rating: (98)
i don't know if it's for sr20's or VQ's - the central hole looks to be rather small for an M20 (about 0.8 inch), also its fairly large for a normal sandwich plate.
So just to make sure i got it right - it has nothing to do with oil filter relocation then?
thx
Old 05-22-2010, 12:17 PM   #1630
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
Yes......but for how much more oil depends on length of the line you ran to relocate & size of oil cooler. (usually about another quart of oil)
Maiku240sxS14 is offline   Reply With Quote
Old 05-22-2010, 12:38 PM   #1631
xpertsnowcarver
Trader Rating: (44)
I use a Tomei N2 block, about 5 ft of -10AN hose, and a Setrab 616 (Series 6, 16 row) oil cooler. I pour 4 quarts in my engine. It only took about an additional pint (half of a quart) to fill the oil filter, hoses, and oil cooler as much as possible.
thx
Correct. That block does not relocate the oil filter. It only provides you an option to run an oil cooler.
My YouTube Channel
Old 05-22-2010, 03:33 PM   #1632
Nizmo_max
Nizmo_max's Avatar
Nizmo_max is an unknown quantity at this point
quick question..okay i did the 300zx brake swap..and now my car doesnt have pressure..my setup is 30mm z brakes up front..and stock rear calipers..with all four ss line...when the car isnt moving i have pretty good pressures brake pedal has minimum travel..BUT when i start to drive the car or the car is moving and i need to brake..i TOTALLY have zero pressure the only way i will get if i keep on pumping the brake pedal..also i am using the 17/16 BMC..from a z fyi...YES!!! i bleeded my car like 10 times...fluid comes out solid....is there something else i did wrong..need help asap..thanks
Nizmo_max is offline   Reply With Quote
Old 05-22-2010, 04:12 PM   #1633
xpertsnowcarver
Trader Rating: (44)
You should use the BMC that was meant for those brakes. 17/16" Z32 BMC.
My YouTube Channel
Old 05-22-2010, 04:54 PM   #1634
Nizmo_max
Nizmo_max's Avatar
yes i do have those...anything?? or ideas why my cars not getting pressure??
Old 05-22-2010, 05:07 PM   #1635
Krewlkid
Krewlkid's Avatar
Trader Rating: (26)
Krewlkid is an unknown quantity at this point
Feedback Score: 26 reviews
s14 zenki lights
im looking for s14 zenki headlights that are glass and are 100 clear, i think there aftermarket but im not sure.
Thanks
Sam
Krewlkid is offline   Reply With Quote
Old 05-22-2010, 05:42 PM   #1636
xpertsnowcarver
Trader Rating: (44)
Ah! Okay then here's what you do. You need to adjust your brake booster. You need to remove the BMC to do it. That's what I did when I installed my brake system. You'll need a friend to assist you.
Have your friend press and hold the brake as far and firmly as he can. He'll need to do this for at least 3 mins, depending on how long you take.
You will need, if I recall correctly, an 8mm wrench and pliers. You'll know what tools you need to adjust the brake booster accordingly. With your BMC removed, and your friend firmly pressing the pedal, a small shaft will poke out of the brake booster. That is what you adjust. Unscrew it to increase braking force into the BMC; and vice versa.
My YouTube Channel
Old 05-22-2010, 06:10 PM   #1637
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
Thanks
Sam
I thought those are the OEM German ones IIRC
badicalradical is offline   Reply With Quote
Old 05-23-2010, 07:36 AM   #1638
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
What settings as in soft or hard to run coilovers when drifting? Do you run the rears softer than hard or harder?
JohnnyDrfiter22 is offline   Reply With Quote
Old 05-23-2010, 11:19 AM   #1639
Patrick Bowering
Thanks
Sam
Enjuku racing sells the german ones but IIRC they are not 100% clear.
Anyone use a threaded gm intake air temp sensor? I need to know an application or a part number.
Old 05-23-2010, 11:36 AM   #1640
turbotofu
turbotofu's Avatar
turbotofu is an unknown quantity at this point
Question...so one of the nuts that goes on the top of the one of the 3 studs, on the camber plate, is stuck. This is for an s13, cusco comp-s coils.
It spins in place, and no matter how many times i turn it, it neither moves up nor down. Any ideas as to why this is happening?
turbotofu is offline   Reply With Quote
Old 05-23-2010, 11:38 AM   #1641
hockeyrules
hockeyrules is an unknown quantity at this point
I need help picking out what size of rod bearings I need. I want cosworth, but I'm going to get my crank polished. So would I need a size zero? Size one is standard.
hockeyrules is offline   Reply With Quote
Old 05-23-2010, 02:21 PM   #1642
badicalradical
DIYAutoTune.com
A quick google showed 85-90 F and Y bodies came with them.
Old 05-23-2010, 02:28 PM   #1643
keeeban
keeeban's Avatar
Trader Rating: (22)
keeeban is an unknown quantity at this point
Feedback Score: 22 reviews
Just a quick question.. I've tried searching, but it hasn't led me specifically to my answer.
So, for an auto to 5speed KA24DE swap, would I still be able to use the automatic engine? If so, what problems would it cause, and would I only be able to shift up to fourth gear?
I've read the faqs and write ups, but I didn't read anything about swapping in an engine originally from a manual.
Thanks a bunch.
keeeban is offline   Reply With Quote
Old 05-23-2010, 02:37 PM   #1644
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
it all depends on the power you're making ect., but just for a basic setup run medium in the front and say you have 15 way adjustable coilovers, run 7 then fine tune. the rear should be set harder, 15 if you want to and adjust from there.
sounds like it is stripped out possibly?
Thanks a bunch.
yes, you can use the same engine, it's the same engine, just an automatic, not manual.
Old 05-23-2010, 02:39 PM   #1645
keeeban
keeeban's Avatar
Trader Rating: (22)
Oh okay awesome. That cleared up all my confusion. Thanks!
Old 05-23-2010, 03:11 PM   #1646
Patrick Bowering
Originally Posted by badicalradical View Post
DIYAutoTune.com
I searched google for a while trying to find an application and just found people talking about them on the forums. Never thought to check them out my friend just bought an ecu from them about a week ago.
Old 05-23-2010, 04:44 PM   #1647
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
What direction do you turn the distributor to advance the timing? ie clockwise or counter-clockwise
pacotaco345 is offline   Reply With Quote
Old 05-23-2010, 04:53 PM   #1648
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
Advanced Timing... : KA24E / KA24DE Forum
simple answer, clockwise.
Old 05-23-2010, 06:06 PM   #1649
turbotofu
turbotofu's Avatar
Yea that was a guess I had...is there any trick to removing it other than chopping it off?
Old 05-23-2010, 11:20 PM   #1650
Patrick Bowering
Just incase anyone ever needs to know. The part number for the gm intake air temp sensor with open element is GM#25036751,AC Delco 213-190, standard#AX1 pigtail#S-556
