03-28-2013, 01:03 AM | #1 |
1995 Nissan S14 240sx Fully Built with a Nissan RB26
I am selling my 1995 Nissan 240sx S14 Zenki Fully Built Track Car equipped with a Nissan RB26DET. The car is street legal and is titled/registered. There has been zero expense spared in the building of this car. I must emphasize that this car has been purposely built as a race car. All parts on the engine are top notch and basically brand new!
The car is XDC/Formula Drift legal, which means that the car is also able to compete in any pro-am or pro events. The motor is easily capable of 1000 horse power; It does need to be tuned. The car currently has all of stickers removed on it to insure new sponsors have the most canvas if and when the car is competing. I have lost interest in competing and no longer have a use for a track car. I am in no rush to sell it. The price is definitely negotiable. I might consider another 240sx plus cash on your end or perhaps even part out the car. Let me know what you have. Please do not contact with an inadequate trade or offer as I simply will not respond. DRIVETRAIN: • RB26DETT out of a R33 Nissan Skyline GTR • Precision 6262 T4 Twin Scroll Single Turbo • CP Pistons • Greddy pulley Kit • ARP head studs • New OEM Nissan Head Gasket • RB McKinney Motor mount kit • Every gasket and seal oil pan to valve cover has been replaced • Greddy kevlar timing belt • AN Fittings on everything possible, I worked extremely hard to make every AN fitting be only blue on the car. There is about $1500 in AN fittings throughout the car. • RB25 oil pan from Nissan • Fully Polished RB26 timing cover, Cam Cover, etc • Splitfire coilpacks • NGK Iridium Spark Plugs • RB26 ITB intake manifold • Twin scroll top mount t4 turbo manifold • Turbosmart hyper gate 45 wastegate • Turbosmart Raceport BOV • Blue Aluminum Top Feed Fuel rail • Titanium tip 3" Full race exhaust • Intense Power 1000hp 4" Front mount intercooler • Intense Power Custom 3" intercooler piping • Boost Flow Custom Made oil catch can • Aeromotive Fuel Pressure Regulator • Koyo radiator with t-bolt clamps • Samco Radiator Hoses • Electric Fans- • Oil sandwich plate • New oem belts • N1 Water Pump • N1 oil pump • UMS Tuning Vacuum Block • 12 Row Oil Cooler • 12 Row Power Steering Cooler • Aluminum Power steering reservoir • 2 QT Accusump with cut off switch • Boostflow custom 3" downpipe • Injector dynamics 1000cc injectors • Copper hardline wastegate lines with all a/n fittings • Haltech platinum sport 2000 stand-alone engine management • Haltech wideband 02 • Custom Made Engine Harness by Vitaly at Ace Up Motorsports • Fully painless wired chassis with 6 switch painless wiring panel with built in circuit breakers • Competition stage 5 single disc clutch • RB25 trans • Arizona Driveshaft custom driveshaft • Welded diff • XS 80 gallon per hour high flow billet fuel pump • 16 gallon fuel cell • All new hardlines with A/N fittings for fuel cell BRAKES/SUSPENSION: • Stance GR+pro coilovers • Rotora Big Brake kit with drilled/slotted Rotors with Blue calipers • Fully boxed Nismo Front lower control arms • SPC tension rods • Future fab rack spacers and modified knuckles • 5 lug front and rear • Z32 rear aluminum uprights • Z32 rear brake calipers • Ksport rear toe arms • Ksport hydro e-brake plumbed with A/N fittings • Power Trix chrome ruca's • Solid subframe bushings • Baller Bolt sub frame bolts • S13 welded diff • Stainless Steel Brake Line Kit by Suspicious Garage • Energy suspension steering rack bushings • Varrstoen Wheels: • Front: 18x9.5 +0 Offset with Federal RSR595 255/35/18 • Rear: 18x10.5 +0 Offset with Federal RSR595 265/35/18 CHASSIS/FABRICATION: • Paint is a beautiful deep blue called "Orgasmic Blue" created and painted by Elite Automotive Finishes • Future Fab fully Tig welded and polished roll cage with bash bar • A&B pillar gussets • Future Fab full tube and gusseted from end (also fully Tig welded) • Fully stich welded chassis (engine, interior, trunk,, everywhere) • Future Fab rear firewall/ bulkhead • Future Fab rear wheel tubs • Exterior/interior/engine bay all painted "Orgasmic Blue" • B-Magic 30mm front fenders • Origin lab "stylish" body kit • 9K racing huge Carbon fiber wing • HID headlights • Tinted taillights • 9k racing hood vent • Hood and trunk pins • Fully gutted doors • Purple Aluminum Tow Hook • All non-essentials removed • Sparco Evo FIA approved Racing seats with Bride seat rails • Nardi Steering wheel • NRG Hub • NRG Quick Release • G Force racing harness • Turbo Smart Electronic Boost Controller • Uncracked dash • Isis short shifter EXTRA PARTS: • Oem coil packs • Extra CAS sensor • Spare FMIC • Two extra sets of head lights • OEM RB26 engine harness • Can include a Apexi Power FC D-Jetro for an extra cost or swap out the Haltech unit if you prefer • Extra log style rb26 manifold • I have a ton of other extra parts that I'm sure I am forgetting. If a good price is met you can everything extra for the car and motor. Price: $28,000 $26,500 Or Best Offer! Don't be afraid to make me an offer. Parts can be removed if not wanted to lower the price of the car. Contact: (949) 922-7937 (Feel free to Text me) Pictures: Last edited by BrownDogg; 04-16-2013 at 06:48 PM.. |
03-31-2013, 10:34 AM | #4 |
Bump for a man who spends a vast amount on fittings.
Are you running stock rods, and how much power is it making to the ground/area of power band? Your engine bay makes that 6262 look big! I would have started at a higher price since I know how much it costs to fabricate and build one up, but you should get your asking price if the right buyer snatches it up. They'll be one happy camper with that 26. |
04-16-2013, 06:47 PM | #5 |
Thanks for the reply and recognized about the fittings. I wish I could truly show how many were on the car. Theres fittings in places of the motor that you can't see with the motor in the car, under the car, inside the car, in the trunk. haha
Rods are stock on the motor and as for horsepower... I dont have a HP # since i never had the car dynoed. Ive lost interested in this and am buying a house instead of this car. Price update: $26,500 |
04-17-2013, 10:17 AM | #6 | |
Posted from Zilvia.net App for Android
1JZ |
04-17-2013, 02:34 PM | #7 |
I know the seller personally, awesome dude to deal with. I can vouch for this car as well literally a beautiful beast! Also theres AN on AN on AN, it makes me jealous..
p.s Dibs on the wing |
240sx, rb26, s14, skyline |
