Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Advertiser Announcements and Feedback
Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback.
Old 02-20-2015, 02:00 PM   #1
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
RB25DET Pro Series wiring harness is here!
RB25DET PRO Series Harness: Only $599 for S13 and S14 240sx - ORDER HERE - Limited Quantities so order now!
After much research and development, our highly anticipated RB25DET PRO Series wiring harness has arrived. This sleek new harness is 100% plug and play and comes with a startup guarantee! It was designed in house on an actual RB25DET engine and supports most ECU's, injector types and MAFS. Wiring your RB25 swap has never been easier!
PRO-SERIES HARNESS SPECS
• Plug and Play.
• No cores or additional wiring required.
• Point to Point continuity tested on every wire.
• Constructed using OEM connectors and seals.
• Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing.
• Wrapped in lightweight nylon loom with -94C to +257C operating temperature.
• Includes a charge harness and improved grounds.
PRO-SERIES HARNESS INCLUDES
• Quick disconnect MAFS/AEM/Haltech/PFC Speed density extensions (change from MAFS TO AEM/Haltech in seconds).
• Coil harness sub-harness.
• Knock sensor sub-harness.
• Transmission harness with reverse and speed sensor wiring.
• Alternator charge cable.
• Nissan Diagnostics connector.
• OEM Power and dash interface connectors.
• Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
wiring specialties is offline   Reply With Quote
Old 02-20-2015, 05:58 PM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
nice, do you sell these without the lower harness?? I already have a pro tranny/alt harness.
supersayianjim is offline   Reply With Quote
Old 02-20-2015, 06:45 PM   #3
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
Are you planning to do one for the NEO as well ? Please Do
Thanks!
MR_GUTTI is offline   Reply With Quote
Old 02-21-2015, 10:41 AM   #4
wiring specialties
Right now they can only be ordered as a full set.
Old 02-21-2015, 10:42 AM   #5
wiring specialties
Thanks!
Yes we are. It will be out soon actually.
Old 04-10-2015, 09:42 AM   #6
wiring specialties
Thanks!
They are on the shelves and ready to ship, let us know if you would like one
Old 04-10-2015, 02:45 PM   #7
BrokenWhite240
BrokenWhite240 is on the path to ruinBrokenWhite240 is on the path to ruin
I will be contacting you in about maybe a month for a harness. I have a S1 Rb25det engine in my RHD S14. But in my car all my wiring is all rhd jdm from my engine bay, dash, and rear body harness. I see that your site has a listing for S14 RHD Rb25det full harness. So would the harness that you offer be plug and play for me?
Team Prettyboys
BrokenWhite240 is offline   Reply With Quote
Old 04-10-2015, 02:48 PM   #8
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
this is pretty
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-13-2015, 08:03 AM   #9
wiring specialties
Yes you are correct, it will be a direct plug and play for you. Should be extremely easy for you. Let us know, we would be glad to assist you
Originally Posted by Flicktitty View Post
this is pretty
thank you
Old 04-15-2015, 05:10 PM   #10
vipergtsr1000hp
vipergtsr1000hp is an unknown quantity at this point
so the pro rb25 neo harness is out already? i dont see it at the site. anyways how much would they cost? thanks.
vipergtsr1000hp is offline   Reply With Quote
Old 04-15-2015, 06:08 PM   #11
s13rhdhatch
s13rhdhatch is an unknown quantity at this point
When will we see rb25det to r32 harnesses?
s13rhdhatch is offline   Reply With Quote
Old 04-22-2015, 07:28 AM   #12
wiring specialties
http://www.wiringspecialties.com/rb25detneo.html
Here is what we offer for the rb25 neo engines
almost ready, we are just finalizing a few more connectors and it will be all set
