Old 08-09-2017, 09:16 PM   #1
Kaisen
Kaisen is an unknown quantity at this point
Burning engine oil + smoke from exhaust
Hi guys,
My S14 SR20VE conversion has been burning engine oil quite rapidly,it can drop from H to L in a few weeks, no signs of oil leaking or whatsoever. Engine has been rebuilt together with the VE head around this period last year with CP pistons and piston rings, supertech valvetrain set, new valve seals, tomei headgasket.
Some white smoke can be seen from exhaust from time to time, but not always. Once when I was decelerating to a stop at the traffic light and a cloud of smoke blew by. Not losing coolant as well.
My turbo is a stock S14 turbo. I am suspecting it might be the turbo as the smoke doesn't appear all the time which shouldn't be the case if it's the piston rings or valve seals?
Attached is a video of the exhaust smoke. Appreciate your inputs.
https://www.youtube.com/watch?v=eS5lzKx3rnI
Kaisen is offline   Reply With Quote
Old 08-10-2017, 09:14 AM   #2
914Slide
914Slide's Avatar
914Slide can only hope to improve
I suspect rings or ring lands check compression. if its all good get a new turbo.
914Slide is offline   Reply With Quote
Old 08-30-2017, 12:39 AM   #3
SidewaysS13ka
SidewaysS13ka's Avatar
SidewaysS13ka is an unknown quantity at this point
valve seals..
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240.
SidewaysS13ka is offline   Reply With Quote
Old 09-07-2017, 11:58 AM   #4
Rusker
Rusker's Avatar
Rusker is on a distinguished road
I'd check the turbo
1990 S13/SR20
Rusker is offline   Reply With Quote
