Old 07-07-2008, 08:12 PM   #1
Antihero983
Antihero983's Avatar
MAF testing?
alright i've been searching on here for about an hour now, and have found little to nothing on HOW to test a MAF. I have a stock KA24DE in an s13.
anyone have any info on how to test the maf and what o test it for?
Old 07-07-2008, 08:15 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It is pretty damn difficult to test a MAF sensor. Some are pretty much un-testable. I'll check mitchell and see if there is a way to test the s-13 MAF sensor or if it is a process of elimination. MAF sensors rarely go bad though, especially on 240's.
Old 07-07-2008, 08:20 PM   #3
Antihero983
well, mine is doing the whole running good when the maf is unplugged bit, and there are NO and i mean NO vacuum leaks on this car.
Old 07-08-2008, 12:09 AM   #4
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
Try to test voltage test on the car when idling should be somewhere between 700mv to 1100mv on the signal wire You need a DVOM to do it
blownmotor is offline   Reply With Quote
Old 07-08-2008, 12:12 AM   #5
s14jesse
s14jesse's Avatar
s14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-known
Send a message via AIM to s14jesse
turn the car on and unplug the maf and if it idels good that means ur maf is bad
s14jesse is offline   Reply With Quote
Old 07-08-2008, 12:22 AM   #6
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
That is not true at all.
Unplugging the MAFS basically puts the car in a 'limp' mode. Thus masking other problems. It could be something like the coolant temp sensor. Hell, I had the completely wrong ECU on my car, but when I unplugged the MAFS, it idled GREAT.
timlush is offline   Reply With Quote
Old 07-08-2008, 01:03 AM   #7
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
pages in fsm
EF & EC 96
WheelsDirty
Old 07-08-2008, 01:14 AM   #8
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
put your maf on my car.
start car. and find out what happens.
you got my numba!?
always welcome.
Peace Russ\
sillyvia13 is offline   Reply With Quote
Old 07-08-2008, 10:34 AM   #9
sillyvia13
sillyvia13's Avatar
got your rep.
thanks Joe.
I will adhere to you advice.
Stay up.
Russ.
Have a good one.
Old 07-08-2008, 10:36 AM   #10
Antihero983
:edit:
taken to pms.
bomber, thanks for the offer, i'll hit you up asap when i find out more.
Old 07-08-2008, 10:46 AM   #11
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
You need to get a voltmeter!
With the key in the on position Check the black/white stripe wire for 12 volts.
Then check the white(signal)wire for around 0.5/0.6 volts and heres the good part! Blow into the maf with the voltmeter still hooked up and your voltage should rise as you blow into it!
And then last check for a good ground on the black wire.
I hope this helps and this is the best way to see if your maf is realy working without doing the whole plug it in plug it out/borrow your friends maf guess work. You can also check your ecu for codes!
Good luck!!!
-mike-
rps13drift is offline   Reply With Quote
Old 07-08-2008, 11:38 AM   #12
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
so if my car idles like shit with the maf plugged in and idles decently unplugged its not necessarily my maf?
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
Old 07-08-2008, 12:08 PM   #13
Phlip
Yes, I look like that
Phlip's Avatar
Swap MAF with a friend, if the problem follows the MAF, replace it... If not, keep searching for possible cause
Weirdo
And I write too!
Old 07-08-2008, 12:17 PM   #14
Antihero983
Ive tried 3 mafs, one of which came out of a runnng car. I'm just trying to double and triple check my shiznat.
Old 07-08-2008, 03:24 PM   #15
stinky_180
stinky_180's Avatar
Trader Rating: (26)
did you follow the diagnostic procedure in the pages i said?
WheelsDirty
Old 07-08-2008, 05:52 PM   #16
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
if ur gonna check voltae of th emaf and dont wana damage hewires just do what i did and puncture a small hole in the wire with a tack or push pin
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
