06-07-2017, 08:30 AM | #21121 | |
Why the S13 would start & run but the S14 wouldn't is beyond me. My only guess was a voltage drop some how from how the previous owner relocated the battery ie, how he ran the wires/connections & such?
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
06-07-2017, 08:42 AM | #21122 | |
06-07-2017, 09:03 AM | #21123 | |
06-07-2017, 11:43 AM | #21124 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Sent from my Galaxy S8+ using Tapatalk |
06-07-2017, 12:45 PM | #21125 | |
06-07-2017, 06:33 PM | #21127 | ||
Not sure what gauge the power cable is but it's huge I think it's 0 or 1 I took all the wires going to factory + terminal and put them in the distributor |
06-07-2017, 06:40 PM | #21128 |
I even temporarily removed the circuit breaker and distributor and just hardwired it to see if somehow they were bad but no dice
I'm gunnu go take a picture to post on here |
06-08-2017, 12:32 AM | #21131 |
Trader Rating: (25)
Feedback Score: 25 reviews
Quick question. I'm running Nismotronic on my KA-T. I have my wideband output run through the ecu so it monitors it. Now, the single wire oxygen sensor that was original on the motor was toast. The wire broke off right at the base and I couldn't fix it. Originally I figured since it's reading the wideband, I wouldn't need the stock O2. Is this the case or do I need to find a new one and install it before I get it on the dyno?
06-08-2017, 09:11 AM | #21132 | |
https://www.facebook.com/groups/145162022225980/
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
06-08-2017, 09:58 AM | #21133 |
Bump, need to order soon and I don't feel like taking the risk after being told that S14's should be thicker
06-08-2017, 11:05 AM | #21134 | |
S13s are 12mm. S14s and Maximas (and a bunch of other Nissans) are 14mm. Source: am using a combo of S14 and Maxima tie rods, but I've long since forgotten which was outer/innner, or what year Maxima I asked for.
06-14-2017, 12:57 AM | #21135 |
Are there any visual cues to tell the difference between the 220hp SR20DET notch top and the 250hp SR20DET notch top?
06-15-2017, 01:52 AM | #21138 | ||
GM2 (SW/AW)
Read this: s13 to 5lug + z32 swap help?
KA-T for life! Current for sale advertisement |
06-17-2017, 12:39 PM | #21140 |
Trader Rating: (92)
Feedback Score: 92 reviews
Have a question for the SR gurus out there I have a stri dsd tach gauge just wondering what do I need to do to make that work, I've tried the rpm signal but the tach doesn't read that signal I also read the cas 180 signal pin 30 would work? As I don't want to mess with my ecu could anyone confirm if that info is true m.
Sent from my iPhone using Tapatalk |
06-22-2017, 02:42 PM | #21141 |
Find a local welder and throw him like 20bucks to cut it off and weld it shut and never worry about it again.
cONtRol FReAkS |
06-23-2017, 06:52 AM | #21143 | |
Trader Rating: (58)
Feedback Score: 58 reviews
06-23-2017, 06:59 AM | #21144 | |
Trader Rating: (58)
You may be able to use pin 30 but it all depends on of that gauge can read squarewave or if it's voltage based
06-23-2017, 07:14 AM | #21145 | |
Trader Rating: (92)
Cody you da man I did some more research and I stumbled on the whole voltage based tach nonsense lol .. plot thickens Sent from my iPhone using Tapatalk |
06-23-2017, 01:51 PM | #21146 |
Got an issue with my redtop sr in my s13, it's dying at idle in traffic and cranks but wont start back up again, it will also die under load in gear while driving and all of a sudden I don't have any gas pedal response but it will restart if I kick start it while still rolling. Normally I wouldn't ask and do my own research and poke around under the hood but I'm at work the next 3 days all day with zero time to really look anything up and I'd just like some second opinions on what I should look for and investigate when I do get some time to take a look.
06-25-2017, 03:53 PM | #21148 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
My damn key wont come out of the ignition on my s13. Its a new key switch and everything. It was coming out just fine until i got the project running and it got electric power through the switch. I was thinking that it might have something to do with the car being an auto to manual swap, but the car runs fine and the wiring specialties harness is supposed to have everything covered.
Any ideas? Sent from my iPhone using Tapatalk |
06-25-2017, 04:02 PM | #21149 | |
Is there a button on your ignition cylinder? Should be black and on the top portion of it. Push it then turn the key counter clockwise. Sent from my iPhone using Tapatalk |
06-25-2017, 05:28 PM | #21150 | |
Ya there is, but it wont go in all the way Sent from my iPhone using Tapatalk |
