Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 10-11-2011, 02:52 PM   #1
ZMan
ZMan's Avatar
ZMan is an unknown quantity at this point
Write-Up: Adjusting the Valve Lash on a '03 350Z
What's going on guys,
Adjusting the valve lash on your engine is one of the most pivotal maintenance procedures that you can perform. It's a good idea to periodically inspect the valve clearance and make necessary adjustments in order to maintain the healthy operation of your engine
With that said, here is the guide to adjusting the valve lash (clearance) on a 350Z. Note that this procedure will most likely also apply to any other vehicle equipped with the VQ35DE engine:
1) Adjust the valve clearance while engine is cold by removing the adjusting shim. The adjusting shim can be removed by using the following procedures:
  • Turn the crankshaft so the camshaft lobe of the valve to be adjusted is pointed straight up.
  • Turn the lifter so the notch is pointed towards the center of the cylinder head; this will facilitate the shim removal process.
  • Using a depressor tool, push down on the lifter and insert a keeper tool on the edge of the lifter to keep the lifter in the depressed position.
  • Remove the depressor tool and remove the shim with a magnet.
Note: Compressed air can be blown into the hole of the lifter to separate the adjusting shim from the lifter.
2) Determine the replacement adjusting shim size by using the following procedures and formula:
  • Using a micrometer determine thickness of the removed shim.
  • Calculate the thickness of a new adjusting shim so valve clearance is within the specified values.
  • R = thickness of the removed shim.
  • N = thickness of the new shim.
  • M = measured valve clearance.
  • Intake shim determination formula: N = R + (M - 0.0118 in. or 0.30mm)
  • Exhaust shim determination formula: N = R + (M - 0.0130 in. or 0.33mm)
3) Shims are available in 64 sizes from 0.0913–0.1161 in. (2.32–2.95mm) in steps of 0.004 in. (0.01mm). The thickness is stamped on the shim; this side is always installed facing down. Select new shims with thickness as close as possible to calculated valve and install it in the lifter.
4) Install the new shim onto the lifter.
5) Depress the lifter and remove the keeper tool. Remove the depressor tool and recheck the valve clearance. Repeat this procedure for any other valves requiring adjustment.
6) When all valve adjustments are finished, install the cylinder head cover, spark plugs and the intake manifold collector.
*diagram courtesy of nissanpartszone.com; all rights reserved
ZMan is offline   Reply With Quote
Old 09-24-2014, 01:07 PM   #2
wtfjay
wtfjay's Avatar
wtfjay is an unknown quantity at this point
is there a possibility you could upload pictures of the procedure
wtfjay is offline   Reply With Quote
Old 06-17-2016, 08:11 AM   #3
starbai
starbai's Avatar
starbai is an unknown quantity at this point
I own one of these generic adjustment tools....
https://www.amazon.com/dp/B0002Q8TU0/
Does the VQ require any kind of nissan specific tool for the job or will this work?
Thanks...
starbai is offline   Reply With Quote
